Brute force 750 carb sync - Kawasaki ATV Forum
post #1 of 10 Old 08-23-2011, 07:35 AM Thread Starter
Question Brute force 750 carb sync
Ok guys got a small problem. I dont know if this has been talked about... if so a link would be fine. But..
I have jetted my brute to where I htink it should be by checking spark plugs. Now I have a small poping at idle and a little popping half throttle. If I go wide open it clears rights up. So I read alot about carbs being synced together. So I have ordered a flowmeter. My question is the syncing part. Is there a specification to do in relation to the jet size? Or do I just pick the higher one or lower one and sync together? Any help would be great!
A lilttle info on the atv.
2005 Brute force 750
Hmf full exhaust
K&N air filter
mud insdustires snorkle with outter wear
ehs mudder lid with outter wear
dyna jet (155-160).
and thats all i think that would have to do with this problem
Rakow03 is offline
post #2 of 10 Old 08-23-2011, 02:17 PM
Feedback Score: 2 reviews
dman66's Avatar
carb sync
I know the service manual tells you how to sync the carbs,but I forget what it says.I do know the carb butterflies should have the same clearances when they are closed/open,and the vaccum should be the same.
05 Brute 750i Stock engine/ Muzzy Pro exhaust,Dynatec cdi,Vision Bruiser 14" wheels, 26" Bear Claw HTR Tires,3" intake snorkle - restricted,2" CVT snorkles,10" electric fan with custom mount,Mr Gasket Fuel Pump ,rejetted at #40 pilots,2 3/4 out on A/F screws,stock needles shimmed .030",# 158/# 158 main Jets
dman66 is offline
post #3 of 10 Old 08-23-2011, 04:37 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Just syncronize them; i.e. draw the same amount of vacuum. It MIGHT help the problem at idle, but won't do anything for the half-throttle issue.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #4 of 10 Old 08-23-2011, 07:24 PM
hondarecoveryman's Avatar
The screw that adjust the sync (between the carbs) adj. both at the same time, It opens one as it closes the other
2003 P650 : Lifted,Snorkeled,Moose Module,26''589's(9's &12's),Super Grip Typhoon Wheels, MIMB clutch mod,Viper 4000lb.
hondarecoveryman is offline
post #5 of 10 Old 08-23-2011, 07:45 PM
Feedback Score: 1 reviews
dustinjklee's Avatar
U just have to adjust them to where they're the same u also have to wait for it to get to operating temps before adjusting. Ull also prolly have to adjust ur idle while doing it cause it might cause it to idle slow and die if it does that just idle it back up to original idle rpm
07 750I
29.5 swamp lites with 1.5 inch wheel spacers
2 inch lift
#4 shimmed needles
.....now I need snorkels and a pipe
dustinjklee is offline
post #6 of 10 Old 08-24-2011, 04:29 AM
dman66's Avatar
jetting
Also did you check your carb needles.what needles are in there - stock needles NFKK front/NFKL rear.I shimmed my needles with two #3 washers,and it helped the carb stumble go away.Post back on how the sync of carbs go - just curious cause alot of people say you should'nt have to sync normally unless some previous owner played with the syncing.
dman66 is offline
post #7 of 10 Old 08-24-2011, 04:40 AM
rdm531's Avatar
i use a number 30 drill bit to adjust mine i use the idle screw to get it in the front to where its a fine fit in the butterfly . then the sync to get the rear, then all you need to do is reset the idle
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #8 of 10 Old 08-24-2011, 05:38 AM Thread Starter
Thanks guys! I will let everyone bows how it goes this weekend. I'm still waiting on the flow meter. Hope it comes in by Friday!
Rakow03 is offline
post #9 of 10 Old 08-24-2011, 11:44 AM
dman66's Avatar
rdm531, my butterflys just touch the bottom wall of the carb venturi wall - is this wrong - not putting you against the wall - just asking. A # 30 drill bit is like an 1/8th inch bit I believe,and that is alot more clearance from the butterfly to carb wall than where mine is set.And it runs ok this way - would it run better set the way your adjusting it?
dman66 is offline
post #10 of 10 Old 09-05-2011, 04:03 PM
b_jahn's Avatar
i have a small studder in the bottom end of my 05 bf 750 but its only on take off, and ive heard the carbs could be out of sync and how exactly do you sync them?
b_jahn is offline
Carb Sync natedog_74 Kawasaki Brute Force/Prairie/Bayou 3 12-10-2009 01:19 PM
carb sync. longhorn Kawasaki KFX700 V-Force 5 06-20-2005 07:33 PM
CARB SYNC QUESTION deerchooper Kawasaki Brute Force/Prairie/Bayou 8 06-06-2005 02:57 PM
P650 carb sync question> lackdog Kawasaki Brute Force/Prairie/Bayou 2 06-02-2004 12:53 PM
Carb Sync norcalvf Kawasaki KFX700 V-Force 2 03-27-2004 11:49 PM
