2006 KVF750 BruteForce Front Carb Problems - Kawasaki ATV Forum
post #1 of 11 Old 11-04-2011, 02:29 PM Thread Starter
Madness_MC's Avatar
I have a customer's 2006 KVF750 BruteForce that is exhibiting problems with the front carb. Vehicle starts fines, but after running at part throttle for about 30 seconds it starts sputtering thru the front carb. The sputtering smoothes out, then about 1 minute or two later, it will sputter again. With the air box removed, you can physically see the diaphragm slide "bouncing" up & down during the sputtering bouts.
We've checked the valve clearances, checked the vacuum hoses from the intake tract to the fuel pump & regulator - they're fine. We've bypassed the fuel pump & ran fuel from an auxiliary fuel tank & monitored the vacuum from both ports simultaneously. Just before the diaphragm slide begins to bounce, you can see the vacuum (with gauges attached) for the front cylinder become erratic. It goes haywire as the slide begins to bounce. This symptom lasts for about 15-20 seconds and then smoothes out again.
If it sits and idles for a long time (until fully warmed up) you may get an occasional snort thru the front carb, but the problems shows up under part & full throttle conditions. We've had the carbs apart - cleaned, inspected and reinstalled them.
This is the 2nd owner. The 1st was a "little old man who only used it from his house to his mailbox and down to his boat dock for 2 years". The 1st owner claimed this behavior happened from day 1, but never concerned him. The current (2nd) owner said the condition has always been there, and hasn't ever gotten worse. He's just being concerned as he uses his BF for deer hunting and tends to go "way off the roads" and doesn't want to get stuck one day.
Any ideas, info or where to look for a resolution would be very helpful and very much appreciated.
Thanks
Joe Licketto - Owner
Madness Motorcycle, LLc
madness_mc@sc.rr.com
803-729-4258
Madness_MC is offline
post #2 of 11 Old 11-04-2011, 04:15 PM
phatjoe's Avatar
Hey listen had the same problem with my bike, call me 3476722358 I'll walk you through everything, trust me
phatjoe is offline
post #3 of 11 Old 11-04-2011, 04:43 PM
Feedback Score: 9 reviews
kawboy1's Avatar
Check the carb boots for cracks/perished. Also click on the link Welcome to Kawasaki.com and put in the vin# to search for recalls......seem to think I read on here that there was a recall on some 750 needles but cant remember what years were effected?
LOONEY TUNED FST 765
LOONEY TUNED KFX450R (SOLD)
My You Tube videos http://www.youtube.com/user/michealmannion?
feature=mhum
kawboy1 is offline
post #4 of 11 Old 11-04-2011, 05:51 PM
Feedback Score: 2 reviews
dman66's Avatar
carbs
Ya beat me to it.... Check the front needle - if its a NFKK - either put a #4 washer under the needle or order a new NFKL needle for the front carb.The rear needle is a NFKL. Check the carb boots for air leaks,check the front carbs diaphram on the carb slides plastic cover for miss installed diaphram or leaks in diaphram.I think thats about it.Sometimes those diaphrams can slightly fall out of their seat when you reinstall the slide and diaphram cover.
05 Brute 750i Stock engine/ Muzzy Pro exhaust,Dynatec cdi,Vision Bruiser 14" wheels, 26" Bear Claw HTR Tires,3" intake snorkle - restricted,2" CVT snorkles,10" electric fan with custom mount,Mr Gasket Fuel Pump ,rejetted at #40 pilots,2 3/4 out on A/F screws,stock needles shimmed .030",# 158/# 158 main Jets
dman66 is offline
post #5 of 11 Old 11-05-2011, 07:02 AM
Mustang302's Avatar
If this condition goes away when the engine is warm , then it sounds to me like the classic symtom of an excessively lean idle . Both Kawie V twin's that I've owned , when cold , behaved like this when set to the "factory" carb calibration .
Usually , just opening up the PMS screw to 2 1/2 - 2 3/4 turns out makes a big improvement . If it's not totally cured , shim the needles .
Team Green 2007 Brute Force 650 SRA
Dynatek CDI
Twin Air High Flow Filter
ITP Terra Cross XD Radials
100% Amsoil Synthetic Lubricants
NGK Iridium Plugs
Tuned Carbs
Full Muzzy
Mustang302 is offline
post #6 of 11 Old 11-05-2011, 11:49 PM
phatjoe's Avatar
Hey madness mc, did our phone call work out
phatjoe is offline
post #7 of 11 Old 11-09-2011, 03:09 PM Thread Starter
Madness_MC's Avatar
Bump !!
803-729-4258
post #8 of 11 Old 11-09-2011, 03:40 PM Thread Starter
Madness_MC's Avatar
Quote:
phatjoe -
I checked the Kawi site for the VIN & recalls - nothing outstanding.
I checked the needles and both are the NFKL needles recommended.
Any additional suggestions ???
803-729-4258
post #9 of 11 Old 11-10-2011, 05:15 AM
Feedback Score: 3 reviews
rdm531's Avatar
have you run a leak down test on it , a snort thru the carbs ,makes me want to think something is up with intake values, maybe need to be lapped, just a thought
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #10 of 11 Old 11-11-2011, 03:48 PM Thread Starter
Madness_MC's Avatar
Leak-down test showed <5% for both cylinders, compression test shows ~70-75 psi both cylinders within 2-3 psi of each other.
It appears that it's running lean on the mid-range jets, as it's now idling fine (after a thorough cleaning and removing the air bleed restrictor valves from the diaphragms) and WOT operation appears OK.
Any additional thoughts ??
803-729-4258
08 kawasaki 650 btute force carburetor issue
2006 brute force carb problem
2006 brute force carb trouble
2006 brute force carburetor problems
2006 kawasaki 750 brute force problems
2006 kawasaki brute force 650 4x4 carburator problems
2006 kawasaki brute force 750 problems
2006 kawasaki kvf650 carburetor adjustments
brute force 750 carb problems
brute force crab problems
carborated kawasaki brute force 750 issues
carburetor problem on 2006 brute force 650
what would make the front carburetor not work on a 2006 kawasaki brute force 750
bruteforce carb slide mod a4x4nutt Kawasaki Brute Force/Prairie/Bayou 2 10-20-2011 07:39 PM
2006 BF fuel/carb issues? dbo Kawasaki Brute Force/Prairie/Bayou 2 11-23-2010 07:05 AM
2006 Bruteforce 750 4x4i roscoe750 For Sale 5 06-04-2010 08:30 PM
plastics---2006 650 bruteforce SRA mkeanglorldo56 For Sale 1 03-23-2009 07:42 PM
carb problems TINNER Kawasaki Brute Force/Prairie/Bayou 2 08-26-2004 01:47 PM
