Go Back   Kawasaki ATV Forum > Kawasaki ATV Performance / Maintenance / Technical > Everything Else
Everything Else For anything else with a motor, Kawasaki or not!
Old 09-07-2009, 10:45 AM   #1
Feedback Score: 2 reviews
skip nay's Avatar
View skip nay's Photo Gallery(0)
Default Need help getting fuel through the carb and into the cylinder!
My wife has made a big mistake years ago. She bought a 2005 Yamaha Kodiak 400 4x4 with electric shift 4 wheel drive. This has had little things here and there and realized she should've bought a kawie. Any way it has plenty of fuel in the tank and getting to the carb. I just cant get the fuel from the carb to the cylinder. I tried carb choke cleaner to start it and it starts just can't keep it running. If I spray it into where the air cleaner hooks up it starts right away. I will probably have to take the carb out but what am I looking for or should I just take it somewhere?
P.S. I just checked spark thats fine. So I put a new spark plug in and it was a little better. So I know its not that.
2008 Brute Force 800: AMR 12.5:1 pistons, AMR XX cams, AMR Rings, Millennium Nikasil Cylinders, EHS Air Box Lid, Muzzy Pro Exhaust, Power Commander III, Moose Module, VFORCEJOHN SpiderMod Clutch (Maroon Spring), 24 LB Injectors, and a Bunch of Custom work to make it Reliable, Fast, and Tuned just right by VFORCEJOHN
skip nay is offline   Reply With Quote
Old 09-07-2009, 12:32 PM   #2
Feedback Score: 3 reviews
View NovaKaw650's Photo Gallery(0)
Default
So when you prime it through the intake before the carb, it will start up and KEEP RUNNING normally?
2002 665 Prairie
FPS 12:1 pistons
FST Stage II Cams
Mild porting
Crossover intakes
Modded airbox
Full Muzzy
Dalton weights
VFJ Springs
Other stuff
NovaKaw650 is offline   Reply With Quote
Old 09-07-2009, 12:38 PM   #3
greasemonkey's Avatar
View greasemonkey's Photo Gallery(0)
Default
Start by opening the drain on the carb bowl to see if the gas is getting to the carb.If it is empty and there is fuel getting to the carb then the needle valve is stuck closed.Some times you can hit the bottom of the carb with the handle of the screw driver to free it up .If not you have to disassemble the carb.
If there is gas in the carb then you have clogged jets and/or passages in the carb.Soak the carb in carb cleaner and blow out passages.Then buy new jets,they are cheap enough.
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline   Reply With Quote
Old 09-07-2009, 12:51 PM   #4
skip nay's Avatar
Default
No it starts just enough until the carb choke cleaner is gone. The line from the tank to the carb is clog free.
Old 09-07-2009, 02:29 PM   #5
o4twinpeaks's Avatar
View o4twinpeaks's Photo Gallery(0)
Default
pull the carb off and clean it. DO NOT USE A HAMMER ON IT SKIP!!!!!!!!!
I can see the carb in little pieces on the back patio now lol
9/08 too much nitrous
2012 sponsors
Twin Air
ODI
GoPro
Steel MX goggles
Leatt braces
o4twinpeaks is offline   Reply With Quote
Old 09-07-2009, 04:20 PM   #6
skip nay's Avatar
Default
Hey Tom can you PM me your number I will call you Wednesday when I get a chance to get back to it. I don't have it off the 4 wheeler yet. I just can't work on the yama anymore than 5 minutes at a time it just pisses me off to no end.
1998 yamaha atv not getting fuel to carb
4 wheeler not getting gas
four wheeler not getting gas
fuel not getting to cylinder
gas not flowing through carberator
gas not going through carb
gas not going through to carbirator on 4 wheeler
kodiac 400 no fuel in cylinder
kx250 not getting fuel
my four wheeler is not getting gas
my four wheeler isnt getting gas
rm80 not getting fuel to cylinder
what causes gas to no get to cylinder from carburetor
You may not post new threads
You may not post replies
Air fuel and rpm's with 39mm carb minimus Kawasaki Brute Force/Prairie/Bayou 5 08-14-2009 04:51 PM
Sea foam - The worlds best fuel / carb cleaner Steve-o- Club Kawie 3 08-18-2008 11:43 AM
36mm Carb air/fuel bb 650 Kawasaki KFX700 V-Force 3 04-19-2007 01:27 PM
Cylinder full of fuel after sitting in garage Whopper Kawasaki KFX700 V-Force 16 07-19-2005 05:49 AM
1987 tecate-4 cylinder vs 1987 kx250 cylinder. appfjord Kawasaki Tecate 5 11-10-2003 06:04 PM
