Coolant leak! - Kawasaki ATV Forum
post #1 of 8 Old 05-19-2011, 10:40 AM Thread Starter
greenskullrida's Avatar
Coolant leak!
Hey fellas, i got a problem. This morning got up and decided to take my baby out for a cool ride. Nothing serious just aroung the block and about 2 miles to my dad's house. Got her back to the house and noticed that my SRA was leaking coolant from under the reserve tank. Has anyone had this problem, if so what can you do to fix it besides taking it in for service. What could have caused this?
2008 BF650sra (Team Green)
2" lift
28x10/28x12 Mudzilla's
2.0" wheel spacers
SS108's
K&N air filter
Snorked
Airbox Mod
MUZZY full exhaust
DynoJet Kit
PowerMadd Handguards
Dynatek CDI
Lethal Threat/Muzzy decals
greenskullrida is offline
post #2 of 8 Old 05-19-2011, 01:06 PM
Shumate650's Avatar
Is it coming from the coolant tank itself or from the tube on the bottom of the motor? If it is coming from the tube with the plastic bulb on it , then I believe that it means that the water pump seal is leaking. Im not totally sure on this though.
2008 Brute Force SRA
VFJ Stage 3 clutch, EPI pink primary and VFJ #4 secondary springs, Dynatek, spark plug boot mod, Crossover intakes, polished slides, shimmed needles, #42 pilots, #140 mains, TRP water pump, Faria temp gauge, Napa hose mod, Twin Air power flow kit, Elka front spring kit, Elka Stage 3 rear, Fasst Flex handlebars, Rox risers and dash, ODI grips, Streamline steering stabilizer, PRM grab bar, aluminum skids, Renegade footpegs, Black Rock wheels, Kenda Bear Claw HTR's
Shumate650 is offline
post #3 of 8 Old 05-19-2011, 01:10 PM
Shumate650's Avatar
I removed my overflow tank to flush the cooling system the other day and noticed that the factory had a hose clamp turned the wrong way and it was rubbing against the tank. I moved the clamp to a different position. You may want to remove your tank and make sure nothing is rubbing against it and to check for holes. It is very easy to remove, 2 phillips head screws.
post #4 of 8 Old 05-19-2011, 01:27 PM Thread Starter
Im not sure shumate650 but it doesnt leak unless the bike is running and its leaking from the bottom right near that tube so ill take it off and check. I knew i could count on you Shumate650. I let you know what i find when i get it off. I probably wont take if off until in the morning because im going to my sons graduation tonight. Thanks man.
2" lift
2.0" wheel spacers
SS108's
K&N air filter
Snorked
Airbox Mod
MUZZY full exhaust
DynoJet Kit
Dynatek CDI
post #5 of 8 Old 05-19-2011, 02:22 PM
Shumate650's Avatar
You may get lucky and it might just be a loose clamp?? I noticed that the ones Kawi used down on the water pump seem to be very cheap. I actually replaced it with a better one. Good luck!! Enjoy your sons graduation!!
post #6 of 8 Old 05-20-2011, 05:58 AM
djmjt's Avatar
I had that happen on mine the other day. Ended up being that I put too much coolant in the over flow tank and it was pushing it out when it got up to temp. It got worse after I shut it off but stopped when it pushed out enough. That was a dumb ass move on my part though
Dan
2012 Brute Force 750i EPS
25" Kenda Executioners
More mod's to come!
Blowed up the 08
08 BF 750i NRA Camo
25" Swamp Lites
K&N Filter
DynaRay's Ultimate Impeller
MIMB Coolant Temp Gauge
More Mod's Coming Soon!!!
djmjt is offline
post #7 of 8 Old 05-20-2011, 06:27 AM Thread Starter
Ok i got the tank off and there is this little bulb lookin thing under the water pump that has the word "UP" on it. It has a little hose on the end of it and the coolant is leaking from that little hose. WTF is that, why is it leaking and what do i do to fix it.
2" lift
2.0" wheel spacers
SS108's
K&N air filter
Snorked
Airbox Mod
MUZZY full exhaust
DynoJet Kit
Dynatek CDI
post #8 of 8 Old 05-20-2011, 11:43 AM
Feedback Score: 21 reviews
Camo's Avatar
You need to buy a waterpump ceramic gasket and a sidecover gasket. Remove the entire left side cover and replace the seal on the inside of that. The waterpump and impeller have to come off before the sidecover, but the seal is inside the cover.
OrangeCrush RR
Boosted / Nitrous Injected Duner
Fundy Performance Sports 1-902-893-(DYNO) 3966
Torque is quick... Horsepower is fast
1) Bench Racers
2) Racers who never actually run into the Big Dog
4) The Big Dog
CUSTOM FABRICATED TURBO EXHAUST / JH MACHINE CUSTOM ROLLER CLUTCH - Godspeed Jim / VFJ Clutch Weights & Springs
YOU DESERVE A HIGH FIVE... IN THE FACE... WITH A CHAIR
Camo is offline
06 kawasaki praire water leaking out tube bottom water pump
2006 kawasaki brute force coolant leak
2008 teryx leaking coolant
2010 kawasaki 450 leaking coolant
2015 teryx 4 leaking antifreeze from overflow hose on bottom of motor
atv leaking antifreeze
coolant dripping from left side under the motor on 09 brute force
kawasaki kfx 700 coolant leaking from top of engine
kawasaki prairie 650 coolant leak
kfx 700 overflow bottle leaking
my kawasaki 03 prairie dripping antifreeze from the front what should i do
teryx 750 cc water plug leak
water pump leak kawasaki brute force 300
Changed Starter Gear Now Coolant Leak Gman77 Kawasaki Brute Force/Prairie/Bayou 3 03-02-2010 08:41 AM
Coolant Leak Help! DoubleTapXX Kawasaki KFX700 V-Force 17 06-27-2009 10:45 PM
Coolant Leak Norpaq Kawasaki Brute Force/Prairie/Bayou 0 10-17-2008 10:58 PM
prarie w/ water pump coolant leak need advice wheelie_king Kawasaki Brute Force/Prairie/Bayou 4 09-16-2006 05:44 AM
coolant leak - help V-Raider Kawasaki KFX700 V-Force 6 10-14-2004 03:10 AM
