06 brute force 750 (kvf750a6f) differential oils - Page 2 - Kawasaki ATV Forum
post #11 of 20 Old 09-01-2011, 10:02 AM
Feedback Score: 1 reviews
dustinjklee's Avatar
Quick question the hydraulic fluid isn't really all that thick why would it matter if its a tiny bit thicker that 10w40 ? It's not like it has an oil pump that it has to cycle through. Do you really think its gonna hurt to run hydraulic fluid in the from diff? What's the outcome if u do?
07 750I
29.5 swamp lites with 1.5 inch wheel spacers
2 inch lift
#4 shimmed needles
.....now I need snorkels and a pipe
dustinjklee is offline
post #12 of 20 Old 09-01-2011, 10:22 AM
Feedback Score: 3 reviews
Octane2079's Avatar
Well come to think of it. It may be the close to the correct weight, but I am pretty sure it includes friction modifiers that would be a no no for the clutch's in the diff.
Also its more expensive than motor oil so why waste it on the front diff when you can buy a gallon of rotella T that will take care of the oil and diff change in one go?
04 Prairie 700
Elka |Faastco | GT Thunder | OMF | VFJ | Rox | Crossovers | Dynatek |
| PRM | Streamline |
Octane2079 is offline
post #13 of 20 Old 09-01-2011, 10:28 AM
U can get 2 gallons of it for 18 bucks that's cheaper than rotella I'm just curious cause I was gonna use what I used in the rear diff for the front. Also the rear break is just like a clutch so if u can use hydraulic fluid in the rear wouldn't u think the diff lock clutches would be made of the same material? I'm just wondering cause none of this makes sense lol. Something u can use in the rear u can't use in the front but they both have the same parts in them they just do different things
07 750I
2 inch lift
#4 shimmed needles
post #14 of 20 Old 09-01-2011, 03:36 PM
Feedback Score: 9 reviews
kawboy1's Avatar
Think about how the front diff lock works(under power)and how the rear brake works(not under power)even though they both have similar components ie clutch packs their operation is the complete opposite.Use what is recommended, there is a reason for it. Motor oil in the front and hyd wet brake fluid in the rear.
LOONEY TUNED FST 765
LOONEY TUNED KFX450R (SOLD)
My You Tube videos http://www.youtube.com/user/michealmannion?
feature=mhum
kawboy1 is offline
post #15 of 20 Old 09-01-2011, 04:21 PM
Octane2079's Avatar
Quote:
Its not cheaper when you also have to buy the oil to do the oil change...
Buy 1 gallon, two quarts in the motor, a bit of the leftover in the front diff and you are done.
Also what wet brake fluid are you getting for 9 bucks a gallon?
04 Prairie 700
| PRM | Streamline |
post #16 of 20 Old 09-01-2011, 04:41 PM
I don't know what its called I'm not around it right now but I got it at rural king its just tractor hydraulic wet brake Fluid. I just think that if its ok for a wet brake it would be ok for a wet clutch. If ur brakes haven't give out squeezing the shit out of them and they still stop good then I wouldnt see why apply pressure and putting torque on the diff clutches would really be that much different. I understand the difference that they do. One has to completely lock up and not slip and the other does slip. Just font see it affecting it until someone can give proof or show proof that it won't work
07 750I
2 inch lift
#4 shimmed needles
post #17 of 20 Old 09-02-2011, 06:49 AM
wart hog's Avatar
Shell Rotella T 15W-40 conventional oil now lists on its packaging JASO MA as one of the specifications it meets, as does the Rotella website product page:
Note that the 10W-30 conventional oil does not list JASO-MA.
The newer fully synthetic T6 5W-40 oil also lists JASO-MA compliance on its packaging and on the Rotella website.
This is what I run:
#1 05 Brute 750 4x4I Camo
DynaTek FS CDI and coils, Muzzy Super Pro Duals
30" Silverbacks on 14" ITP SS212's, Elka Stage 1's
3" Center Snorks, ODI Rouge Grips, HDPE Skids
Wild Boar Radiator Relocate, Highlifter Signature 2" Lift Warn 3500 ProVantage
#2 07 Brute 750 4x4I Team Green
DynaTek FS CDI, HMF Penland Pro,Center Snorks, HDPE Skids, Brush Guard, Aluminum Bumper
30" Mud Lights on 14" ITP SS106's, Warn RT2500
wart hog is offline
post #18 of 20 Old 09-02-2011, 10:41 AM
Thumbs up Oils
Simple for me
Front and Engine Rotella T6 Synthetic
Rear Kubota UDT hydraulic fluid.
Stewby is offline
post #19 of 20 Old 01-24-2015, 08:03 AM
You can get the Mobil 424 that Kawasaki recommends for the rear differential on ebay for about $25 for two quarts. Enough to do two changes. Hydraulic oil is required in rear differential because of brakes
ttpinker is offline
post #20 of 20 Old 01-24-2015, 08:12 AM
NovaKaw650's Avatar
Garage
Quote:
4 year old post.
I think a quart of the Kawichem fluid is only about $12.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
2010 brute force 750 rear diff oil
2015 brute force 750 front differential oil
brute force 750 diff fluid
brute force 750 front diff fluid
brute force 750 front diff oil
brute force 750 front differential oil change
kawasaki brute 750 front differential what oil
kawasaki brute force gear oil
kvf650 diff oils
kvf650 gear oil
what front diff oil do i use for 2007 brute force
what kind of front differential gear oil does a 2009 brute force 750 take
need help removing front differential brute force MIDAllStarz Kawasaki Brute Force/Prairie/Bayou 4 10-27-2010 09:23 PM
06 750 brute force front differential broussos Wanted 2 10-19-2010 08:03 PM
Prairie/Brute force front differential kaw700 Wanted 0 02-19-2010 01:20 PM
brute force front differential hoofy58 Wanted 0 06-27-2009 01:32 PM
Brute force differential dmalmay Kawasaki Brute Force/Prairie/Bayou 10 05-01-2007 09:51 PM
