Bayou 220 carb kit - idles too high - Kawasaki ATV Forum
post #1 of 6 Old 06-14-2011, 06:41 AM Thread Starter
Guys,
I'm second owner of a 2001 Bayou 220 that was an adult ridden ranch utitlty vehicle. Bayou ran fine last summer than started leaking fuel from carb overflow and finally the throttle response dimished to where I decided to clean carb and install a Shindy carb kit.
Got all the new jets etc. installed (but kept the old jet needle as I didn't want to alter the setting and reinstalled carb on bike with the Idle Adj. screw and Pilot Air screw @ 1.5 turns open; cleaned air filter and connected carb to airbox. Bike starts quickly and over revs to 2000 plus rpms.
I checked the throttle cable and it is loose allowing slide to close - I thought it might be holding slide open on a high speed circuit, but it isn't.
Also pulled carb back out and changed the jet needle to the Shindy needle set to the 1st clip position - didn't change the rpms - still over reving.
Next I adjusting the Idle and Pilot Air screws out with no change and finally screwed them both in till seated - no change, bike stills starts quick and runs at fast rpms.
Bike starts quick has good throttle response when the throttle is wacked, it is just idleing too fast. What can I do to get the idle normal before I give up and take it to the shop? All comments are welcome.
BigYoung is offline
post #2 of 6 Old 06-15-2011, 05:48 AM Thread Starter
Anybody?
BigYoung is offline
post #3 of 6 Old 06-22-2011, 01:12 PM Thread Starter
TTT for comment
BigYoung is offline
post #4 of 6 Old 07-13-2011, 03:30 PM Thread Starter
All comments welcome - anyone?
BigYoung is offline
post #5 of 6 Old 01-02-2013, 12:45 PM Thread Starter
Guys,
Got it figured out. I was using an aftermarket Shindy carb kit and installed the Shindy slide needle and left the OEM needle jet in the carb body. This caused the high idle as the Shindy needle has more of a taper which was a looser fit in the jet.
Next, I changed the slide needle back to OEM, but also changed the needle jet out to the Shindy jet. This was an oversize needle in the smaller jet which caused the engine to only idle under choke. It would rev and run WFO but did not idle. This is when I thought to match the needle to the jet and used both Shindy parts. Fourth notch from the bottem caused it to rev as in first paragraph; second notch from bottom had it idleing and runnning WFO. Hope this helps some else.
BigYoung is offline
post #6 of 6 Old 01-02-2013, 03:27 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Quote:
Originally Posted by BigYoung View Post
Guys,
I just read this thread for the first time. You did a good job of troubleshooting!
Now I know why I never use generic carb kits. If you would have bought a new factory needle and seat and a gasket set, you probably would have saved some heartache, lol.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
2000 bayou 220 idles fast with new carb
bayou 220 carb settings
bayou 220 low range
change jets on carb for a 220 kawasaki bayou
choke cable bad idles high bayou 250
install throttle cable mikuni carb for kawasaki bayou 220
installing a new carburetor on kawasaki bayou
kawasaki 220 idles fast with new carb
kawasaki 250 bayou carburetor idels to fast when warm
kawasaki bayou 220 carburetor settings
kawasaki bayou 220 throttle cable
kawasaki prairie 300 idles to fast
pilot jet adjustment on mikuni carb bayou 220
Quad Idles Barely Accelerates kjk240 Kawasaki KFX700 V-Force 2 06-04-2011 07:29 AM
need help with carb problem (high reving when throttle is at idle position etc. wildcatfan0309 Kawasaki Brute Force/Prairie/Bayou 23 01-30-2011 09:04 AM
93 Bayou 4x4 300 high- low range hddi11 Kawasaki Brute Force/Prairie/Bayou 1 12-21-2010 01:26 PM
new guy Bayou 300 carb? kawi Bayou Kawasaki Brute Force/Prairie/Bayou 5 10-13-2010 12:39 PM
Idles, dies under load KFX400 AJOet Kawasaki KFX450/KFX400 6 06-18-2010 09:56 PM
