How Important is Valve Adjustment? - Kawasaki ATV Forum
post #1 of 22 Old 01-24-2011, 09:12 AM Thread Starter
I have an 08 Brute 750 with about 1500 miles. Runs great. How do I know if I need the valves adjusted? They have never been done and I'll have to take it in which will likely cost a lot of money. Hate to spend the money only to find out they were fine.
MinnKawi is offline
post #2 of 22 Old 01-24-2011, 09:19 AM
Feedback Score: 4 reviews
Mikeyboy_esq's Avatar
Its free if you learn to do it yourself. Its a bit of a pain to get to the valves, but its very doable by the average do-it-yourselfer/shade-tree mechanic. All you really need is some feeler gauges (bent at 45 degree angle works best) and a few basic tools. It would be a good idea to buy a Service Manual for your quad before attempting to do this.
As far as symptoms, the motor usually gets hard to start when the valves are out of spec. I usually adjust my valves about once a year (if I ride regularly).
Happy trails...
2007 KFX 730 (sold)
2004 Twin Peaks 800 (sold)
2003 Prairie 650 (parted out)
2002 Prairie 650 (parted out)
Happy trails...
Mikeyboy_esq is offline
post #3 of 22 Old 01-24-2011, 10:28 AM
ForceTA308's Avatar
Another symptom is a ting-ing sound coming from your top end
04 KFX700
04 KFX700
04 TRX450R
04 TRX450R
ForceTA308 is offline
post #4 of 22 Old 01-24-2011, 10:28 AM
redlined's Avatar
Happy trails...
+1. To add to those comments, valves get tight over time.....as the old saying goes....."slappy valves are happy valves". Don't neglect them!!
2009 Brute Force 750
Team Green
26" ITP XTR'S
HMF Swamp Series Slip-On
Moose Heated Grips
Zerk Mod
RT 25 Warn Winch
Amsoil Everywhere
Moose luggage
Super ATV 2" lift
Super ATV 1" Wheel Spacers
Garmin E-Trex GPS
2008 KFX90
Team Green
PowerMadd Handguards
Halogen running light
Modified exhaust
Lots of smiles and hugs from my 7yo
redlined is offline
post #5 of 22 Old 01-24-2011, 11:33 AM
dogwood's Avatar
I have 5000km on my prairie 700 and have never done a valve job, starts right up and i hear no ticking. Once a year for a valve job seems excessive to other poster?
dogwood is offline
post #6 of 22 Old 01-24-2011, 11:34 AM
When u do the valves were do u put the feeler guage and r the valve relaxed and should there be slack in the rocker arms i guess u call them
jakeharrington95 is offline
post #7 of 22 Old 01-24-2011, 12:50 PM
I could be wrong, but I thought the owner's manual recommends valve jobs about once every 100 hours or once per year, something like that. To be safe, I usually do it once a year (if I ride often). Its really not hard to do and is not a big deal at all after you've done it once.
As far as how to do the valve adjustment, I loosen the locking nut on the rocker arm and loosen the set screw. Then I slide the appropriate size feeler gauge between the rocker arm and the top of the valve. Then I tighten down on the set-screw until I feel some resistance while sliding the feeler gauge back and forth. Once its at the correct setting, I tighten the lock nut. Repeat for the other 3 valves...then double check all 4 again.
The KEY to remember is the cylinder that you are adjusting must be positioned at TDC. So you will need to remove the cover over the flywheel to find the TDC marks for the front and rear cylinders and make sure you turn the crank over to the correct TDC mark before you do any vavle adjustments....then turn the crank over again to do the valve adjustments for the other cylinder.
Good luck and happy trails...
2007 KFX 730 (sold)
Happy trails...
post #8 of 22 Old 01-24-2011, 01:34 PM
Feedback Score: 15 reviews
RobCatV's Avatar
Some good pics
How to: Adjust Valves
RobCatV is offline
post #9 of 22 Old 01-24-2011, 02:39 PM
Feedback Score: 8 reviews
asnowmobiler's Avatar
Quote:
Not really.
The valves tend to get tighter on these engines,making them harder to start,even harder when warmed up.
Officiallywas one of the fastest Prairies in the world
Team Green 04 V-Prairie, Ported AMR 730,XX cams,Digatron gauges,VFJ custom clutch with EBC bearing removed,V-force gears,AMR ported intakes,programmable Dyna,30 shot of Boon,Brute Force Flywheel,stock carbs,stock exhaust,Flexx bars,Rox Risers,ODI grips,Tusk Dozer plow,ECT.
AMR 330 347 6800
2013 BMW K1600GT
2015 BMW R1200 GS Adventure.
asnowmobiler is offline
post #10 of 22 Old 01-24-2011, 02:40 PM
Feedback Score: 40 reviews
PIPO's Avatar
A valve job and valves adjustment are 2 different things....at least in my book.
PINARELLO DOGMA 60.1/CAMPAGNOLO RECORD 11
CANNONDALE SUPERSIX EVO HI-MOD/DURAACE 11
PIPO is offline
2007 kawasaki kfx 90 valve adjustment specs
2008 kfx 450r valve adjustment kit
atv do i need a valve adjustment
atv valve adjustment how critical is it
how much does it costs to get valves adjusted on atv brute force 750 kawasaki atv
importance of making valve adjustment
is it important to adjust valves on brute force
kfx 700 valve adjustment
out of adjusment value atv
symptoms of bent valves on ltr450
trx450r valve adjustment how often
why valve clearance is important
why would you need an atv valves adjusted
Valve adjustment?? JMcClure Kawasaki Brute Force/Prairie/Bayou 3 08-17-2009 09:49 PM
valve adjustment ?? vtprairie03 Kawasaki KFX700 V-Force 1 07-01-2008 07:15 PM
Valve adjustment Cosmo Kawasaki KFX700 V-Force 17 02-01-2008 07:52 PM
valve adjustment. lonerezzie Kawasaki KFX700 V-Force 7 07-18-2005 10:29 AM
Valve adjustment on a 785 bb razzergreen Kawasaki Brute Force/Prairie/Bayou 2 06-28-2005 06:33 AM
