Best mud tires? - Kawasaki ATV Forum
post #1 of 17 Old 11-14-2011, 07:36 PM Thread Starter
Best mud tires?
What are the best mud tires for my 2006 750 brute force
Meeks1221 is offline
post #2 of 17 Old 11-14-2011, 07:42 PM
driftguy2008's Avatar
mudzillas are the best mud/all terrain tire. outlaws or silverbacks for pear mud/deep water.
2006 brute force 750-27" mud zillas,itp delta 5" offset,Dynatek CDI,epi clutch kit= 54+56g weights-white primary-red secondary spring,full body skids,HD bumper, warn rt2500 winch.
2005 brute force 750 28" mudlites, itp delta, Dynatek CDI, hmf exhaust W/ quiet core, jet kit, K&N w/outer wear, epi maroon primary-almond secondary, full skids.
if you can read this thank a teacher if its English thank a soldier.
driftguy2008 is offline
post #3 of 17 Old 11-15-2011, 06:10 AM
Feedback Score: 1 reviews
wart hog's Avatar
"Best mud tire" question is like the whole "Chevy-Ford" debate. Everyone has their favorite. It's mostly a matter of what you like. For pure mud bogging, Outlaws, Silverbacks, Terminators and Mudzillas. Basically anything with a deep lug with wide lug spacing to shed mud.
Weight and ride comfort are a couple of concerns to look at as well.
Some tires by the same maufacturer ride rougher than others due to the lug spacing.
Example-28",29",30" and up Outlaws ride decent, 27" Outlaws lugs are spaced at the same width, but because of the diameter of the tire you get a Bumpity-Bump ride.
#1 05 Brute 750 4x4I Camo
DynaTek FS CDI and coils, Muzzy Super Pro Duals
30" Silverbacks on 14" ITP SS212's, Elka Stage 1's
3" Center Snorks, ODI Rouge Grips, HDPE Skids
Wild Boar Radiator Relocate, Highlifter Signature 2" Lift Warn 3500 ProVantage
#2 07 Brute 750 4x4I Team Green
DynaTek FS CDI, HMF Penland Pro,Center Snorks, HDPE Skids, Brush Guard, Aluminum Bumper
30" Mud Lights on 14" ITP SS106's, Warn RT2500
wart hog is offline
post #4 of 17 Old 11-15-2011, 07:43 AM
Feedback Score: 2 reviews
03maxpower's Avatar
I have the terminators and love them I do alot of trail riding and they ride smooth I also ride some mud and they do great not saying youll never get stuck but ive only been stuck when I got high centered and in that case no tire will help and alot of times when you can no longer go forward they will usually back out unless high centered
1978 atc 70
Teryx 4 LE aztec red
Catvos 3" lift
29.5" terminators
09' brute forcesold!!!
Fst 840 stg II cams
03maxpower is offline
post #5 of 17 Old 11-16-2011, 09:29 AM
matt1's Avatar
i run itp mudlite xls on my kawi, and they will go through any thing i put them threw.It depends on how you ride and were, but my 2 cents mudlite best all around tires.
matt1 is offline
post #6 of 17 Old 11-17-2011, 02:44 PM
LimeBrute750's Avatar
it all depends on the specific type of riding you do if all you do is mud bog then silverbacks,terminators,outlaws,black mambas,etc. but if you trail ride then mudlites,mudlite xls,sti mud trax,itp xtrs,etc.
07 Kawasaki Brute Force 750-BKP 840,XX cams,+1 valves,HD valve springs,ported & polished heads,Muzzy pro,K&N,VFJ stage 3 with spider mod,Dynatek,ITP,Sedona
05 Honda TRX450R-JE,Hotcams,Rekluse,HMF,Maxxis,Pro Armor
Youtube:MrTLynn7
LimeBrute750 is offline
post #7 of 17 Old 11-17-2011, 04:07 PM
Outlaws
NorumbegaEnforcer is offline
post #8 of 17 Old 11-17-2011, 04:22 PM
Just mud , research black mambas or terminators all around MY faves are mudbugs but like stated before best tire debate is like chevy vs. ford !!!
2012 A-C TRV CRUISER 1000 Just because Kawie dosen't have!!
________________________________________
Brute Force 650i , camo
Maroon and Ivory clutch springs
Copperhead CDI
Stage ? cams , machined clutch sheaves to match
Full aluminum skid-plate
Heated grips & thumb
3000lb warn winch
c-series ITP rims
27" mudbugs
full aluminum skids
Left hand mirror
K&N air filter
SOLD!!
Bill Sweetman is offline
post #9 of 17 Old 11-17-2011, 11:20 PM
03maxpower's Avatar
Obviously you guys never ran terminators if you think they are strictly mud cause they ride great on the trails and if you are worried about the weight get the 28s. Not sure how much less they weigh but im sure theyre better than the 29.5s mine are 45lbs a piece
1978 atc 70
Catvos 3" lift
29.5" terminators
Fst 840 stg II cams
post #10 of 17 Old 11-18-2011, 04:02 AM
KawiMonster's Avatar
40lbs, PitBull - Rockers, or Growlers (both are radial)... I have the Rocker Ubers and they work awesome (ride as smooth as Bighorns)
I go through all the same shit as my buddies with silverbacks, mud zillas outlaws and terminators
"I Dare Do All That May Become A Man; Who Dares More Is None"
KawiMonster is offline
07 brute force 750 good in mud or not
atv mud tires
best atv mud tires
black mambas vs terminators
kawasaki brute force mud tires
kawieriders best mud tires
mud tires for 2006 kawasaki
silverback vs terminator tires
silverbacks or terminators
terminaters vs silverbacks
terminators vs black mambas
terminators vs silverbacks
teryx 4 on zilla tires
Bias Ply Tires and Radial Tires… What’s what? What’s right for me? Discount Tire Discount Tire 0 08-03-2011 02:33 PM
Brute SRA wheels and 27'' tires & couple other tires prostep68 For Sale 8 07-23-2011 02:40 PM
swapping tires.. rear tires on front rims? levi_plummer Kawasaki Brute Force/Prairie/Bayou 7 01-24-2011 07:18 AM
useing 24" tires instead of 22" tires moodykfx Kawasaki KFX700 V-Force 3 10-01-2010 05:51 AM
Tires TNBRUTE Kawasaki Brute Force/Prairie/Bayou 7 07-06-2008 07:00 PM
