650i spitting and sputtering - Kawasaki ATV Forum
post #1 of 4 Old 12-07-2011, 07:46 AM Thread Starter
sullivanfire1's Avatar
Ok, 07 650i, set for a few months during off season. Started up and it runs like hammered u know what. Thought maybe it was the gas so I added sta-bil and it did not help. Took the air filter off and looked at the slides on the carbs, they seem to be working fine, however there is a tremendous amount of vibration when I give it throttle (normal??). This machine has always from day one been a hard starter, choke for about 45 seconds while trying to start and leave choke on for about 3 minutes until it warms up. No problem after that.
How can a machine run so good at the end of last season and so bad at the start of this season???? Belt is fine and is not in limp mode. It will run and run hard just doesn't sound very good with pop pop, spit spit and occasional small backfire thru carb(s).
Does anyone think it is just bad gas?? Should I be running 93 octane in the unit?? Any advise is appreciated. I really don't think it is the jets or valves because it is almost like it happened overnight.
Thx for lookin.
Southern by the Grace of God, Republican by common sense.
sullivanfire1 is offline
post #2 of 4 Old 12-08-2011, 03:27 AM
BrutemanAl's Avatar
Bad gas by the sounds of it , should have put the sta-bil in it when you knew you wouldnt have it running for a while in the down season . If the gas has just been sitting in the bike with no sta-bil or similar product , it can gum up your carbs . my brother in law is a small engine's/ marine mechanic and he told me last year that gas can start to go bad in as little as 2 weeks. You may have to drain the fuel and pull the carbs apart and clean them .
Im sure someone else will chime in and maybe they have another suggestion .
08 650 I Bruteforce
27" mudzillas,on 212 Itp rims
HMF Performance pipe
2" lift kit
Grease zerk mod on A-arms
Cdi dyna tech
Diamond G racing tierods
2500 lb warn winch
custom made HDPE Skid plates and a-arm guards
Front storage box Mod
MIMB 2" Snorkel's
Wild Boar Rad relocate
Etrex Gps
5 ft easy mount plow
BrutemanAl is offline
post #3 of 4 Old 12-08-2011, 08:28 PM
Valve adjustment.
I would bet money on it.
bfgreen is offline
post #4 of 4 Old 12-09-2011, 05:34 AM Thread Starter
Quote:
Originally Posted by bfgreen View Post
Valve adjustment.
I am thinkin the same thing, after reading posts about the unit being hard to start. Anyone know a good mechanic in Central Florida??? I refuse to take it to the local ATV shop !!
07 carb'd brute 750 spitting sputtering CRFX528 Kawasaki Brute Force/Prairie/Bayou 16 09-25-2011 03:59 PM
Spitting out gas!? s.hiles Kawasaki KFX700 V-Force 11 05-02-2011 07:27 PM
spitting oil! dgraham225 Kawasaki Brute Force/Prairie/Bayou 8 09-08-2008 09:43 PM
Quad spitting, sputtering, and backfiring at wot krewzlo Kawasaki KFX700 V-Force 3 08-28-2007 10:32 AM
BBK spitting oil asnowmobiler Kawasaki KFX700 V-Force 13 05-29-2007 11:47 AM
