2007 Prarie 360 Problem...i know, i know.... - Kawasaki ATV Forum
post #1 of 10 Old 11-06-2010, 09:31 PM Thread Starter
Like some, i went through every post in this forum for the problem with the Belt/4x4 light and tried them all...even put in a new harness and still have the belt light and 4x4 light blinking when i turn the key on. Resets have been done (lost count) with the black and gray plug with the 2 pin disconnected and always made sure the belt switch was in the "on" position before doing the test. When i check the brake actuator and the 2wd/4wd actuator with direct battery power they spin and the i rig them right and install them but the brake actuator when i turn the ignition switch on just keeps clicking and doesn't stop. ATV doesn't rev high when test driving it before it feels like a govenor kicks in. Both belt/4x4 lights blink constant when key is turned on. the Belt flashes every 2 secs for 1 sec and the 4x4 is 1 sec on 1 sec off...........whoa thats a lot to type...any troubleshooting suggestions? Would a bad LED indicator cause any problems since there is a diode and a resistor inside?
Hollywood_35 is offline
post #2 of 10 Old 11-07-2010, 02:43 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Sounds like either the KEBS actuator or the KEBS controller under the seat, although that shouldn't make it go into limp mode (I think). Make sure the belt switch inside the cover is actually working; maybe someone here knows if it's normally open or normally closed. Test it with a meter.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #3 of 10 Old 11-07-2010, 03:53 AM
Feedback Score: 18 reviews
brute 840's Avatar
Had this happen a few times a low battery will not let you reset the belt light hook a charger to it while you are doing the belt reset and see what happens I had this happen on a atleast 4 360s in past year low batterys
brute 840 is offline
post #4 of 10 Old 11-07-2010, 04:53 AM
ALDO's Avatar
Go to this site, try to download the service manual:
www.ATVPT.com - Service_Manuals
Then go to the page 16-48 you can see a table with the failure and what means the flashes lights, and a number of check that you have to do.
Also pages 5-8, 16-56.
you try this procedure:
Here is a step by step procedure for reseting the belt light on a Prairie 360.
First, disconnect the two wire plug on the belt sensor (rectangular box rivited to the top of the clutch cover
Then, find the black and grey plugs up under the gas tank cover. These are on the clutch side, just above the belt snsor.
Press the tab and unplug them both
Swap the greay to the black, and black to the grey
Cut the key on for about 5 seconds, or untill you see the flashing lights momentarily blink differently. Then cut the key back off.
Plug the grey and black plugs up the way they were. Don't foget to fasten them back up to the frame, if you pulled the strap off of them.
Plug the belt sensor back in.
Cut the key on to verify the procedure worked.
good luck.
ALDO is offline
post #5 of 10 Old 12-17-2010, 03:27 PM
audiman18235's Avatar
ok hi i am new herre i have a 06 360 praire and aldo had helped me to with mine. i tried to reset the wires as set and that made mine worst . i act on mine i took the two fuse links apart under the seat left them off for say 30 seconds then put them back together that fixed my quad give it a try i might work for you lol just trying to help back bye
audiman18235 is offline
post #6 of 10 Old 04-08-2011, 06:06 AM
fixitrc's Avatar
Smile
Quote:
Make sure the battery is fully charged to at least 12 volts. Low voltage will not let the system reset. Test the belt switch with a meter putting two pins or wires in the connector to the switch and it should be normally closed, if it does not have continuity then the switch is flipped or the wires are broken. Test the check belt fuse using a meter on the wires that run up to the chassis, if the fuse is good you will have continuity. When you are doing the reset, if the system is going to reset the belt led will flash very fast then flash slowly, after 5 or more seconds turn the switch off, reconnect the wires blk to blk and grey to grey and reconnect the belt switch wire. Turn on the main switch and the belt switch should flash once then turn off. If this doesn't work email me Fixitrc@aol.com . It seems like the belt switch system is causing a lot of people to change or rebuild the sputtering carburetor when the system only needs a reset. A LOW BATTERY CAN CAUSE THE BELT SYSTEM TO FAIL AND NEED A RESET. RC
fixitrc is offline
post #7 of 10 Old 05-30-2011, 01:07 PM
just did it and took care of the 100 hr service light thanks
whitegater is offline
post #8 of 10 Old 03-17-2015, 05:22 PM
Unhappy Help please
I took my 2007 Kawasaki prairie to the shop because it had a high Rpm sputter after the guy replaced all the gaskets in the carb because he said they are still bad he tired doing the belt light reset thing said he cant do it so now he is telling me the ECU and wiring harness is bad because it wont let him reset the light is there any way this can be true? other things i read says the belt control module is bad? any tips for when i get it back? also if i do have to get a ECU does it have to be flashed for my bike like a car needs to be PLEASE HELP!!!
gsxrboy is offline
post #9 of 10 Old 03-17-2015, 09:50 PM
Risen!
wawoodwa is offline
post #10 of 10 Old 03-17-2015, 09:54 PM
In all seriousness, it may be best to start a new topic in the forum. That way you can get some specific help. The group here is very supportive. First, make sure the battery is strong and fully charged. That is needed for any belt reset procedures.
wawoodwa is offline
Tags
360, 4x4, belt, prairie, troubleshooting
04 prairie 360 how to test led indicator
07 kawasaki 360 prairie 4x4
2007 kawasaki 360
2007 kawasaki prairie 360
2007 kawasaki prairie 360 4x4 reviews
2007 kawasaki prairie 360 review
2007 kawasaki prairie how to time
2007 prairie 360 running bad
do you have to reset the belt light on a prairie 360 kaw for it to work
kawasaki prairie 360 check belt light
prairie 360 4x2 rev problems
what position do you put the pin in on a 2002 kawasaki 650 prairie 4x4 actuator
02 650 prarie riverkid Kawasaki Brute Force/Prairie/Bayou 10 04-20-2009 07:33 PM
I got a new Prarie wilrideanything Kawasaki Brute Force/Prairie/Bayou 2 11-11-2007 04:24 PM
2000 PRARIE 400 PROBLEM turkeyfoot Kawasaki Brute Force/Prairie/Bayou 4 10-09-2007 05:54 AM
02 650 PRARIE VFORCEJOHN Kawasaki Brute Force/Prairie/Bayou 19 09-22-2004 05:44 PM
module problem or clutch/belt/ jetting problem ?HELP!!!!! sdteb Kawasaki Brute Force/Prairie/Bayou 4 09-28-2003 09:27 AM
