Is this clutch wear normal?? - Kawasaki ATV Forum
post #1 of 10 Old 04-02-2011, 09:42 PM Thread Starter
digger2's Avatar
So this is the first time I've had the CVT cover off the Brute. I wanted to check deflection and got 1.34"?? Spec is .866"-1.063". New Belt width 1.19" new and 1.17" original take off belt when measured with caliper and 2 straight edges. Virtually no difference between new and used, maybe the uses is stretched a little causing deflection?? They are both Kawi belts too. The quad has about 750 miles on it, but is used a lot in Low range blowing snow in winter. I removed the clutch tonight and found what looks to be like grove mark were the belt sits near the bottom of the clutch. Is this normal or has the belt grooved the sheaves from using it a lot at walking speed moving snow?? I tried to take some photos but the camera kinda sucks. Let me know what you think??
digger2 is offline
post #2 of 10 Old 04-03-2011, 05:09 AM
Feedback Score: 1 reviews
I beleive it is the KEBC that causes this wear, it keeps pressure on the clutch at low speeds.
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #3 of 10 Old 04-03-2011, 05:14 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
The wear is normal.
I hope you always use low range when plowing and going slow.
Make sure the belt is all the way to the top of the secondary clutch sheaves before measuring the deflection. With the trans in neutral and the belt installed, spin the secondary clutch at least 10-15 revolutions. It sometimes takes that long for the sheaves to fully close on the belt. The belt should end up 1/8-1/4 of an inch above the top of the sheaves if the deflection is good.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #4 of 10 Old 04-03-2011, 06:58 AM Thread Starter
digger2's Avatar
Thanks for the replies fellas, I always use low range when blowing snow. I didn't rotate the drive the recommended amount 10-15 times maybe that's why the deflection is off?? I'm pretty sure the belt was level with top of secondary clutch, which I have read now is incorrect.The bike has started "bumping" just as I take off in high range (not when I mash the throttle just easy acceleration) . So I didn't know if this was normal and maybe the clutch was causing it. Here's a pic of what the Brute did all winter.
digger2 is offline
post #5 of 10 Old 04-03-2011, 07:42 AM
NovaKaw650's Avatar
Garage
Ouch! I didn't realize you were using a blower instead of plowing. That slow crawling speed will really heat up the clutch and wear the belt.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #6 of 10 Old 04-03-2011, 12:19 PM Thread Starter
digger2's Avatar
So I went back out to the garage and put the new belt into the secondary clutch and basically sat flush to the top as well. I guess they put in alot of shims from factory?? Will have to pull the secondary and see whats up. I am considering doing a VFJ stage 3 on my clutch, but didn't know if it's worth it on a mainly stock quad. I know they work great on Modded bike but for a stocker don't know if it's worth the $$. Still sitting on the fence for this one. Ahhhhh decisions...............
digger2 is offline
post #7 of 10 Old 04-03-2011, 12:37 PM
NovaKaw650's Avatar
Garage
Quote:
Typically, no they don't.
John's mod is well worth doing to a stock machine, but MAKE SURE you tell him that you use a snow blower. It could be a cause for concern.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #8 of 10 Old 04-03-2011, 12:47 PM
If it were me and my belt was still within spec, I would just re-shim the secondary. Shims are not expensive and it's pretty easy to do if you have the tools and follow the service manual.
2007 750 Camo Brute, 27" Mudlite XTR's/ Black 14" SS108's, 1" spacers, Diamond G Tie Rods, Gibson Steering Stabilizer, Elka's, Richochet skids, Snorkels, Dyna FS CDI, Twin Air, Full Muzzy, Gaffrig Wtr.- Prf. Temp Gauge, Ext. Oil Cooler w/braided lines, VFJ primary mod., XT 25 Warn.
spinnin2win is offline
post #9 of 10 Old 04-03-2011, 01:25 PM
NovaKaw650's Avatar
Garage
Quote:
If you want to "tighten" the belt, then you remove shims, not add them.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #10 of 10 Old 04-04-2011, 04:13 AM
NovaKaw650...You're correct in saying "if you want to tighten the belt, then you remove shims, not add them". However, by removing one, you may not achieve the desired deflection, e.g. mine had a .024 and .039 in it for a total of .063. To achieve the proper deflection I needed to be at .051 which isn't achievable by removing one of the two shims that were in it. It was achievable by purchasing a .012 shim (Part#92026-0034).
The service manual shows a total of 6 shims available, they are .012, .024, .032, .039 and .055.
atv worn clutch sheaves
brute force clutch wear
brute force worn clutch
groove in primary clutch bruteforce 650
how do atv clutches wear out
how do you know if a 650 prairie cluch is worn
kawasaki brute force belt deflection
kawasaki clutch wear
kawasaki secondary clutch wear
machining grooves out of brute force clutch
wear marks on atv clutch
worn atv clutch
worn clutch sheave
Clutch question: Is this normal? tgunn1 Kawasaki Brute Force/Prairie/Bayou 8 02-14-2011 04:36 PM
Primary Clutch Pic - Does this look normal? XTWalt Kawasaki Brute Force/Prairie/Bayou 1 02-17-2010 06:27 PM
do you wear a helmet? KSMITH Club Kawie 20 06-18-2007 09:34 PM
EXCESSIVE CLUTCH WEAR? Steve-o- Kawasaki Brute Force/Prairie/Bayou 3 02-01-2005 05:59 PM
some sprocket wear? ky babyn Kawasaki Mojave/Lakota 2 09-20-2004 10:29 PM
