Electrical Wont Start....somewhat mechanically enclined - Kawasaki ATV Forum
post #1 of 10 Old 09-07-2011, 02:44 PM Thread Starter
I NEED HELP. My dad just gave me a 1986 Kawasaki Bayou 300 2x4 with differential. It always had a hard time starting in the cold, but never electrical issues. My dad said he bought a new battery and at first it started, then he was having to jiggle the key, and now nothing. No neutral light, headlight, or clicking, nothing. The battery is good.
Here is what I have done so far.
1. Looked at 10 million posts and still cant figure it out. I might not have tried everything properly.
2.Took off all the plastic to have access to everything.
3. Tried to pass the relay on the ignition with a screwdriver, and still did not get any lights.
4. Looked at what i think is the solenoid and noticed the connections were very rusty.
5. Checked the only fuse i could find, looked fine.
6. Checked ground to frame, clean and connected/
Please help. I am hoping to use this ATV to plow some driveways in the neighborhood to earn money for school, put i cant plow if it doesnt start!
bigbubbalouie is offline
post #2 of 10 Old 09-07-2011, 02:49 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Clean all the connections, and pay attention to the jiggly key switch. It may have quit completely.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #3 of 10 Old 09-07-2011, 03:18 PM Thread Starter
the key switch does not seem to be loose. i am cleaning the connections to the solenoid as we speak, but it doesnt seem rusty enough to cause a problem with the connection. How exactlly do i "jump ith from the solenoid" as someone told me to do??
post #4 of 10 Old 09-07-2011, 04:00 PM Thread Starter
ok so i cleaned the connections for the solenoid, and i am able to jump it and get it to turn over by using a screw driver. However, it still wont start. it turns over, but wont start up.......Can anyone offer a suggestion to the next step of my never ending project!!
post #5 of 10 Old 09-07-2011, 04:13 PM
NovaKaw650's Avatar
Garage
Start tracing wires. Or you could go back to the keyswitch that you know was causing problems.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #6 of 10 Old 09-07-2011, 04:20 PM Thread Starter
it is turning over by jumping the solenoid, will it start by doing that. if its not starting but turning over by jumping the solenoid, do i have electrical problems, or other problems?
post #7 of 10 Old 09-07-2011, 04:35 PM
NovaKaw650's Avatar
Garage
All you've done is proved that the selonoid and starter work. You haven't done anything to correct the lack of fire to the spark plug and lack of power to trigger the selonoid.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #8 of 10 Old 09-07-2011, 06:23 PM Thread Starter
ok so i found the electrical problem, it was the key switch. I removed it and bypassed it by connecting the two wires together and now my neutral light lights up!! When i try starting it, it back fires and smells very rich. Could i of flooded it, what else could be wrong! I know its going to be one thing after another. And after i fix this, i hope i can help others as frustrated as me
post #9 of 10 Old 09-23-2012, 01:12 PM
lilclay12's Avatar
I NEED HELP TOO. I have a 2007 kawasaki bayou 250 that wont start. I went through a little bit of water and after that it wouldn't start the next day. I replaced the battery with a new one. But when you try to electric start it there is a clicking sound coming from the solenoid and the fuse was bad. so i got a new solenoid and replaced it but the same thing happens. It wont pull start either. i also checked the ground wire and nothing is wrong with it. SOMEONE PLEASE HELP ME WITH THIS. ANYBODY. I NEED HELP.
lilclay12 is offline
post #10 of 10 Old 06-23-2014, 02:11 AM
Thumbs up
Quote:
Originally Posted by bigbubbalouie View Post
ok so i found the electrical problem, it was the key switch. I removed it and bypassed it by...
Thank you very much for posting that this was your problem!
My 1997 Prairie 400 just recently had a similar issue (no lights on the dash, no solenoid click when turning on the key, no headlights, full battery). Based on your findings I opened up the ignition switch (key switch) and found that it was heavily corroded inside. I took a wire brush to both halves of the ignition switch to clean it all up and now everything is working fine again.
Have a great day everyone!
Shadallark
1997 Prairie 400
Shadallark is offline
Tags
bayou, electrical, no power, wont start
1986 kawasaki 4 wheeler
1986 kawasaki bayou 300 no power with key on
1996 klf 220a green light ignition won't turn on
89 kawasaki bayou 300 fuse diagram
bayou 300 light switch
bayou electric start, no clicking nothing
kawasaki brute force 650 won't start and no lights
kawasaki prairie no electric start
kawasaki prarie 400 cranks but wont start battery was dead put charger on and cranks but wont start
no click or ignition light 220 kawasaki bayou
weak spark how does it work the kawasaki 300 bayou makr spark
why wont my1988 kawasaki bayou 300 crank
wiring problems on my 1988 kawasaki 300 4x4 bayou
kfx 400 wont start hinkelracing Kawasaki KFX450/KFX400 34 09-26-2011 08:25 PM
96 Prairie 400 won't start, electrical issue? mozy444 Kawasaki Brute Force/Prairie/Bayou 1 07-31-2011 10:08 PM
'03 400 wont start Thunder Sucker Kawasaki KFX450/KFX400 3 01-12-2011 06:55 PM
06 kfx 400 wont start? chris1234 Kawasaki KFX450/KFX400 9 03-26-2010 05:49 AM
v-force wont start now. wont turn over 2qk4u Kawasaki KFX700 V-Force 1 10-28-2007 08:24 AM
