Strange problem with Bayou 300 - Kawasaki ATV Forum
post #1 of 7 Old 01-11-2011, 02:11 PM Thread Starter
I am hoping that someone has heard of this before.
When out riding, my Bayou 300 will just decide after an hour or two to lose all throttle response. Basically, it feels like it is running out of gas. It will idle forever but, any input of throttle will cause it to die. I can limp home using about 3/4 choke and keeping the throttle JUST over idle.
Removing the fuel line shows excellent flow from the tank.
I have had the carb out numerous times. I thought that the float must have been sticking. No problems with the float.
Next, I thought that the needle may be jamming itself in the main jet - no problems there.
I am very good with carbs and have thoroughly cleaned this one. I did install a Dynojet kit (stage 1) designed for a stock Bayou 300 4x4.
Now here is the strange thing. When it does this, I found that it is pressurizing the gas tank. While it is idling, I can stick the vent tube in my mouth and feel the pressure expanding my cheeks.
When the machine is running normal, there is no "back" pressure from the tank.
Any ideas?
Thanks in advance.
mpj220 is offline
post #2 of 7 Old 01-11-2011, 02:38 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Did you install the DJ kit after the problem started, or before?
The only thing that causes pressure in the tank is heat. If you can't get it above an idle and you are going very slowly, this will cause the gas in the tank to heat up.
Two things come to mind: vapor lock or the carb freezing up; they will cause similar symtoms.
Did this problem start with the onset of cold weather? If so, simply shutting the hot engine off for 5 minutes should allow the engine heat to thaw the carb and let it run normally. If it's vapor lock, then shutting the engine off and letting it cool down should make it run well again.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #3 of 7 Old 01-12-2011, 04:29 AM Thread Starter
I don't have much history on the machine prior to the DJ kit. Bought the Bayou, went on one ride with no problems, then put in the DJ kit.
I am beginning to lean towards a stuck float valve. Once fully sealed off, the warm tank is allowing the fuel to expand.
Went out for a night ride last night and it died 4 times. It only happens when hitting some rough bumps under heavy power. I think what is happening is after being under full throttle for a bit, the level in the bowl drops a bit (as much as it possibly could under full throttle) and when hitting a big bump allows the float valve to get stuck.
When it does die, I remove the fuel line from the tank, fire it up, after it starts to lean out and cough, suddenly all is back to normal.
If I ride easy through woop sections - it runs all night.
After some searching online, it appears that Bayou 300's are notorious for having carb issues. The popular fix seems to be replacing the carb with some no brand name copy of a Honda TRX card available on ebay for $130. Many post claim this cures all Bayou problems. I just don't want to throw money at it only to find it was some vapor lock or something else.
I plan on putting the stock jetting back in today. Also, for kicks, coat the bottom of the tank with heat tape. If there is a way to make and fit a heat shield between the tank and motor, that will be done.
If it happens after that, ebay carb will be next.
mpj220 is offline
post #4 of 7 Old 01-12-2011, 07:41 AM
hddi11's Avatar
I am using the trx carb, the only thing is you may have to drill out the carb body JUST A LITTLE where the throttle cable goes in the carb. cranks 99% of the time without choke, but i do have the choke cable attached!!!!
hddi11 is offline
post #5 of 7 Old 01-12-2011, 02:33 PM
NovaKaw650's Avatar
Garage
Pretty much answered the question right there.
You may have damaged the float while the carb was apart.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #6 of 7 Old 01-13-2011, 04:24 AM Thread Starter
It has been apart and inspected numerous times.
And, yes, I am VERY experienced with carburetors.
Carb will come back out today, be disassembled, put in a carb bath for a good 4 hours, re-assemble with stock jetting and test after.
It could be as simple as a vapor lock being caused by the extra heat due to the dynojet kit. The stock main jet was a #125, the DJ kit uses a #110. After installing the DJ kit, the machine felt lean (to me) in the low end of the midrange. It was misfiring alot and throttle response was very flat. I contacted dynojet just to see if they had any notes on this - hoping to save time taking the carb out more than once. The tech there insisted that it was running rich and that I should raise the clip one notch. I did so and the machine ran worse. I then dropped the needle one notch below the recommended and it runs fine other than this strange problem.
I have read that these carbs can develop a problem in the float valve seat that causes the valve to stick. Some have used burnishing compound to clean the seat. I will inspect the seat with a magnifying glass.
mpj220 is offline
post #7 of 7 Old 01-13-2011, 12:19 PM
NovaKaw650's Avatar
Garage
Again, it worked before the DJ kit, and doesn't now.
I know where I would be looking.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
01 bayou 300 runs bad at half throttle
1995 kawasaki bayou 300 4x4 carburetor adjustment
94 kawaski bayou 300 carb kit problem with float valve not seating
bayou 300 dies out when riding
bayou 300 dies when hot
how do you know if i choke cable is bad on kawasaki bayou
issues with kawasaki bayou 300 4x4s
kawasaki 300 bayou cutting out above half throttle
kawasaki bayou 300 idle issues
kawasaki bayou 300 problems
kawasaki bayou loading up at full throttle
kawasaki prairie 300 only runs until half throttle
why does kawasaki 300 prairie vapor lock
Bayou starting problem scruffy19 Kawasaki Brute Force/Prairie/Bayou 2 12-31-2010 04:41 PM
Bayou 300 4x4 bad problem... willyt Kawasaki Brute Force/Prairie/Bayou 1 12-01-2010 10:27 PM
Bayou 220 problem 1SlowSVT Kawasaki Brute Force/Prairie/Bayou 4 03-05-2010 05:39 AM
bayou carb problem 05fcpbrute Kawasaki Brute Force/Prairie/Bayou 2 01-23-2010 11:43 AM
Bayou 220 problem GoonGrinch Kawasaki Brute Force/Prairie/Bayou 4 04-06-2003 10:31 PM
