teryx primary clutch bent - Kawasaki ATV Forum
Interstate Motorsports
post #1 of 15 Old 04-10-2013, 05:40 AM Thread Starter
I blew a belt on my 08 teryx the belt wrapped up behind the primary clutch and broke about half of the fins the clutch sleeve closest the the motor rubs the case when you turn it by hand and the whole clutch looks bent I tryed to remove out but snapped the bolt off this morning it was extreamly tight we used a little bit of heat to remove the bolt but no luck it snapped right off the bolt came out with about 1.5 threads the rest broke off first question is how do I get that clutch off beating it off is OK with my iam 100% sure its shot also is a brute force clutch the same and is it possible that the crank shaft end is bent the clutch looks bent like tipped then you look over the top of it
snopro111 is offline
post #2 of 15 Old 04-10-2013, 11:43 AM
Supporting Vendor
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
Sounds like you bought the Chinese puller. these snap off EVERY TIME YOU USE THEM. I can't tell you how many 100's of people this has happened to.
also, be sure you are using a STOCK oem kawy belt!! aftermarket belts blow easily and always snap off the fins when they chunk apart.
as for the clutch, I can fix it. you'd need a new fixed sheave. the part is 195.00 this is very common. I have dozens of these in stock.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #3 of 15 Old 04-10-2013, 02:30 PM Thread Starter
Thanks for the reply I broke the bolt off never got a chance to use a puller I would have ordered a cheap puller tho thanks for the heads up on that. How do I get the primary off with the bolt snapped off in the crank its broke about flush with the crank I will Ez out the bolt but need to get the clutch off first
post #4 of 15 Old 04-10-2013, 03:27 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Quote:
Never seen a clutch bolt break off........ unless you were going the wrong way. You do know that the bolt loosens clockwise?
You've got a bad situation.
You might be able to weld a bolt on the end of the belt, but if you were going the right way, then that's not going to get it off.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 15 Old 04-10-2013, 04:53 PM
clutch
Hey that sucks man!! I have a used primary setup for you if your interested, as far as the bolt issue maybe welding something on it , good luck!
aquatic1998 is offline
post #6 of 15 Old 04-10-2013, 11:14 PM Thread Starter
Aquatic1998 what do you want for your clutch also is their a bolt with it 218-261-0506 is my cell I turned the bolt the correct way I was running it tight then loose trying to get it to break free it broke turning clock wise
post #7 of 15 Old 04-11-2013, 02:23 AM Thread Starter
Is it possable the crank shaft end is bent
post #8 of 15 Old 04-11-2013, 03:50 AM
rdm531's Avatar
anything is possible,but bent unlikely my thoughts
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #9 of 15 Old 04-11-2013, 02:36 PM
Supporting Vendor
VFORCEJOHN's Avatar
that's the only way to break it off. he didn't read the directions and prob tightened it.
what to do is get a puller EPI. and cut about 1/2 an inch off the tip. then pull the clutch off.
PHONE: 570-773-1240
post #10 of 15 Old 04-12-2013, 04:23 AM Thread Starter
Update clutch is off and broken bolt is out used a brute force puller and put a aluminum slug in behind the puller so it wouldn't mess up the broken bolt more clutch came off fairly easy then we drilled through the bolt and used a straight extractor the type you pound in and can turn eather way it came out pretty easily also I baught the teryx not running the previous owners mechanic had it all torn apart the seats. plastic. heads all offwas told when buying it it had a bad crank the mechanic thaught it was blown up or a broken rod that jammes up in the case that's y when starting it it only turns over a little bit and stops. When it was realty the clutch grinding on the case If they only pulled the belt inspection cover they would have seen that long story short I guess right thanks for everyone's help I txtd the previous owner for shits n giggles he said they had just put a new belt in that's y they never checked it
bent crank on 08 kawasaki teryx 750
how do i know if clutch is bad kawasaki 750 teryx
how do you know clutch is bad teryx
how to get a broke bolt out of clutch assembly on a 2008 teryx
how to get clytch off of 08 kawasaki terex#gsc.tab
kawasaki fs bent crankshaft
pulling primary clutch kawasaki 4 wheeler
teryx 750 primary clutch removal
teryx 750 upgraded primary clutch
teryx broken primary clutch cover
teryx clutch going bad?
teryx clutch suport
teryx primary noshoes Wanted 0 02-12-2012 07:12 PM
09 teryx primary complete assembly for sale Redron123 For Sale 2 05-17-2010 09:31 PM
Teryx Clutch Jammer Kawasaki Teryx 20 04-25-2010 07:13 PM
09 Kawi teryx complete clutch primary assembly for sale Redron123 For Sale 9 03-18-2010 12:48 PM
teryx clutch mod? Whitey Kawasaki Teryx 35 02-23-2008 10:26 PM
