Teryx 4 clutch modification - Kawasaki ATV Forum
Interstate Motorsports
post #1 of 37 Old 01-26-2012, 05:08 PM Thread Starter
Supporting Vendor
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
Arrow Teryx 4 clutch modification
Got it all done and setup for the T4. soon as it gets done from testing I'll be offering this service to my kawasaki clutch modification lineup.
So far I have Primary clutch modification and primary spring change(no stall setup or high stall setups)
looks something like this.
T4 primary modification involves faceplate modification, spider modification, and sheave modifications and clearancing. There is no KEBC braking system on there. so nothing has to be done.
No special pullers are involved for removing this as well. remove the 22mm nut (reverse thread) and off it comes. it's splined shaft. so no overtorqing on the shaft and causing issues like on the tapered clutch setups of the past.
also, NO deflection setting. the secondary is a constant pinch setup.
I'll be working on adjustable weights as well as higher rate secondary springs in the next coming months.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #2 of 37 Old 01-26-2012, 05:43 PM
Feedback Score: 5 reviews
ItsAllCreated's Avatar
Great to hear John!
So are the performance improvements going to be similar to what happens for a Brute/Prairie/VForce? ...like higher top speed capability, and possible better gas mileage during regular driving?
Thats cool that you don't loose engine braking, need a puller, or needs deflection set (makes it simple & easy!)
Im really beginning to look forward to seeing the performance of these T4's with a few simple bolt-on mods!
~StephenB
ItsAllCreated is offline
post #3 of 37 Old 01-26-2012, 05:51 PM Thread Starter
Supporting Vendor
VFORCEJOHN's Avatar
Yes, but with the new secondary on the T4 when I mod the primary it lets the belt sit a hair lower in the primary and higher in the secondary decreacing the gearing off the start. something we could never do with the earlier secondaries. there'll be no belt squeal as the wet clutch keeps the clutches stopped at idle and the belt has no deflection as the secondary pinches it VERY tight all the time
the overdrive, it already has more than the T2. it actually has very similar travel to my stage 3 teryx modded t2 clutch. I can take it to the next level and max out the belt travel. you cannot bolt on a overdrive faceplate to these models. the faceplate and spider are stock very similar to what I do on the stage 3 teryx mod for the T2. They are FAR different vs a t2 clutch and they way they are setup.
what I'm not happy with is where is our goddamn adjustable helix. guys with bigger tires can benefit from a slower ramp on the helix angle. still we cannot adjust this, so we work around it with spring rates in the secondary (I don't have one this stiff here) we may be into snowmobile rates on these secondaries.
the weights. I see good things here as well as future upgrades to run wider and longer belts. which I can get into later. adjustable weights that I have in mind will be able to adjust MANY things. rev's, backshift, stall, engagment, belt-sheave clearances.
Springs for the Primary. I have them made already. hard to believe but the stock spring is STIFFER than my #2 primary. I have low-mid-high stall springs already available. #3-#4-#7 these use what we would have concidered "race springs"
I'm very happy with the clutching upgrades they have done and I look forward to seeing these motors and clutch setups on the atv models in the future. It'll be way worth it to have these in the atv's.
PHONE: 570-773-1240
post #4 of 37 Old 01-26-2012, 06:20 PM Thread Starter
Supporting Vendor
VFORCEJOHN's Avatar
there's a 2012 Brute 750 Stage 3 clutch VS a 2012 Stage 3 T4 clutch
you can see they are larger but still way more compact than a T2 clutch.
PHONE: 570-773-1240
post #5 of 37 Old 01-26-2012, 06:23 PM Thread Starter
Supporting Vendor
VFORCEJOHN's Avatar
There's a stock 2012 teryx T4 clutch vs a 2012 stock teryx t2 clutch
You can see there is still lots of room for gained belt travel in both of them.
PHONE: 570-773-1240
post #6 of 37 Old 01-26-2012, 06:38 PM
012brute's Avatar
That's some nice work john.keep them end mills a spinning.
012brute is offline
post #7 of 37 Old 01-27-2012, 06:22 AM
Feedback Score: 18 reviews
brute 840's Avatar
That T2 looks like it weighs a Ton!Nice work as always on the T4 Clutch!You think we will see the change to this clutch for the ATVs and will it be a good or bad thing you think VFJ?
2012 TERYX
750 SPORT
2012 FX2 Super Crew F150
355 Gears Rear Locker
SCT X4 Tuner/Unleashed Tuning
Kicker Soundgate kit
Lowered
VAS Traction Bars
Wagner Intercooler
brute 840 is offline
post #8 of 37 Old 01-27-2012, 07:04 AM Thread Starter
Supporting Vendor
VFORCEJOHN's Avatar
If this comes to the Atv they will defiantly benefit. Especially larger tire atv's.
PHONE: 570-773-1240
post #9 of 37 Old 02-07-2012, 02:14 PM
Hey John. One of these days I hope to meet you while riding up in coal country :-) As a T4 owner I am curious to hear what improvements were felt after you got done with the clutch work? Was it a noticable improvement? and where? Thanks!
kfp673 is offline
post #10 of 37 Old 02-07-2012, 02:32 PM Thread Starter
Supporting Vendor
VFORCEJOHN's Avatar
clutch work is after you unlock the ECU. with the ECU unlocked it'll have gearing for 63 mph at 9000 rpm it'll run about 57 mph
with the clutch work it'll have more top end speed to carry it over 70 mph, but as far as what it'll actually do real world has yet to be seen. I think these may hit 70 mph stock internals with pipe, clutch and ECU. were still waiting some parts.
I'll have all the info for you with dyno print outs with in the next few weeks.
PHONE: 570-773-1240
2012 kawasaki teryx 4 clutch
2012 teryx 4 clutch kit
2014 teryx 4 mods
2014 teryx 800 clutch kit
best upgrades for teryx4
clutch kit teryx 4 2014
teryx 4 clutch kit
teryx 4 mods
teryx4 clutch kit
teryx4 muffler mod
teryx4 secondary clutch
vfj clutch kit for a 2015 teryx4 800 price
what effect will a clutch modification have on a teryx4
What can I do to me 840 teryx clutch? deviant_illusion Kawasaki Teryx 10 11-30-2011 08:11 PM
Teryx clutch? PIPO Interstate Motorsports 3 01-03-2011 06:05 PM
FI Brute and Teryx Rev limiter Modification reds650 Kawasaki Brute Force/Prairie/Bayou 2 06-13-2009 05:19 AM
FI Brute and Teryx Rev limiter Modification VFORCEJOHN Interstate Motorsports 9 06-08-2009 07:20 AM
teryx clutch mod? Whitey Kawasaki Teryx 35 02-23-2008 10:26 PM
