prairie 700 mods and clutch questions - Kawasaki ATV Forum
Interstate Motorsports
post #1 of 56 Old 12-05-2012, 10:32 PM Thread Starter
Feedback Score: 2 reviews
kawiprairie700's Avatar
hi vforcejohn im looking for some mods to do to my 2004 prairie 700 and everyone has been saying to get a clutch mod but im not sure what one i need like stage 1,2,3,or 4 and also how much it costs. Also im going to be putting on 26" mudlite xtrs on it and i usually ride on my 20 acres of property but sometimes ill race someone and want a bit more speed but not much mudding. I have a few trails but quite a few hills. Also ive been thinking of the full muzzy exhaust system for it is that a good idea?
kawiprairie700 is offline
post #2 of 56 Old 12-06-2012, 08:11 AM
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
First thing I'd ask anyone with a 2004. How is the condition of the clutch?? How many miles.
9/10 I see older machines need parts along with the modification.
If it's in good condition, I'd suggest a stage 2 spidermod setup with my #1/#4 spring setup. 345.00
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #3 of 56 Old 12-06-2012, 01:13 PM Thread Starter
ill have to check the condition of the clutch tomorrow but it seems to work fine and still tops out around 60-65 mph but it takes about 300rpm off idle to get it to go into gear which it used to almost go into gear right off idle and it has 3800 miles on it before the electrical system went so im still trying to figure that out because all of the sudden when i went to turn it off one day it wouldnt start unless pull started and the lights flickered and the computer dash would turn on and off so ive got it all ripped apart now trying to figure that out. it needs a lot of other things so im rebuilding the whole quad by summer with about a $2200 budget, but when i took the belt cover off, the belt had no cracks at all and still looks almost like new. Im also taking off the valve covers and doing whatever everyone suggests on the pre 05 models its something to do with the screws that hold the piece that hold the cam in fall out and destroy the engine. ive got to do a bit of research on that, So im rebuilding the whole quad but the belt looked new, it still reached 60+ mph and didnt take much at all to get it into gear. I got used this summer with 2300 miles on it for $3300 and think he said he put in a black spring but cant remember so ill let you know when i figure it all out.
post #4 of 56 Old 12-06-2012, 01:48 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
The RPM difference is due to a worn out, un-adjusted belt. Either that, or the primary clutch has some serious wear.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 56 Old 12-06-2012, 02:11 PM Thread Starter
whats the best belt?
post #6 of 56 Old 12-06-2012, 02:26 PM
NovaKaw650's Avatar
Garage
OEM Kawasaki belt only.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #7 of 56 Old 12-06-2012, 05:51 PM Thread Starter
ill get that one then and i think i heard its a good idea to buy the stock belt before and im also wondering about the coolant. What i did was drained the old 50/50 green coolant and put a hose into the radiator and flushed the rad but i didnt flush the system i just put water through each of the cooling lines untill there was no green coming out at the bottom of the pump. The next day i took the hose off and a tad bit of green was still left in there and waited another day and then pulled off the hose again at the water pump and it still had the slightest green but barely noticable. Then i put water through the lines for the last time then put in the engine ice coolant. Is that ok how i cleaned the cooling system out? because the dealer where i got the engine ice from said thats fine if its not completly clear of the green coolant just dont mix it. So will i have any problems? or is what i did ok?
post #8 of 56 Old 12-06-2012, 06:23 PM
NovaKaw650's Avatar
Garage
It's fine; coolant is fully compatible with other coolants.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #9 of 56 Old 12-06-2012, 06:44 PM Thread Starter
well this is blue coolant its engine ice its not regular coolant it was $40 for the 2 half gallon bottles its susposed to cool better and everyone on here said it was good
post #10 of 56 Old 12-07-2012, 01:34 PM Thread Starter
theres the pics i took of the clutch and it seems to have a bit of wear but not that bad you can see it has a bit of wear but it doesnt look that bad anyways ill have to pull it off soon and it still ran normally and went 60+ mph before this and the belt looks very good
02 prairie 650 putting 28" tires on what clutch mods? Lloydthumper Kawasaki Brute Force/Prairie/Bayou 14 04-13-2013 01:10 PM
Prairie 360 4x4 Clutch mods stevyrob Kawasaki Brute Force/Prairie/Bayou 4 08-20-2009 03:40 AM
Clutch Mods, Vforce, Prairie, Bruteforce, Teryx VFORCEJOHN Interstate Motorsports 21 02-22-2009 05:00 AM
some questions about different mods paulg Kawasaki KFX700 V-Force 9 11-13-2007 06:18 PM
What's the best clutch mods for the Prairie 700? Haynes1111 Kawasaki Brute Force/Prairie/Bayou 7 05-02-2004 04:54 PM
