Air Cut Off Valve - Kawasaki ATV Forum
post #1 of 6 Old 10-19-2010, 11:05 AM Thread Starter
AverageJoe's Avatar
Air Cut Off Valve
Anyone know what the purpose of the air cut off valve is? It's that small, spring loaded diaphragm at the top of the carbs on the 650's.
AverageJoe is offline
post #2 of 6 Old 10-21-2010, 04:50 PM
greasemonkey's Avatar
That diaphram pulls the needle out of the main jet to richen up the mixture as the motor needs it.It is controlled by vacuum so the motor only gets what it needs.Varying load changes vacuum which chages rate at whic the needle is pulled up.
o2 prairie 650 supertrapp idsx,dynojet jet kit,Diamond G module & air box snorkle,HL clutch kit,Moose front and rear bumpers(rear mounted upside down, front mounting tabs welded onto frame lower than headlights), 2 inch lift with 28 inch itp 589's,front 2500 lb. winch and rear 2000 lb. winch,60 inch cycle country plow with electric lift and angle.
1964 Chevy Malibu conv. 355 cu.in. 4 sp. two stages of nitrous 850 hp at crank 10.20@142mph.
1970 Chevy Nova 396 auto tubbed and caged.
2000 Ford F350 4x4 7.3 diesel 538 hp 925 lb. torque at crank
1994 HD Dyna wideglide 96 in. S&S custom wheels and paint
1972HD FLH 1200 port and polished heads,sifton cam, aries piston,lightened flywheels,5 sp. in a 4 sp. case trans
1994 prostreet HD sportster 1200 105 hp. 180 rear tire ,midglide front end ,custom wheels,removeable wheelie bar.
Special construction 96 cu in rigid, 10 in over springer,250 rear tire,5 sp w/kick and electric start,3 in. open primary,foot clutch hand shift.
08 Skidoo 800 Renagade XP
02 Skidoo 800 Summit
He who dies with the most toys dies with an empty wallet(and usually single)
greasemonkey is offline
post #3 of 6 Old 10-21-2010, 08:21 PM
Feedback Score: 1 reviews
Quote:
Wrong diaphragm, your talking about the throttle diaphragm
CUT OFF VALVES PREVENT "AFTER BURN" GENERATED WHEN THE THROTTLE IS SUDDENLY CLOSED WHEN THE THROTTLE IS SUDDENLY CLOSED, THE VALVE TEMPORARILY CLOSES THE SLOW-JET PASSAGEWAY---CREATING AN INSTANTLY RICHER MIXTURE AND THUS REDUCES "POP" SOUNDS UPON DE-ACCELERATION
Hunterworks is offline
post #4 of 6 Old 10-22-2010, 10:59 AM Thread Starter
AverageJoe's Avatar
Thanks, Hunterworks. I noticed that one of the air cut off valves on my bike was in pretty bad shape, but didn't have time to replace it before my next ride. During that ride, I noticed more "pop" when backing off of the throttle and was concerned about my engine brake.
2006 Brute Force 650 SRA
Kenda Bearclaws
Venom 3000lb. Winch
Kolpin Rear Rack Cargo Box
post #5 of 6 Old 10-23-2010, 06:48 AM
No problem, here to help
post #6 of 6 Old 10-23-2010, 12:24 PM
i always wondered why these things dont pop on deceleration. i wish mine popped more, i love that sound
06 BF 650 sra, 26x12 mudlights,vision 159 wheels,dyna cdi, looney tuned duals,x-over intake, twin-air filter w/ 12hole lid, maroon and black clutch springs, epi front coils, reverse light, autometer tach, custom front bumper and grab bar
islandlife is offline
06 brute symtoms of a bad cut air diagram
2006 kawasaki brute force 650i air cut valve diaphragm
2006 kawasaki brute force 650i diaphragm air cut valve
air cut off diaphragm yamaha 350 purpose
diaphragm,air cut valve brute force
honda atv air cutoff kit
honda rancher air cutoff valve
honda trx 250 air cutoff valve diaphragm
honda trx 350 air cut valve
honda trx faulty air cut
kawasaki prairie 650 air cut out valve
trx 250 air cutoff valve?
what does a air cut off valve do on a raptor
Valve job 05-BF-750 Kawasaki KFX700 V-Force 13 05-03-2010 06:25 PM
valve job? brichardson02 Kawasaki KFX700 V-Force 1 12-28-2009 12:17 PM
E.G.T. valve dirk_411 Kawasaki Tecate 12 04-10-2009 05:26 PM
Valve ?????? orangecrush05 Kawasaki KFX700 V-Force 22 03-28-2009 11:27 PM
