1994 kawasaki 220 bayou pilot screw setting - Kawasaki ATV Forum
post #1 of 4 Old 02-24-2011, 12:07 PM Thread Starter
i need the starting turns for a 1994 kawasaki 220 bayou pilot screw. i took carb apart to clearn, did the "turn in" on pilot screw, was 1-1/2 turns. the manual for my 1985 kaw 185 bayou says 1 turn for it. carbs are similar but not same. i want to make sure. can anyone help? thanks! ps... it can be close in years mfg'd
unclebucks2000 is offline
post #2 of 4 Old 02-24-2011, 05:04 PM
The book says 1.5 turns except California models, 2.5 turns...Hope this helps..
What size was your main-jet? Mine has a 117.5 Dealer says it should be 122.5 for sea-level..I bought a 2002 Bayou "set up for high altitude" and it has a 110 main-jet in it. Trying to sort it out...
Bayou Two is offline
post #3 of 4 Old 03-01-2011, 12:56 PM Thread Starter
hey thanks, but my hanes book, which i got from the library says 1.2 turns for 88-99 220's. 2000 and later and all 250's is 1.3, so im waiting for the clymer manual to come in to double check. my main is a 115, book says 115 for all 88 thru 99, 2000 on california. then it says 117.5 for 2000 on except california. makes no mention of high altitude. so it looks conflicting...
post #4 of 4 Old 03-01-2011, 02:34 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Open the pilot screw until the engine begins to idle rougher. Now close it until it does the same. Set the screw between these two positions.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
1993 kawasaki bayou 220 needle jet screw adjustment
1994 bayou klf-300 poilt screww setting
1999 kawasaki bayou 220 carburetor adjustment
88kawasaki 220 how to adjust carb
95 kawasaki bayou pilot jet what does it do
bayou 220 carb pilot adjustment
bayou 220 carb settings
carb seting on 185 bsyou
default settings on carburetor kawasaki 300
how to adjust jet screws on 1994 kawasaki bayou 220
kawasaki 220 bayou carb settings
kawasaki bayou 220 carburetor settings
Factory Air Screw Setting c6quad Kawasaki Brute Force/Prairie/Bayou 4 02-15-2011 10:02 AM
pilot needle setting 01 prairie korther Kawasaki Brute Force/Prairie/Bayou 0 10-24-2010 10:22 AM
1994 Bayou, can I still get parts? Dave_In_Florida Kawasaki Brute Force/Prairie/Bayou 4 09-10-2010 11:51 PM
Kawasaki Bayou 300 1994 pwain Kawasaki Brute Force/Prairie/Bayou 0 09-21-2009 07:09 PM
1994 Bayou with no spark please help bayou400 Kawasaki Brute Force/Prairie/Bayou 6 07-19-2008 06:48 AM
