front brake problem! - Kawasaki ATV Forum
post #1 of 10 Old 03-22-2011, 08:22 AM Thread Starter
Feedback Score: 1 reviews
kevinryan7's Avatar
So I spent all night last night troubleshooting my front brake issue....or, lack of brakes. Absolutely no pressure building up in the handle. Fluid is squirting out of the bleeder valves like they should. Fluid level is not going down in the master cylinder so I know it's not leaking out anywhere. No holes or kinks at all in the lines but still won't build any pressure? Kind of has me stumped and confused........any suggestions?
kevinryan7 is offline
post #2 of 10 Old 03-22-2011, 08:24 AM
Feedback Score: 9 reviews
hndlbarmonkey's Avatar
there is air trapped in the lines, trust me
Take the reservoir cover off and pump the brakes, you will probably see tiny bubbles coming up
Home of the proven fastest and quickest all motor Kawies in the world
Quote:
Originally Posted by Dynoray View Post
Quote:
Originally Posted by hndlbarmonkey View Post
It says race because it was 12.6:1, instead of 11:1
lol, so going from 11:1 to 12.6:1 is building a race motor to you
LOL, back in 04-05, pretty much, LOL
AMR 840 trail bike
Fundy 800 race motored trail bike<wifes
Fundy 800 drag bike
It's nice when you get to a point, where you don't give a shit anymore
hndlbarmonkey is offline
post #3 of 10 Old 03-22-2011, 08:57 AM Thread Starter
kevinryan7's Avatar
At first I did pump it with res cover off and a lot of air bubbles came out....consistently. Now, no air bubbles and when I checked it again with the cover off after I bled the lines it was wanting to splash out like it's supposed to. But yes, there was a lot of air in the lines at first. That's why I'm kind of stumped now
post #4 of 10 Old 03-22-2011, 09:01 AM
Still a bubble trapped somewhere, I went through this when I put my braided lines on, a vacuum bleeder helps alot, also try lifting the front of the bike up or one side then the other while pumping the brakes.
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #5 of 10 Old 03-22-2011, 09:57 AM Thread Starter
kevinryan7's Avatar
Never used a vaccum bleeder before.....they got those at Auto Zone or Advanced? Guess I could give that a shot cause I've tried every other way I know to bleed them.....even tilting the bike while pumping, still nothing.
post #6 of 10 Old 03-22-2011, 06:24 PM Thread Starter
kevinryan7's Avatar
So I pulled the master cylinder and hooked a hose to the bottom of it, filled the cylinder with fluid, closed it up, squeezed the handle and fluid did not come squirting out like I had hoped. This leads me to believe I have to rebuild the master cylinder.....does this sound right?
post #7 of 10 Old 03-23-2011, 12:03 AM
Feedback Score: 21 reviews
Camo's Avatar
Could be by-passing internally but definitely not a common problem.
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
Torque is quick... Horsepower is fast
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim / VFJ Clutch Weights & Springs
YOU DESERVE A HIGH FIVE... IN THE FACE... WITH A CHAIR
Camo is offline
post #8 of 10 Old 03-23-2011, 10:53 AM Thread Starter
kevinryan7's Avatar
Sorry if I don't understand, but what do you mean by bypassing internally? After I bench bled the master cylinder and was getting no juice I took it apart and there was no obvious reason why it wouldn't work. Everything was in great shape, nothing broken/pitted/corroded/scratched up, spring was still good.......this is really starting to get to me now. I have yet to find a reason why the front brakes won't work!!!! I am open to try any and all suggestions to get this resolved.
post #9 of 10 Old 04-12-2011, 08:28 PM
I am having the SAME EXACT problem. Can u tell what u did to fox the problem? I bought a brake bleeder form autozone for $40 and still nothing...I can not get thye fluid from the master cylinder to push any fluid
Fontenot41 is offline
post #10 of 10 Old 07-10-2012, 06:12 AM
Did you ever figure it out? I'm having the same problem with my 86 300 Bayou. The brakes were great and suddenly nothing. I figured I blew a line but when I checked it the next day the reservoir was full and there were no leaks anywhere. I'm having the same problem when I try to bleed the brakes. I was just about to buy a master cylinder but now I'm thinking it might still be air in the lines.
bvolks is offline
2005 brute force front brake master cylender locking up
2010 brute force front brakes wont work
2012 brute force 750 master cylinder prime
atv brakes wont build pressure
atv front brakes no pressure
fromt brakes sticking 2011 kawasaki teryx
front brakes on kawasaki bayou 300
front brakes wont release on kawasaki gpx900
how do u prime the brakes on a kawasaki 4 wheeler
howq to tell if four wheeler master sylinder is bad
ive bled my brakes on my atv but it still wont apply brakes
kawasaki teryx brake problems
why brakes are not working in four wheeler
engine brake problem bruteforce65006 Kawasaki Brute Force/Prairie/Bayou 5 11-17-2010 07:30 AM
Rear brake problem Scott_T Kawasaki Mojave/Lakota 11 10-28-2010 09:28 AM
mojave rear brake problem wheelyking Kawasaki Mojave/Lakota 6 05-19-2010 10:43 PM
Rear brake problem samvel1981 Kawasaki KFX700 V-Force 13 11-25-2009 12:24 PM
Weird Brake Problem? SlvrBrute Kawasaki Brute Force/Prairie/Bayou 11 09-22-2008 01:56 PM
