Adjust Valve Kawasaki Bayou 220 - Kawasaki ATV Forum
post #1 of 4 Old 06-14-2011, 09:57 AM Thread Starter
vladiassis's Avatar
Hi guys.
I have an ATV KAWASAKI Bayou 220 - 2001, and he presents sound off on adjusting the valves. I have the caliber of clearances and have the setting values​​, but I have a question: to make the adjustment the piston must be at PMS? How do I stop the piston in this position? The two valves are closed in this position. Please detail how I do.
Thanks for the help.
vladiassis is offline
post #2 of 4 Old 06-15-2011, 08:40 AM
jordy geiger's Avatar
Quote:
Originally Posted by vladiassis View Post
Hi guys.
when i did mine i pulled the spark plug then pulled the pull cord cover off hooked vise grips to the pice that hookes to the crank under the cover so the vise grips sat of the foot peg to hole it in place and wedged thin laths in between to get it just right. ull know its top dead center when the dot on the timing sproket its in line with the mark on the case and both rocker arms will wiggle
93 kawasaki bayou 220 home made 2 inch lift, 12x7 black ams rims with 25" kenda executioners, snorkle, grabber green paint, and many more home rigged up grades to come
jordy geiger is offline
post #3 of 4 Old 06-20-2011, 05:32 PM Thread Starter
vladiassis's Avatar
Quote:
Originally Posted by jordy geiger View Post
Hi guys.
Thank you.
post #4 of 4 Old 06-20-2011, 05:51 PM
did u get them all set
Tags
bayou 220, engine, valve, valve adjustments
93 Bayou 300 how to Adjust valves? mcgoo Everything Else 0 12-05-2010 12:06 AM
Idle Adjust, Jetting, etc on Kawasaki Prairie 650 stormarty Kawasaki Brute Force/Prairie/Bayou 4 08-16-2010 12:27 PM
now where did I see the valve adjust link? big had Kawasaki KFX700 V-Force 1 10-18-2009 05:55 AM
Valve settings on a Bayou papaterk Kawasaki Brute Force/Prairie/Bayou 2 08-01-2009 07:38 PM
valve adjust specs... Mike Walker Kawasaki KFX700 V-Force 6 07-22-2005 10:37 AM
