Dyno results
This is a discussion on Dyno results within the After Midnight Racing forums, part of the Sponsor Support category; Congrats on the strong numbers Minimus! Sounds like a screamer. The curve you described also sounds pretty good...if I remember right, my last Dyno run ...
Go Back   Kawasaki ATV Forum > Sponsor Support > After Midnight Racing
After Midnight Racing After Midnight Racing - Wooster, OH - 330-347-6800
Old 01-11-2010, 05:58 AM   #11
Mikeyboy_esq's Avatar
View Mikeyboy_esq's Photo Gallery(7)
Default
Congrats on the strong numbers Minimus! Sounds like a screamer. The curve you described also sounds pretty good...if I remember right, my last Dyno run showed my peak HP was at 21 mph. I hope to go back to a dyno sometime this spring (if and when I finally install nitrous).
So what RPM was your motor at when you hit peak HP? I'm guessing that is probably pretty close to where you are making the most HP, unless the clutch is WAY out of tune.
Do you have a tach? I just got an Acewell Tach for Christmas...I hope to use that to help me make adjustments to my clutch for the local 300' sand drags. If you have a tach, perhaps you can try heavier weights and test it to see what your rpms look like at your drag strip?
Happy trails...
'04 FST Twin Peaks 800
Boondocker kit/AMR ported heads/FST Stage 3 cams & 11:1 pistons/36mm carbs/LTE dual exhaust/VFJ Stage 4 primary & lightened secondary/Dyna Programmable CDI/FST intakes/lightened flywheel/Mike Walker oil cooler/Elka rear shock & strut springs/AC front bumper/PRM rear grab bar/ACEWELL 3200 tach & temp gauge = 104.7 RWHP & 67.2 lbs TQ on a Superflow Dyno
Happy trails...
Mikeyboy_esq is online now   Reply With Quote
Old 01-11-2010, 06:35 AM   #12
Feedback Score: 1 reviews
z-mann's Avatar
View z-mann's Photo Gallery(0)
Default
Good numbers... Is this the same dyno you used before?
As far as tuning your clutch... the thing that worked best for me was to get a buddy , who I was close to race wise.. mark of 3, 400 ft or whatever.. line em up... then go try something.. and race again... of course.. you both can't make any changes...Tough to be able to notice any improvements on your own unless you have some sort of timer set up.
04 kfx730- Fundy powered
04 kfx764- " "
04 kfx800 chain drive
04 kfx700 stock
04 kfx ? drag frame chain drive
05 Polaris sportman 90
04 Polaris predator 90
03 Polaris predator "troy lee" 90
99 traxter
z-mann is offline   Reply With Quote
Old 01-11-2010, 06:38 AM   #13
Feedback Score: 9 reviews
RAWDAWG700's Avatar
View RAWDAWG700's Photo Gallery(9)
Default
Nothing wrong with 74 good numbers there Rand congrats
What are you running as far as heads go
FOUR STROKE TECH 730
Special thanks to the following:
Four Stroke Tech
ATV Trick Stuff
Big Kevs Performance
Interstate Motorsports
Dasa Racing
Dick's ATV
Monkey Motorsports
RAWDAWG700 is offline   Reply With Quote
Old 01-11-2010, 08:17 AM   #14
Supporting Vendor
Feedback Score: 7 reviews
VFORCEJOHN's Avatar
View VFORCEJOHN's Photo Gallery(0)
Default
that's a good HP# similar as most other 840's I've seen. You are ported and larger valves??? if so I'd want you revving at 8500-8700 anyway. Bwoody's big valve 730 we had set up at 8900 shiftout. it liked it best there and made 70.5 rwhp
if you have a readout of the chart I can decipher what you can do to get some more out of it. I just need the RPM readings from 25-30-35-40 mph then I can tell what the clutch was doing. you run sand, so you'll want it up more than normal
a/f #1 get that lower. ported and 840 I'd shoot for 12.8:1.
i'd be happy with that. it's got to be a good runner.
www.VForceJohn.com (570) 773-1721
VFORCEJOHN is online now   Reply With Quote
Old 01-11-2010, 08:20 AM   #15
Supporting Vendor
VFORCEJOHN's Avatar
Default
that's the best way to do it. but find someone who is consistant. the speedo works, but sometimes you can run faster point a-b and it will show same speed on the speedo. or if you spin alot speed can go up, but times will be slower.
Old 01-11-2010, 09:27 AM   #16
GnFnRs's Avatar
View GnFnRs's Photo Gallery(0)
Default
hell my bolt on v did 95 mph on the dyno..and only made 49.8 rwhp lol that was with a vfj stage3 clutch and stock holeshots
If Obama is the answer,the question was stupid.
GnFnRs is offline   Reply With Quote
Old 01-11-2010, 01:55 PM   #17
Feedback Score: 3 reviews
kujo's Avatar
View kujo's Photo Gallery(0) Send a message via MSN to kujo
Default
my 820 V with stock valves, trail race cams, 38mm carbs and porting peaked at 8100rpm on rays engine dyno, so you should definately be a bit higer with those big cams/valves/carbs and better pipe.. you are probably making power till atleast 8500rpm.. good numbers, i bet its a blast to drive
DS1000
VULCAN 1600 CLASSIC
ZX12R
KD80
kujo is offline   Reply With Quote
Old 01-11-2010, 02:49 PM   #18
Feedback Score: 2 reviews
skip nay's Avatar
View skip nay's Photo Gallery(0) Send a message via Yahoo to skip nay
Default
Great numbers!!! Enjoy it! Wouldn't the spring in the clutch depend on how fast it would rev? I don't know everything and I'm still learning so I'm just asking. I must have missed waht was all done to this motor so can you please tell me again because I didn't see it in this thread.
What are you mostly going to do with this Brute?
2008 Brute Force 800: AMR 12.5:1 pistons, AMR XX cams, AMR Rings, Millennium Nikasil Cylinders, EHS Air Box Lid, Muzzy Pro Exhaust, Power Commander III, Moose Module, VFORCEJOHN SpiderMod Clutch (Maroon Spring), 24 LB Injectors, and a Bunch of Custom work to make it Reliable, Fast, and Tuned just right by VFORCEJOHN
skip nay is offline   Reply With Quote
Old 01-12-2010, 03:11 AM   #19
Feedback Score: 19 reviews
PIPO's Avatar
View PIPO's Photo Gallery(0)
Default
Good numbers!
What tires did you have on the brute during the pulls? I know that had to do a lot with the mph on the dyno. With 25"tires mine pulled til 108mph before it hit the rev limiter and only 88mph with 18".
KFX 798
AMR/ASR/BKP/Diamond/DG/Dynatek/Elka/Falicon/GT Thunder/JH Clutch/Muzzy Super Pro/WEB
YFZ 450
CP/CCP/FCI/Fox Evol DSC/Fox Podium/Hiper/Houser/JD/Nmotion/REM/Team axle
330'-4.6 660'-7.41@87mph 1320'-12.1@98mph
11secs coming soon...all motor baby!
Last edited by PIPO; 01-12-2010 at 04:01 AM. Reason: verified mph with old thread.
PIPO is offline   Reply With Quote
Old 01-12-2010, 03:25 AM   #20
Feedback Score: 8 reviews
hndlbarmonkey's Avatar
View hndlbarmonkey's Photo Gallery(0)
Default
did you have a fan blowing on the front of you to simulate wind resistance
hndlbarmonkey is offline   Reply With Quote
You may not post new threads
You may not post replies
Dyno results minimus Kawasaki Brute Force/Prairie/Bayou 16 08-22-2009 07:10 PM
Dyno Results Eforce13 Kawasaki KFX700 V-Force 26 02-05-2008 03:05 PM
dyno results 2006 kfx700 Kawasaki KFX700 V-Force 37 11-07-2007 12:25 AM
New Dyno results KISSSOFDEATH Kawasaki Brute Force/Prairie/Bayou 10 05-23-2005 06:03 PM
Dyno results KISSSOFDEATH Kawasaki Brute Force/Prairie/Bayou 45 05-10-2005 08:56 PM
