07-27-2010, 08:32 AM
#1
Feedback Score: 4 reviews
Red Spring with Silver & Purple stripe
I thought I had a Red spring with a Silver stripe ...pulled it off today and its a Red with Silver stripe AND a Purple stripe too  ???
Any body know what rate that is?
~StephenB
08- BruteForce 750 w/ Muzzy Pro Exhaust System, DASA 38mm TB's, & MSD Fuel/Ignition Controller
03- Prairie w/ 700 motor, FST 11.5:1 Std Bore Pistons, Fundy Race Cams, Rocker Mod, Dyna CDI, FST Intakes, 36mm Carbs, Muzzy Exhaust System, VFJ Stage2 Primary Clutch, VFJ Race Secondary Clutch, DS Customs +7 Swinger
07-27-2010, 08:36 AM
#2
Feedback Score: 7 reviews
Location: Western Poconos (SOON)If they ever finish my new home..
I have a couple at home,I'll look to see if I have that one.
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,VFJ X-over intakes, Looney Tuned Exhaust, programmable Dyna,30 shot of Boon,Brute Force Flywheel,Flexx bars,Rox Risers,ODI grips,ECT.
AMR 330 347 6800
07-27-2010, 09:58 AM
#3
I msg VFJ, but I know he's OOO
I went ahead and installed the Maroon ...and I THIIIIINK the RPM rev a little higher ...but I'm not sure. If it does, then its just a touch higher.
Either way I'm still looking to rev higher. Maybe 500-700 higher?
...I need to get a Tach on this thing!
speaking of Tach's ... which is a good Tach-only gauge? I don't want a speedO at all. The Auto Meter Pro Cycle Guages are pimp daddy, but $250+
~StephenB
07-27-2010, 12:13 PM
#4
I know you said tach only,but I have(and like)this one with a coolant sensor,EGT and Tach all in one.
YouTube- AMR 730 Tach
Digatron DT-30K Series: - Engine RPM (Tachometer) and up to two temperatures. Maximum readings of all functions. Minimum readings of RPM. Timing with an infrared or magnetic sensor. Large, bright, easy-to-read displays. Times displayed to the 100th of a second. USA "Patriotic" cover. Automatic power on and off feature.Backlight for night viewing. (3) Highly visible red L.E.D. warning lights Free P.C. Downloadable software. Features: Custom instrument configuration, charts, and log book. USB and serial computer input. Quality lightweight high impact aluminum casing. Lifetime Warranty.
- Quickest and most reliable sensors on the market.
AMR 330 347 6800
07-27-2010, 12:15 PM
#5
From VFJ:
"That's my #1 spring. Very similar to epi maroon. My spring is an actual 10/170. Epi is rated at 10/170 also but actually measures out at 8/164. So it will have a hair less rpm than the red one. I'd doubt you'd notice any difference."
Oh greaaaaaaaaaat
~StephenB
#6
Feedback Score: 10 reviews
2007 KFX700
07-27-2010, 01:59 PM
#7
Quote: Originally Posted by RobCatV
RobCat you just made my day
...Lookie what I'z gots installed
Hellz yeah!
I had this thing laying around collecting dust. I think it was only 20-25 bucks too (one of them cheapO Auto Zone tachs). Too bad it only goes to 8k, (it goes past 8k; just isnt numbered), but it'll do the trick for now.
That helps ALOT! ...without it I'm changing springs blind (its like trying to tune A/F ratios without a meter. <Worthless).
The clutch set-up currently holds around 7500RPM when @ WOT. I've got the old-style Fundy Race cams ...you guys think thats a good RPM for these cams? ...or do they like it a little higher?
~StephenB
07-27-2010, 02:14 PM
#8
If you are worried about damaging the tach, put in a switch to cut it off when you are planning WOT.
2007 KFX700
07-27-2010, 03:39 PM
#9
why would I need that (because it may push the needle too far)?
It's a cheapie ...i'm not too worried about damaging it.
~StephenB
07-28-2010, 07:13 AM
#10
Supporting Vendor
I have stiffer spring than that . 2-3-4-7 are all stiffer. The #2 220lb spring will take you to about 7800-7900 shiftout. The Fundy 775 can will run just fine at that rpm. #3 250lb maybe a little too stiff unless you have ported heads.
| Visitors found this page by searching for these keywords: |
who was kawasaki gensai had red hair?, purple striped clutch, silver purple stripes, purple stripes in hair
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
» Site Navigation |
