Prairie 700 Valve Clearance Adjustment Troubles!!! - Kawasaki ATV Forum
post #1 of 5 Old 10-10-2010, 12:08 AM Thread Starter
jaybird4th's Avatar
Hey folks. I'm having a bit of trouble getting my clearance correct. I've used my feeler gauges to try and get my clearance to factory specs but my front cylinder is still making this ticking noise. I took the adjustment cap off several times and tweaked it a bit but still the annoying noise. Any suggestions from ya'll out there would be appreciated. Is it possible to have a weak valve spring or am i just still off with my adjustments?
jaybird4th is offline
post #2 of 5 Old 10-10-2010, 06:48 AM
Feedback Score: 1 reviews
applehead's Avatar
better have a look at the cams.
applehead is offline
post #3 of 5 Old 10-10-2010, 06:15 PM Thread Starter
jaybird4th's Avatar
cams and rockers are new.
post #4 of 5 Old 10-11-2010, 07:53 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Is it a very loud ticking?
You're most likely trying to adjust the valves in the wrong part of the cycle.
Ignore what you've heard about "rotating 180 degrees", etc., just remove the valve adjustment cover and roll the engine over with the pull starter. Watch for the valves to cycle; when the intake valve closes you are now starting the "compression" stroke. Rotate the crank another 1/2 turn until you see the proper flywheel mark come into the viewing access hole down by the recoil starter. Set the valves.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #5 of 5 Old 10-11-2010, 12:53 PM Thread Starter
jaybird4th's Avatar
oh its enough noise to get on my nerves when its started. Its like a noise only a person that knows atv engines would notice. It's the front cylinder valves so it may be a little hard to actually see what position the valves are in. I can hear the compression(low sucking sound) when I roll it over though. I'll just go on that and see if I can get some headway. I'll keep ya posted!
2004 kawasaki 700 valve lash
2004 suzuki 700 valve cleqrance
kawasaki prairie 700 valve adjustment
kawasaki prairie 700 valve clearance
kawasaki prairie 700 valve specs
prairie 700 valve lash
prarie 700 valve adjustment
ticking noise kvf700
valve adjustments 700 kawasaki
valve lash kawasaki kvf 700
what is the valve gap on a kvs 700 kawasaki
what is the valve specs. on a 2003 700 prairie
Valve Clearance Pibster Kawasaki Brute Force/Prairie/Bayou 11 04-03-2015 01:55 AM
2003 Prairie 360 Valve Adjustment & Lashing Questions JaCkaL829 Kawasaki Brute Force/Prairie/Bayou 3 10-29-2010 07:07 PM
Valve clearance orangecrush05 Kawasaki KFX700 V-Force 14 01-18-2009 08:50 PM
FST Valve Clearance ICantAffordIt Kawasaki KFX700 V-Force 11 08-06-2007 11:30 AM
valve clearance bartlettracing Kawasaki KFX700 V-Force 1 07-22-2004 03:30 PM
