1st oil change - Kawasaki ATV Forum
post #1 of 5 Old 06-14-2011, 06:14 PM Thread Starter
1st oil change
12 hours and 62 miles on my new brute, did my first oil and filter change, not a lot of particles in the oil, but the front diff. was a different story, it looked like a very expensive metal flake paint, there were a lot of particles in it.
I will look at it again at 20 hours and see how it looks.
Oh yeah going Mobil 1 full synthetic 10W40, and installed a wix filter (51358)
Jeepz is offline
post #2 of 5 Old 06-15-2011, 01:29 AM
Feedback Score: 1 reviews
wart hog's Avatar
First oil change on a diff will have scale from the gears meshing. It peals about 1mil off of the surface. It's cool, diffs do that when set up right.
#1 05 Brute 750 4x4I Camo
DynaTek FS CDI and coils, Muzzy Super Pro Duals
30" Silverbacks on 14" ITP SS212's, Elka Stage 1's
3" Center Snorks, ODI Rouge Grips, HDPE Skids
Wild Boar Radiator Relocate, Highlifter Signature 2" Lift Warn 3500 ProVantage
#2 07 Brute 750 4x4I Team Green
DynaTek FS CDI, HMF Penland Pro,Center Snorks, HDPE Skids, Brush Guard, Aluminum Bumper
30" Mud Lights on 14" ITP SS106's, Warn RT2500
wart hog is offline
post #3 of 5 Old 06-15-2011, 04:37 AM
Same thing with me, but this was my 4th service. (Did engine oil and both diffs each time)
Didn't notice it the other times, but when I emptied the drain bucket, it was loaded with gold flakes. Unfortunately, I didn't take much notice and drained everything into the same bucket so I can't say for sure where it came from....I checked each diff for water (none) as soon as the fluid started coming out and then just let them drain while I did other stuff.
I'm very curious to hear if it's normal also. First service I would expect some particles, but this is the 4th...7 months old, 102 hours, 1950kms. All stock.
gcfishguy is offline
post #4 of 5 Old 06-15-2011, 09:00 AM
Feedback Score: 4 reviews
Chuck750's Avatar
4200 miles on my 08 Brute...every front diff oil change (every 400-500 miles/20-25 hrs) would be the silver metallic looking oil. Never had any problems with it so I assumed it's normal...just keep changing since its easy enough and cheap enough. I read here a while back to NOT use synthetic oil but dont' remember the reason why - something with the acuator? I did use Amsoil and then switched to the cheap stuff later on.
08 Brute Force 750, 6 Xtra HP w/ VDI
VFJ Stage3 primary
26" Mudlites on Type 7's
3K Viper winch
MIMB Snorks
FULL custom indestructable HDPE Skids, A-arm & Floorboard guards - PM if interested in a set! Better than ebay pricing!
11 Outlander Xxc, Muzzy slip on, EJK, Twin Air, D2's, Elka Stage 3's, 26" DC's on SS212's
Wifes 07 King Quad 700, Elkas, VDI, Uni, 26" Grim Reapers, 212's`s, Coop mods, EPI Yellow, 17g weights, 60" Moose plow, Powermadds
Chuck750 is offline
post #5 of 5 Old 06-15-2011, 09:54 AM
wart hog's Avatar
I build my rearends for my race cars and it's the same. Light flakes are normal. 4 Wheelers are the same. It's a combination of the chrome bearing surfaces, gear mesh on heat treated gears and basic wear debris. As the gear oil passes through the mesh points, small particles are caught between the gears and "mashed" flat into flakes. Some of it is aluminum specks from the inside of the gear case, a lot is the thin chrome layers on the bearing races pealing. That is where the slack in your bearings comes from. Normal wear.
wart hog is offline
2012 kawasaki teryx 750 change oil
2013 kawasaki tyrex 4 oil change
2014 kawasaki teryx 800 oil capacity
2014 teryx 800 oil change
2015 teryx 800 oil change
750 teryx oil change
how do you change the oil in kawasaki teryx 750
how to change oil in kawasaki teryx
how to you change the oil filter on a 2016 kawasaki teryx le
kawasaki 750 teryx oil capacity
kawasaki teryx 4 oil change
kawasaki teryx 4 oil change how often
kawasaki teryx oil change instructions
oil change help Reggie44 Kawasaki Brute Force/Prairie/Bayou 1 04-26-2010 09:21 PM
Oil change how often? mn250r Kawasaki Brute Force/Prairie/Bayou 4 01-25-2009 10:08 AM
oil change ruffriderGA Kawasaki Mojave/Lakota 7 06-21-2005 02:24 PM
did it change again? cwr fast mojave-greg News/Support/Feedback 2 06-06-2005 08:35 PM
did it change again? cwr fast mojave-greg Kawasaki Mojave/Lakota 0 12-31-1969 07:00 PM
