2010 Kawasaki Brute Force 750i Knocking from left rear axle - Kawasaki ATV Forum
post #1 of 5 Old 05-22-2011, 09:51 AM Thread Starter
I was riding last weekend when i started hearing a real loud knocking noise. I stoped and jumped off to see what was wrong and didnt see anything out of the ordinary. I proceeded to ride to the truck and it didnt make the noise agin. If i turn sharp to the left i can hear a knocking noise in the left rear axle. I took the axle off and cleaned up the inner and outer ball joints and everything looked fine. Anyone have any sugestions? I do have a leak in the rear main but the noise sounds like its from the axle. I would take it to the dealership but i only had a 1 year warrany which went out last month.
Hella4x4 is offline
post #2 of 5 Old 05-22-2011, 09:53 AM
Feedback Score: 23 reviews
T_Dilley's Avatar
More than likely its the joints on the axle
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
T_Dilley is offline
post #3 of 5 Old 05-22-2011, 02:25 PM
Shumate650's Avatar
You said that it makes the noise when turning it to the left, perhaps your rear wheel bearing is going bad?? Not sure what else it could be if you have already ruled out the axle.
2008 Brute Force SRA
VFJ Stage 3 clutch, EPI pink primary and VFJ #4 secondary springs, Dynatek, spark plug boot mod, Crossover intakes, polished slides, shimmed needles, #42 pilots, #140 mains, TRP water pump, Faria temp gauge, Napa hose mod, Twin Air power flow kit, Elka front spring kit, Elka Stage 3 rear, Fasst Flex handlebars, Rox risers and dash, ODI grips, Streamline steering stabilizer, PRM grab bar, aluminum skids, Renegade footpegs, Black Rock wheels, Kenda Bear Claw HTR's
Shumate650 is offline
post #4 of 5 Old 05-24-2011, 01:55 PM
BIG BRUTE FORCE 650 4X4's Avatar
we had to replace a friend of ours boot cuz it was open and tonns of stoff ate away the bearings so replace ur barings
BIG BRUTE FORCE 650 4X4 is offline
post #5 of 5 Old 05-24-2011, 06:03 PM
djmjt's Avatar
Mine did the exact same thing! Loud clunk or knock noise when I turned left but not all the time. My problem though was not what I thought it would be. I to thought it was coming from what sounded like the axle. Check the belt it appeared loose. I took the shims out of the secondary and put in a new belt and clunk was never heard again! It was the old belt slapping the cvt cover but sounded like it was coming from underneath the bike. With the shims out the belt is perfect.
That took care of my knock. Yours could be the cv or something but thought I'd throw that in there! I also had a nut that was loose in the rear diff but that was only the 2008 brute 750's though due to a factory screw up. The darn nut backed out and would've blew the diff if I waited any longer to fix it
Dan
2012 Brute Force 750i EPS
25" Kenda Executioners
More mod's to come!
Blowed up the 08
08 BF 750i NRA Camo
25" Swamp Lites
K&N Filter
DynaRay's Ultimate Impeller
MIMB Coolant Temp Gauge
More Mod's Coming Soon!!!
djmjt is offline
08 750 teryx knock
2011 brute force 750 axles
750 brute force axle 08
brute force 750 left rear axle
brute force 750 rear axle
brute force 750 rear wheel bearing removal
brute force knocking when turn left
can the belt on my kawasaki brute force make a clanking noise
kawasaki brute force 750 knocking
kawasaki brute force axle jump
popping noise coming from rearend of 05 brute force 750
PCIII for Kawasaki Brute Force 750 2008-2010 rednutbow For Sale 5 06-16-2011 06:34 PM
2010 Brute Force 750i - 1st OC (gas in oil)? 2010_KVF Kawasaki Brute Force/Prairie/Bayou 2 05-18-2011 07:24 PM
2010 Brute force 750i Hella4x4 Kawasaki Brute Force/Prairie/Bayou 2 08-16-2010 03:27 PM
WTB Brute force 750i rear axle stonny9 Wanted 0 06-16-2009 05:51 PM
2008 Kawasaki Brute Force 750I shel524 For Sale 2 06-06-2009 06:06 PM
