Old 03-30-2011, 09:24 PM   #1
Feedback Score: 3 reviews
Mikeyboy_esq's Avatar
View Mikeyboy_esq's Photo Gallery(13)
Question Help...radiator fan won't kick on when engine is hot
I'm trying to figure out why my twin peaks' radiator fan won't kick on when the motor gets hot (the overheat light came on last Saturday during a trail ride, so I know something is wrong).
So far, here is what I've checked.
1) Fuse is good (was a little corroded, but I cleaned up the connection and the fan still does not come on when the engine warms up).
2) Fan works when I directly run 12v to it.
Given that the fuse and fan appear to be good, the only possible cause I can think of is the radiator overheat sensor. Do you guys agree, or is there another possible cause that I'm forgetting?
2007 KFX 730
2004 Twin Peaks 700 (sold)
2003 Prairie 650 (parted out)
2002 Prairie 650 (parted out)
Happy trails...
Mikeyboy_esq is online now   Reply With Quote
Old 03-30-2011, 09:25 PM   #2
Feedback Score: 75 reviews
DoubleTapXX's Avatar
View DoubleTapXX's Photo Gallery(0)
Default
Most likely the sensor in the radiator.
A 4.0 Fu#*ing Liter straight 6, A box full of hollow points and lord willing a GD Twinkie. Gotta enjoy the little things!
2k8 700xX
2k3 400ex {Wifes}
2k4 V-Force(SOLD)
2k8 730 V-Force(SOLD)
2k4 V-Force Roller (SOLD)
DoubleTapXX is offline   Reply With Quote
Old 03-30-2011, 09:33 PM   #3
Feedback Score: 9 reviews
kawboy1's Avatar
View kawboy1's Photo Gallery(0)
Default
Mikey the sra's have some sort of reset thing that you push with something like a pencil.......up under the seat where all the electrics are IDK if the Prairies/Twin Peaks have it too ?
LOONEY TUNED FST 765
LOONEY TUNED KFX450R
My You Tube videos http://www.youtube.com/user/michealmannion?
feature=mhum
kawboy1 is offline   Reply With Quote
Old 03-30-2011, 09:42 PM   #4
Default
KFXhellrzr,
That is my guess too. It looks like p/n 27010-1202: SWITCH,FAN for 2004 KAWASAKI Prairie 700
Kawboy1,
Thanks for the suggestion. I might be wrong, but I think you are talking about the Brute Forces which have some kind of breaker box (which can be reset) instead of a fuse box. My twin peaks has a fuse box.
Happy trails...
2007 KFX 730
Happy trails...
Old 03-30-2011, 09:48 PM   #5
kawboy1's Avatar
Default
Yes thats right the breaker is right opposite the fuse block under the seat and pretty sure there is a fuse as well......I didn't know if the twin peaks was the same setup?
feature=mhum
Old 03-31-2011, 04:02 AM   #6
Shumate650's Avatar
View Shumate650's Photo Gallery(0)
Default
Let us know if the temperature sensor was the culprit.
2008 Brute Force SRA
VFJ Stage 3 clutch, spidermod, KEBC removed, maroon primary and VFJ #4 secondary springs, Dynatek, spark plug boot mod, Crossover intakes, polished slides, shimmed needles, #42 pilots, #140 mains, Napa hose mod, No Toil Super Flow kit, Elka front spring kit, EPI rear spring, Fly handlebars, Rox risers and dash, ODI grips, Streamline steering stabilizer, PRM grab bar, aluminum skids, Renegade footpegs, Black Rock wheels, Maxxis All traks
Shumate650 is offline   Reply With Quote
Old 03-31-2011, 04:03 AM   #7
Default
I am betting so. Last person I told on this same problem bought a new fan along with some other stuff they didnt need. Temp sensor is it more than likely.
2k8 700xX
2k3 400ex {Wifes}
2k4 V-Force(SOLD)
Old 03-31-2011, 04:08 AM   #8
Shumate650's Avatar
Default
I agree with you. My brother in law wanted me to put a new fan on his 750, but after I ran a test wire directly to the fan, it worked fine. I had him take it back and get a temp sensor. It fixed it right up.
Old 03-31-2011, 06:02 AM   #9
Default
Ok. Thanks for the advice guys. I just ordered that sensor in the radiator and will report back later (after I get it installed) to let everyone know if that solved my problem.
Thanks again!
2007 KFX 730
Happy trails...
Old 04-17-2011, 06:19 AM   #10
Default
Good news! I replaced the radiator temp sensor switch (this part screws into the side of the radiator) and that fixed my problem. I took my twin peaks for a 31 mile ride on Friday at the Sam Hou. Nat'l Forest and it ran great with no overheating problems. The fan kicks on and off like normal.
Thanks again for everyone's advice above.
Happy trails...
2007 KFX 730
Happy trails...
04 kfx 700 cooling fan dont work
2004 kfx 700 fans wont turn on
700 v force fanmotor
arctic cat 400 cooling fan problem
brute force overheating and fan wont kick on
kawasaki mule radiator fan
kawasaki prairie 400 cooling fan
kawasaki prairie 400 overheating
kawasaki prairie 700 motor runs hot
kfx 700 fan wont come on
prairie 700 running hot fan doesnt come on
radeater fan kawasaki 700
radiator fan wont kick in
You may not post new threads
You may not post replies
Looking for Mojave Kick start gears or bottom engine... also looking for a muffler!! CoryDavis Wanted 1 07-19-2010 06:18 PM
What automobile RADIATOR CAP is comparable to the Prairie's radiator cap? Mikeyboy_esq Kawasaki Brute Force/Prairie/Bayou 8 05-28-2010 04:23 AM
kick in the nuts kfxmatt Club Kawie 2 12-05-2009 04:48 AM
I need to kick my own ass.. asnowmobiler Kawasaki KFX700 V-Force 42 10-07-2009 02:20 PM
Fan will not kick in on BF 750 ProXJC Kawasaki Brute Force/Prairie/Bayou 12 08-14-2009 12:19 PM
