snorkel questions - Kawasaki ATV Forum
post #1 of 6 Old 07-25-2011, 07:48 PM Thread Starter
joshwyle's Avatar
snorkel questions
im going to snorkel my 2005 brute force 750. i was planning on going with the 2" pipes but do not want to have to rejet. ive found all the info on how to but nothing on how to not have to rejet. im also wondering about vent lines like which ones need to be moved up and what to use to extend them. is there anything im missing ? any thoughts are much appreciated. thanks
joshwyle is offline
post #2 of 6 Old 07-26-2011, 07:54 AM
When ever you add more air to a intake system, your going to need more fuel, no other way around it
Injected is offline
post #3 of 6 Old 07-26-2011, 08:03 AM
2010Bruterider's Avatar
I've read of people having good luck when using the three inch snorkles for the air box. No rejetting req'd. That's what I've read. Maybe someone will chime in and confirm that for you.
Sent from my SAMSUNG-SGH-I997 using Tapatalk
Snow White 2010 Brute 750, protected by .357
2010Bruterider is offline
post #4 of 6 Old 07-30-2011, 04:13 AM
If you go to MudInMyBlood Forums forum they have a few threads on building snorkels and what all needs to be done with the set up including rejetting.
hawk is offline
post #5 of 6 Old 07-30-2011, 05:43 AM
Feedback Score: 2 reviews
dman66's Avatar
05 brute 750
If I were you,and I will be reinstalling my snorkles,I would install the 3" intake and 2" CVT snorkles.Most people prefer the center snorkles instead of the side snorkles due to if your bike tips over in deep water,the side snorkles are usally the first to go under water - center snorkles are in the center.I plan on installing mine just as high as the front pod is,cause I dont go super deep over the bars.My snorkles were more to prevent water from getting in the air box on creek riding or trial water pits. The 2" has been a real PITA to rejet,And is still ongoing.I have I believe a Kehin 148 front jet and a 152 rear jet,a #40 pilot and stock needles with one 3mm shimm under each needle,stock bike other than snorkles.I have to still restrict air to get her to run right.I've been over jetted - under jetted and needle shimmed to the point of rage dialling her in.If you remove the cover on the intake of the box,and stick the 90 deg. rubber boot on the air box,take her out for trial rides and see how she does - this will give a good idea how she'll run.Please keep all posted.
05 Brute 750i Stock engine/ Muzzy Pro exhaust,Dynatec cdi,Vision Bruiser 14" wheels, 26" Bear Claw HTR Tires,3" intake snorkle - restricted,2" CVT snorkles,10" electric fan with custom mount,Mr Gasket Fuel Pump ,rejetted at #40 pilots,2 3/4 out on A/F screws,stock needles shimmed .030",# 158/# 158 main Jets
dman66 is offline
post #6 of 6 Old 07-30-2011, 05:53 AM
dman66's Avatar
snorkles
Oh yeah,I forgot to mention.The set up I posted above ,in the center pic shows a used carb boot in the 2" intake. With that in the intake,she'll wheelie as much as you want her to.The bike is sooo snappy on the throttle to.If I take out the boot,she falls on her face at 1/8 to 1/2 throttle which should be the carb needles - but have not achieved a good shimming of needles for just a straight 2" intake.
dman66 is offline
2005 brute force 750 snorkel kit rejetting
brute 750 3 center snorkel list
brute force rejet for snorkels 05
brute force snorkel rejet
do u have to rejet for snorkels on 05 brute force 750
how to do the center snorkle on a brute force
how to snorkel a 2005 750 brute force 3'
how to snorkel a 2005 brute force 750
how to snorkel a kfx 90
is there rejetting with a 3' rubber 90 brute force
snorkel 2005 brute 750 going dead in water
whats ppl going with snorkeling a 750 brute force
where do the three snorkles go on brute force
Snorkel Questions forcefulbrute88 Kawasaki Brute Force/Prairie/Bayou 3 01-29-2011 03:22 PM
39 mm carbs questions/ motor build questions. jksimpson Kawasaki Brute Force/Prairie/Bayou 15 07-19-2010 08:15 PM
Brute Force 650i Snorkel Questions o8 Brute Kawasaki Brute Force/Prairie/Bayou 1 05-25-2010 10:25 PM
Snorkel Questions ditch1000 Kawasaki Brute Force/Prairie/Bayou 1 08-23-2009 08:20 AM
V-Force airbox snorkel questions? OuterLimit Kawasaki KFX700 V-Force 0 02-15-2004 06:58 PM
