Bayou 400 B4 Idle start problems - Kawasaki ATV Forum
post #1 of 2 Old 08-04-2011, 06:58 PM Thread Starter
TJH
Have a 96 bayou 400 that'm a headache. The problem is with the idle at atart up. Most of the time at start it will idle rough and stall. If chocked it will seem to run abit better. If I them simply let the bike sit for 10 minuetes or so, it sometimes starts and runs like a new one. Once in a while it will start cold just like a new one. the idle problem is intermitant.
Things that I have done to this bike.
New plug, New cylinder, New piston, New rings, two new valves, valve job, new decompessor, new one way clutch, new torque limiter, chased wiring and repaired to remove potential shorts, disassembled and cleaned carb (initial setting on pilot jet set at 2 1/4 turns), Did find the pilot jet partially clogged and cleaned it with a wire.
One note: the vacuum diaphram appeared somewhat wrinkled, but not torn or holed.
I do ride this on my farm but it drives me nuts to keep starting and shutting down till it starts and runs clean.
Any help is appreciated
TJH is offline
post #2 of 2 Old 08-05-2011, 07:28 PM Thread Starter
TJH
Bayou 400 B4 Idle start problems (Found problem)
Think I found the problem. For the benefit of others here's what i found. When I originally cleaned the carb, I did not check the float height. I hate getting a float off adjustment, so often just leave them alone. Took the carb apart again and measured float height. To my horror, it was probably 7mm to low. Changed the height to put it in the middle of factory specs. Wow, made a difference. Could run better at a slow idle, but it's acceptable for now. Explains why the previous owner had the pilot screw turned out 8 turns.
TJH is offline
1996 400 bayou clutch adjust ment top screw turns hard all the time
400 bayou carburetor problem
95 kawasaki bayou float adjustment
adjust idle on kawasaki bayou 400
bayou 400 carb adjust
bayou 400 starting problems
bayou 400 vaccum valve adjustment
how to adjust idle on 95 kawasaki bayou 400
how to adjust kawasaki bayou 400 clutch
kawasaki 400 idle problems
kawasaki bayou 400 carburetor adjustment
kawasaki bayou 400 carburetor problems
starter idle limiter kawasaki bayou
My Bayou will only idle ...? jlakey Kawasaki Brute Force/Prairie/Bayou 2 05-18-2011 04:42 AM
Stalls at Idle and then wont start King of Beers Kawasaki KFX700 V-Force 2 12-22-2010 01:37 PM
hard to start and idle when cold djturg Kawasaki Brute Force/Prairie/Bayou 2 10-12-2010 11:08 AM
hard to start, cough at idle, cant tune BigSexy03 Kawasaki KFX700 V-Force 20 12-01-2009 08:29 AM
IDLE PROBLEMS???? ohiobrute75 Interstate Motorsports 13 11-25-2008 04:46 PM
