2002 Kawasaki Prairie 650 Overheating/Fan Issues - Kawasaki ATV Forum
post #1 of 4 Old 06-28-2011, 12:02 AM Thread Starter
Question 2002 Kawasaki Prairie 650 Overheating/Fan Issues
I have a 2002 Kawasaki Prairie 650; I have been having trouble with my cooling system. When just normal riding you can feel the heat building in the engine and anywhere from 5-10 mins after riding the cooling fan turns on. The fan use to be mostly quiet but now has a growl or louder hum then before. Anywhere from 5-10 mins AFTER the fan kicks on the heat is still building and soon the overheating light comes on the display. I haven’t noticed any overflow issues and the coolant reservoir appears to be full. The last time I rode, I could tell it got very hot and seems like the fan would run long after the engine was shut off (up to 20 mins). I haven’t really ridden too much after this has happened because of fear of damaging the engine. The radiator appears to be clean. I have always thought it was an issue with the fan because of the increase in noise. Could there be something more than an issue with the fan? I have taken the fan out and is there any way to test the fan assembly? As of right now, I am thinking about just replacing the fan assembly. Any suggestions or insight would be greatly appreciated!
Matt
stubmat is offline
post #2 of 4 Old 06-28-2011, 09:29 AM
coach robinson's Avatar
You can jumper the 2 wires from the sensor to test the fan. (Ones that plug into the rad) Put your hand infront of and behind the radiator and see if you can feel it pulling air and then go from there if you think its the fan.
As far as replacing it goes I went with a 10" hayden fan for $50. A new kawi fan was too expensive and a used one would.lend the same problem sooner or later.
But if the one you've got is moving air through the rad despite the noise you've got a problem elsewhere. Ie pump t stat airlock etc.
coach robinson is offline
post #3 of 4 Old 06-28-2011, 10:30 AM
Are you sure your rad is clean? Shine a trouble light from the inside and take a look from the front. Otherwise, maybe you need a new water pump. Fire it up cold with the rad cap orr and watch for circulation.
2014 t2 800 N PARTS! NOW GET THE FAWK OUTTA MY WAY!
EFFIN750 is offline
post #4 of 4 Old 06-28-2011, 10:31 AM
OFF not orr, dumb fingers!
EFFIN750 is offline
Tags
cooling fan, cooling system, overheating, prairie
02 kawasaki prairie 650 overheating
02 kvf 650 overheating
2002 kawasaki prairie 650 over heatig
2002 kawasaki prairie 650 overheating
2002 praire 650 overheating problem
2002 prairie 650 cooling issues
fan not working 2002 kawasaki prarie 650
kawasaki 650 prairie overheating
kawasaki prairie 650 cooling fan
kawasaki prairie 650 fan motor
kawaskie prairie fan 650
why would my zkaeaski 4wheeler over heat?
Kawasaki 2002 Prairie 300 help. jdunne Everything Else 3 09-20-2009 06:20 PM
2002 Kawasaki Prairie 650 Parts Bruiser For Sale 1 02-06-2009 05:31 PM
2002 KAWASAKI PRAIRIE 650 PARTS!!REDUCED!! Bruiser For Sale 2 06-22-2008 05:50 PM
2002 Kawasaki Prairie - $4200 obo VTwinMan For Sale 4 04-16-2008 09:34 PM
FS: Kawasaki 2002 Prairie Air Box and Filters Fireman650 Kawasaki Brute Force/Prairie/Bayou 0 07-06-2005 02:41 PM
