Skyblaster your belt is not loose, it's a little tight. When new with perfect deflection they should squeel a little in gear. Set up like this is key to the proper performance for a stock brute. When the belt squeels just pop it into neutral. Trust us it's not loose, the squeeling will lessen as the belt breaks in. YOU RAN A KAWASAKI BELT I HOPE, DO NOT USE ANYTHING ELSE THEY DON'T LAST. If your belt is loose the quad will be really doggy, poor response.
