360 Prairie Hard starting - Kawasaki ATV Forum
post #1 of 9 Old 02-03-2011, 07:04 PM Thread Starter
I have a 05?, 06? 360 Prairie that you can run the battery down trying to start, but pull the rope one time and it starts right up. Once started takes a while before it will idle without the choke being on at least a little. It seems to idle up on it own from time to time too. Once its warm other than the idle issue, it seems to run fine.
Any advice would be greatly appreciated.
Thanks,
dodgewade is offline
post #2 of 9 Old 02-04-2011, 05:56 AM
hddi11's Avatar
Wink
clean the carb!! Here is some info from nuther sites that may be helpfful!!!!!!!
hddi11 is offline
post #3 of 9 Old 02-05-2011, 06:58 AM
You might want to check and adjust your exhaust valves. My 360 was difficult to start, took forever to idle without choke and after I would get it to run without choke, it would stall after returning to idle after running it wide open. It darted to backfire alot as well. My valve clearance was zero. I had the Carb rebuilt at the same time but mechanic said Carb looked good before the rebuild.
wingman72 is offline
post #4 of 9 Old 02-05-2011, 08:13 AM
I agree with wingman72. Try adjusting your valves. Mine is doing the exact same thing and Iv tried everything else.
wistler1 is offline
post #5 of 9 Old 02-05-2011, 03:14 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Quote:
The valves go tight on the 360's for some reason, and you lose compression. A very common problem.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #6 of 9 Old 02-05-2011, 03:59 PM Thread Starter
Thanks, I have an 08 I bought new and it is starting to do about the same. Guess I need to spend a w/e working on stuff when the weather warms a little.
post #7 of 9 Old 02-06-2011, 05:16 AM
ALDO's Avatar
This bikes have this problem, i live here in the tropic and have some little problems to start it in the morning, thats a normal issue of this big machine, but when it warms all is ok. This thread is similar :
Hard Starting Prairie 400
ALDO is offline
post #8 of 9 Old 02-06-2011, 01:49 PM
Hard starting 360
Same problem with my '09 still under warranty. The manufacturer should have known this for a long while and may have suggested answers. Has anyone received advice from a Kawasaki mechanic?
larrydiamant is offline
post #9 of 9 Old 02-06-2011, 01:57 PM
Hard starting 360
03 kawasaki prairie 360 hard to start
2010 kawisaki 360 atv hard starting
360 prairie hard to start when cold
360 prairie pull rope without battery
atv kawasaki prairie hard starting
how to pull start a kawasaki prarie atv
how to start a kawasaki prairie
kawasaki 360 hard to start
kawasaki prairie 360 hard starting
kawasaki prairie 360 will not start
prairie 360 compression
Hard Starting Prairie 400 Part 2 dirtdemon Kawasaki Brute Force/Prairie/Bayou 5 08-01-2011 06:51 PM
Hard Starting Prairie 400 dirtdemon Kawasaki Brute Force/Prairie/Bayou 8 01-10-2011 06:25 PM
hard & erractic starting 650 prairie mainer Kawasaki Brute Force/Prairie/Bayou 2 06-08-2009 12:00 PM
very hard starting big d Kawasaki KFX700 V-Force 10 07-21-2008 06:34 PM
hard starting?? Tobys 2 strokes Kawasaki Tecate 7 06-03-2007 09:49 PM
