My 2006 Bayou bogs down if I give it any gas. I've cleaned the carb (3 times) and flushed the gas tank, installed a fuel filter. The bike will run that afternoon but the next day it will only idle and then bogs down if I give it any gas. Any thoughts?
Check ur gas cap, my sons polaris had a similar issue. Check for clogged vent hose if it has one.. Loosen the cap then give it throttle and see what it does.. good luck on the fix
is the battery good/fully charged bayou wont run with a good battery their charging system requires a good battery to run
Related Threads
Kawasaki ATV Forum
971.2K posts
52.3K members
Since 2002
