'04 Bayou 250 Idle Problem - Kawasaki ATV Forum
post #1 of 5 Old 07-19-2011, 06:50 AM Thread Starter
cwalton's Avatar
My 250 doesn't seem to want to idle corrertly. I've adjusted the mixture screw every which way. When I apply the choke it will idle for a short time then rev way up and when I get off the choke it dies...Any thoughts would be great.
cwalton is offline
post #2 of 5 Old 07-19-2011, 01:49 PM
You prolly need to pull the carb and clean all the jets. The pilot jet is most likely the culprit here but if it's corroded the other are too. It's not a hard task to do either.
1998 Prairie 400 AWD---SOLD
2013 XMR 650---NEW RIDE
On the lookout for a Brute at a good price. Minor work needed is ok if the price is right!
Josh1980 is offline
post #3 of 5 Old 07-20-2011, 01:07 PM Thread Starter
cwalton's Avatar
I completely striped the carb and soaked it cleaner over night. It is still doing the samething. Would a jet kit help or would it be a waste of money?
Fortes Fortuna Adiuvat
cwalton is offline
post #4 of 5 Old 07-21-2011, 12:34 PM
Well on mine and I'm sure yours would be the same. You'll need to pull the jets out and clean them. The pilot and main jet have some extra holes that need cleaning and can easily clog up. I did the same as you with the same result, which is why I tore it completely down. Runs great now. I just used a new jet kit instead of trying to clean mine. Kit was like $20 and comes with all you need.
Josh1980 is offline
post #5 of 5 Old 07-26-2011, 08:06 AM Thread Starter
cwalton's Avatar
I'll try a new jet kit. Thanks
cwalton is offline
06 kawasaki bayouy 250 idle issues
250 kawasaki bayou want idle.
250 kawasaki bayou won't idle and less choke is on
high idle problem on a 2006 250 kawasaki boyoa
kawasaki 250 bayou misson idle
kawasaki bayou 250 carb adjustment
kawasaki bayou 250 carburetor adjustment
kawasaki bayou 250 carburetor problems
kawasaki bayou 250 idle adjustment
kawasaki bayou 250 problems
kawasaki bayou 250 wont idle
my 2008 kawasaki bayou 250 is idleing to high
why does my kawasaki 250 bayou not idle?
1988 Bayou 300 Backfiring above idle cnskey Kawasaki Brute Force/Prairie/Bayou 4 03-13-2012 07:25 PM
87 300 Bayou idle probs CJStymeist Kawasaki Brute Force/Prairie/Bayou 2 05-22-2011 06:48 AM
My Bayou will only idle ...? jlakey Kawasaki Brute Force/Prairie/Bayou 2 05-18-2011 03:42 AM
idle problem matt1 Kawasaki Brute Force/Prairie/Bayou 13 03-11-2011 02:15 PM
Bayou 220 idle problem smallquads Kawasaki Brute Force/Prairie/Bayou 2 05-05-2003 04:21 AM
