Bayou 220 Starting Problems - Kawasaki ATV Forum
post #1 of 7 Old 10-10-2010, 10:56 AM Thread Starter
I am having some starting issues with my 02 Bayou 220. I have never had a single problem with it until now and it has been tough as hell. I have noticed about 6 months ago or so that I started have a little bit of grayish smoke coming from the tailpipe. I didnt worry about it at the time and it has been just like normal since then. Anyway today I drove it up on my trailer and it ran great and about 15 min or so later I couldnt get it to fire. I put a new plug in it and it didnt make any difference. I pulled the air filter off and sprayed some WD-40 in the carb and it did fire off that but when it ran for the couple of seconds off that it put out a ton of grayish colored smoke and didnt run for crap. I had thought that possibly my rings have gone bad because it doesnt seem like it is getting good compression, or possibly something to do with the carb. If anyone has any ideas or starting points I would greatly appreciate it. Thanks
09wingates is offline
post #2 of 7 Old 10-10-2010, 02:03 PM
.did you check your carbs are getting gas! check for spark.check that carbs are getting air.motor should run.smoke may or may not be another problem.dont use wd-40 in carbs use gas!
kazo is offline
post #3 of 7 Old 10-10-2010, 05:31 PM
tazmaniac_37752's Avatar
You might also want to check the timing on it mine smoked and then quit and it was the halfmoon key in the charge magnetic drum had sheered and the 4 wheeler wasnt fireing rite then it finally slipped to far to even start!
WARNING: I am new to the 4 wheeler world so any advice i might give will be common sense or compareable to regular autos! If it's bigger than you shoot it twice!!!!!!!!
tazmaniac_37752 is offline
post #4 of 7 Old 01-28-2017, 09:18 AM
I am having electrical problems. I have tested the battery and it is good. The green neutral light comes on but the headlights do not. When I turn on the headlight switch the neutral light goes off. I get nothing when I push the ignition button but it will start with the pull rope.
JimSelman is offline
post #5 of 7 Old 02-02-2017, 08:17 AM
Still sounds like current isn't getting to the starter. Check your battery voltage when you turn on the headlights (with the engine off). Does the starter make any sound at all, like it's trying to start? Your battery may test well with no load, but it may not have any capacity to deliver the current. You may also have a bad connection or ground in the system, too.
SteveH is offline
post #6 of 7 Old 02-02-2017, 09:37 AM
Josephkaisner's Avatar
If it would be helpful I could send you the electrical diagrams and info from the technical manual. Just let me know!
Josephkaisner is offline
post #7 of 7 Old 02-02-2017, 10:29 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Quote:
You have either a bad ground or a bad connection.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
2001 kawasaki bayou starter problems
220 bayou problems
bayou 220 starter problems
bayou startet problems
bayou220 not firing
ignition problems on bayou 220 four wheeler
kawasaki 220 bayou starting problems
kawasaki 220 bayou troubleshooting
kawasaki bayou 220 problems
kawasaki bayou 220 starter problems
kawasaki bayou 220 starting problems
kawasaki bayou 220 trouble shooting
kawasaki bayou 220 troubleshooting
Starting Problems MMEYER Kawasaki KFX450/KFX400 2 07-14-2010 05:59 PM
'j95 Bayou 220 Starting Problems thajuice Kawasaki Brute Force/Prairie/Bayou 0 09-18-2009 07:20 AM
Starting Problems gitrdone Kawasaki KFX700 V-Force 4 05-04-2009 03:05 PM
starting problems MUddogg Kawasaki KFX700 V-Force 3 12-12-2008 05:20 PM
starting problems vtprairie03 Kawasaki Brute Force/Prairie/Bayou 9 06-06-2005 05:16 PM
