Pilot needle adjustment - Kawasaki ATV Forum
post #1 of 15 Old 06-18-2011, 10:27 PM Thread Starter
Feedback Score: 1 reviews
wart hog's Avatar
My bike is back-firing and lagging on take off. It clears up once you get past 1/4 throttle. It acts like it is leaning out on the bottom end. I was going to fatten up the pilot needles, but I can't get my hands in there to turn the needles. Is there some trick tool or do I have to pull the carbs to adjust them? (Surely not. lol)
#1 05 Brute 750 4x4I Camo
DynaTek FS CDI and coils, Muzzy Super Pro Duals
30" Silverbacks on 14" ITP SS212's, Elka Stage 1's
3" Center Snorks, ODI Rouge Grips, HDPE Skids
Wild Boar Radiator Relocate, Highlifter Signature 2" Lift Warn 3500 ProVantage
#2 07 Brute 750 4x4I Team Green
DynaTek FS CDI, HMF Penland Pro,Center Snorks, HDPE Skids, Brush Guard, Aluminum Bumper
30" Mud Lights on 14" ITP SS106's, Warn RT2500
wart hog is offline
post #2 of 15 Old 06-18-2011, 10:29 PM
Feedback Score: 9 reviews
kawboy1's Avatar
You mean the fuel screws? I don't know about the 750 but on the sra you can get to them with a screw driver.
LOONEY TUNED FST 765
LOONEY TUNED KFX450R (SOLD)
My You Tube videos http://www.youtube.com/user/michealmannion?
feature=mhum
kawboy1 is offline
post #3 of 15 Old 06-18-2011, 11:41 PM Thread Starter
wart hog's Avatar
I wish it was that easy on 4x4i bikes. I think the SRAs my be different. These screws are on the bottom of the carbs by the bowls. You can't get your hand under there. I tried with a bit from a 4in1 screwdriver. They show a special tool that looks like a flex driver with a 90 degree bend at the end.
wart hog is offline
post #4 of 15 Old 06-19-2011, 06:03 AM
kawboy1's Avatar
Yeah the sra must have a bit more room......they are still where you describe but I can get to them with a screw driver no probs.
feature=mhum
kawboy1 is offline
post #5 of 15 Old 06-19-2011, 06:10 AM
Feedback Score: 2 reviews
dman66's Avatar
pilot adjust
I have an 05 750i,and I use a 6 in 1 screwdriver. I take the 1/4" end out of it and use it with the small flat blade tip - yeah it's tight,but you can get in there and turn that 1/4" adaptor with your fingers.You just have to make adjustments when shes cold,or wrap a thin towel/rag on top of your hand when shes hot,so you don't burn your hands on coolant piping -been there - lol.........Oh yeah,the screws your talking about are the air/fuel mixture screws on the bottom of each carb. What size pilots do you have? Are you getting popping out the carbs? Did you try to restrict air, or turn on your choke when this condition occours? I have a 2" intake snorkle to the air box,uni air filter,stock cdi,stock engine,Kehin #150 main jet front/#152 rear,#40 pilots,and I still have to restrict air into the intake snorkle,to get her to run great. I plan on bummpimg up main jets a little at a time till shes good without restricting air into intake snorkle - and in doing so you have to keep checking those spark plugs to get a brown paper bag colour - just don't go to the whiteish colour.
dman66 is offline
post #6 of 15 Old 06-19-2011, 04:49 PM Thread Starter
wart hog's Avatar
Where do I buy pilots from. I live in the boonies and have to mail order all of my stuff. I'm running 152 front and 158 rear. i have a 38 pilot, it could help bumping it up to a 40. I'm going to shim the needles and see if that helps.
I did manage to get my hands in there and turn the fuel/air screws. At 3 turns out, it ran better, but not as well as it should.
wart hog is offline
post #7 of 15 Old 06-19-2011, 05:03 PM
kawboy1's Avatar
Try RM ATV or Motosport.com maybe? I would try shimming the needles first as it's free apart from the washers(#4). If that don't work go to the #40 pilots.
feature=mhum
kawboy1 is offline
post #8 of 15 Old 06-19-2011, 05:52 PM Thread Starter
wart hog's Avatar
Cool Kawboy. I shimed the needles once when I first bought the bike. 2 washers under them was too much. I didn't really know what I was doing, just hit and miss trying to get it dialed in. I'll try one washer and see where that hits. This thing should should leave the the line like a cheetah on cocaine. It is awesome once you get it past the low end lag.
wart hog is offline
post #9 of 15 Old 06-22-2011, 07:59 PM Thread Starter
wart hog's Avatar
Shimmed needles with 2 #4 washers and running pilot screws at 3 1/2 turns out and it's still wanting more juice on the bottom end. I ordered #40 pilot jets from Rocky Mountain and will put them in Saturday.
wart hog is offline
post #10 of 15 Old 06-22-2011, 08:02 PM
kawboy1's Avatar
Any better though?
feature=mhum
kawboy1 is offline
06 kawasaki 650 atv pilot mixture adjustment
07 brute force 750 carb adjustment
adjusting air fuel screw on brute force 750
brute force 750 pilot adjustment
brute force 750 pilot screw adjustment
kawasaki carburetor adjustment tool
kawasaki carburetor pilot adjustment
kawasaki kz440 pilot needle adjustment
pilot circuit screws 07 brute force 750
pilot jet adjusting tool for kawasaki voyager
pilot needle valve carb
pilot screw in brute carb
'03 Mojave Carb Jet Needle Adjustment? ironmine Kawasaki Mojave/Lakota 3 05-22-2011 06:26 PM
Pilot screw adjustment rbogle Kawasaki KFX700 V-Force 3 01-28-2011 07:24 PM
pilot needle setting 01 prairie korther Kawasaki Brute Force/Prairie/Bayou 0 10-24-2010 11:22 AM
Needle shim and pilot size??? gman-brute Kawasaki Brute Force/Prairie/Bayou 12 06-24-2010 05:26 AM
keihin cvkr jet needle adjustment prairie dog 650 Kawasaki Brute Force/Prairie/Bayou 3 12-19-2009 08:04 PM
