Brute Force 750 power problems - Kawasaki ATV Forum
post #1 of 14 Old 08-28-2010, 01:48 PM Thread Starter
With about an 1/8th of throtle motor dies out. It idles just fine. We have changed the fuel filter and installed new spark plugs with no improvement. It was running good after we took it to the dealer a couple of weeks ago for the same problem and in two days started again acting up. The dealer didn't change the pump. Do we have to break down and buy a new fuel pump??
Pooter is offline
post #2 of 14 Old 08-29-2010, 05:13 PM
Feedback Score: 1 reviews
Carb or EFI?
Hunterworks is offline
post #3 of 14 Old 08-30-2010, 03:21 PM Thread Starter
EFI
We took the filter off the bottom of the pump and installed an inline one that was easier to change. The filter doesn't get empty of gas in full throttle, that's why we are questioning the fuel pressure number. We are just about ready to bring it back to the dealer. I just don't want them to tell us it needed a new pump, when I could have done that myself.
Pooter is offline
post #4 of 14 Old 08-30-2010, 07:10 PM
Quote:
Originally Posted by Pooter View Post
EFI
Did you do this to fix this or it started after you did this?
Also, they can check the fuel pressure.
I might would look at the TPS sensor being out of adjustment
post #5 of 14 Old 09-01-2010, 08:00 AM Thread Starter
the filter was to fix the problem because the filter that is in the bottom of the pump was pluged so we took it out and added the inline filter and what is the sencer u talked about. or how can that be fixed
Pooter is offline
post #6 of 14 Old 09-01-2010, 04:49 PM
Throttle position sensor, you have to measure the voltage across it with throttle closed.
Kinda hard to explain on here.
It is on the throttle body
post #7 of 14 Old 09-01-2010, 07:03 PM
does anyone know what alternate fuel pump can be used on a brute 750? replaced mine twice now at 600 bucks a pop. heard there is a car pump that may work?
bobby71 is offline
post #8 of 14 Old 09-30-2010, 06:10 AM
czy
I have the same problem.
how you solve the problem?
czy is offline
post #9 of 14 Old 09-30-2010, 07:14 AM
Feedback Score: 23 reviews
T_Dilley's Avatar
Quote:
Corvette fuel pump
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
T_Dilley is offline
post #10 of 14 Old 07-17-2011, 07:57 PM
I am having this problem also. So do we adjust the tps or replace. Also my 08 brute has a problem. When I hit the throttle hard it hammers out of the hole and then acts like you put the choke on on a carbed unit. Stock pipe msd changed belt deflection and clutch springs.
Air filter clean no snorkle Pipe screen looks to be mudded up. Could that cause this
Thanks to all
outieman is offline
Tags
fuel pump
07 brute force 750 fuel pressure
2008 kawasaki brute force 750 in line fuel filter
2009 brute force 750 fuel filter location
2009 brute force 750 fuel pressure
brute force 750 fuel pump
brute force fuel filter
brute force fuel pump problems
brute force tps sensor causing breaking ip
kawasaki brute force 750 fuel filter location
kawasaki brute force 750 fuel problems
kawasaki brute force 750 fuel pump problems
where is secondary fuel filter on 08 brute force
where to find a fuel filter for a 2009 kawasaki 750 brute force
4wd problems with 05 brute force 750 blatzman Kawasaki Brute Force/Prairie/Bayou 0 03-09-2010 03:26 PM
07 Brute Force 750 / No Power dragon5801 Kawasaki Brute Force/Prairie/Bayou 1 01-05-2010 01:23 PM
HMF on Brute Force Problems? TSauer09 Kawasaki Brute Force/Prairie/Bayou 1 07-31-2009 04:53 AM
Brute Force problems HELP PLEASE jmeier1981 Kawasaki Brute Force/Prairie/Bayou 5 07-18-2009 07:46 PM
Brute Force Power mn250r Member Pictures & Movies 1 07-15-2009 06:05 AM
