750 Brute force will idle but bogs with throtle - Kawasaki ATV Forum
post #1 of 11 Old 10-26-2010, 12:27 PM Thread Starter
I've cleaned the carbs set them back to factory specs set the valves new plugs fuel pump is working I have good spark. the bike will start and idle beautifuly but when I apply throtle the engine bogs and back fires??? I'm frusterated could it be cdi? voltage regulator? can i eliminate belt break switch? engine break? how does any of this affect the way it runs?
2005 Brute is offline
post #2 of 11 Old 10-26-2010, 02:52 PM
Feedback Score: 9 reviews
kawboy1's Avatar
Have you got any mods? You say you set it back to factory specs.....how did it run before that? When you put the carbs back together did you make sure that the rubber diaphrams were in good condition with no holes or splits and seated properly and the little nipple on the diaphrams in correct spot?
At what throttle position does it bog? Make sure you have no flashing 4x4 lights on the dash....if you do it could be in limp mode which means you will have to adjust the belt back into spec or replace, then re-set the belt switch. If you fit a Dynatek cdi it will no longer go into limp mode, it also eliminates the reverse over ride so you have full power in reverse, raises your rev limit to 9500rpm and best of all gets rid of the timing retard to give you a very noticeable power improvement.
You can also remove the KEBC fork to save wear on your clutch but you will lose engine brakeing at low speeds although all you have to do is blip the throttle a little and your clutch will engage to give you engine brakeing.
LOONEY TUNED FST 765
LOONEY TUNED KFX450R (SOLD)
My You Tube videos http://www.youtube.com/user/michealmannion?
feature=mhum
kawboy1 is offline
post #3 of 11 Old 10-26-2010, 04:55 PM Thread Starter
Thanks I know the carbs are good I'll try the belt break switch but I do have a after market cdi box on it when I unplug the engine brake or belt break the 4x4 light flashes but while they are pluged in it reading normally can I test either of these components to make sure they are functioning corectly?
post #4 of 11 Old 10-26-2010, 05:45 PM
Do you still have your stock CDI laying around? If so, try putting it back on. If everything works fine, you know it's your CDI. Had the same problem with a prairie I had. The aftermarket CDI went bad.
2006 BF 650i-Dynatec CDI, HMF Utility slip-on exhaust, EHS Racing Lid, UNI air filter, front airbox hole blocked off, airbox screen removed, maroon/almond spring combo, 2" lift, 27" Swamplites, 14" Douglas Rattlesnakes
650iRider is offline
post #5 of 11 Old 10-26-2010, 05:50 PM
kawboy1's Avatar
What cdi do you have on it? If its a Dynatek they bypass all that belt crap but if its a Moose or simmilar they dont.
feature=mhum
kawboy1 is offline
post #6 of 11 Old 10-27-2010, 06:33 AM Thread Starter
It is a Dynatek I'll try the old cdi box and check the belt switch thanks
post #7 of 11 Old 10-27-2010, 02:47 PM
Hey, i'm having the exact same problem with a 05 650 Brute Force. i've tried all the above tests also minus the CDI because i do not have an extra.. the one on the machine is stock. would love an update from your test with the stock CDI to see if it fixes yours before i replace mine. Thanks.
kawcycle is offline
post #8 of 11 Old 10-29-2010, 07:53 AM
i got an 05 750 with exact same problem,i got the dyn cdi box to try to fix this issue and been threw the carbs twice. i have also checked timing with timing light per service manual . checked all valve clearance. any help would be awsome
cmfgoobie is offline
post #9 of 11 Old 07-11-2012, 05:40 PM
Wondering if the stock CDI box fixed your problem? Did you notice your voltage regulator getting hot?
dirtykawie is offline
post #10 of 11 Old 07-22-2012, 11:10 AM
what fixed the one i was working on was the ,(the drivetrain moudle is what i called it. not the cdi) and jetting the carbs. the drive train moudle was bad also killing the battery and putting the stock cdi in limp mode( rev limiter ) did the same to aftermarket cdi.........you have to completely install the air box to test, filter and lid that you are going to run or you will be chasing your tail !!
hope this helps
goobie
05 750 brute force idles good but craps out when given fuel
05 brute force 750 bogging and backfiring
06 kawasaki brute force 650 bogging when cold
2005 brute force idles good but only back fires when throttle hit
2006 brute force 750 bogging down
2006 brute force 750 cuts out no lights on
2008 brute force 750 rev limiter bypass
750 brute force will run at idle but backfires and no power when give throttle
brute force 650 sra won't idle backfiring
brute force 750 backfire on acceleration
brute force 750 bogs down
my 2007 brute force is bogging down at full throttle
what makes a 750 brute force idle but not take gas
Brute Froce 650 cutting out, bogs down herman23243 Kawasaki Brute Force/Prairie/Bayou 3 10-24-2010 09:54 AM
Brute Force 650 sra won't idle oak1971 Kawasaki Brute Force/Prairie/Bayou 5 10-04-2010 03:13 PM
2005 Brute Force 750i Idle Problem MKader17 Kawasaki Brute Force/Prairie/Bayou 1 04-22-2010 01:26 PM
750 brute force engine idle noise chine Kawasaki Brute Force/Prairie/Bayou 1 09-04-2009 07:14 PM
Brute Force 650 idle question drjpb Kawasaki Brute Force/Prairie/Bayou 1 08-19-2009 03:30 PM
