Primary bolt NOGO tight - Kawasaki ATV Forum
post #1 of 8 Old 01-03-2012, 07:38 AM Thread Starter
Cool Primary bolt NOGO tight
I'm having one heck of a time trying to remove my primary bolt off 06 BF 750. Tried my air impact and electric impact, still NOGO. This bad boy is on tight.
I can only use a bigger breaker bar and have to acquire the holding tool which I have to pre-fab or purchase. Darn...
Can I wedge anything in the splines without causing damage?
I recently put a new belt on after 650 miles in the original. Belt is now squealing and creeping forward when in gear. Even having trouble putting in neutral sometimes. I cut the old belt and walked the new one on but obviously I have to shim the new.
Anyone live close to CT. and have a holding tool kicking around. I did purchase the primary puller bolt off E-bay for 22.00.
Need help as machine is DOWN for now. Have reviewed numerous threads to date.
malibu is offline
post #2 of 8 Old 01-03-2012, 11:21 AM
Feedback Score: 1 reviews
Are you turning it the right way? It has left hand threads
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #3 of 8 Old 01-03-2012, 11:38 AM
2011BruteForce750's Avatar
my brand new 2011 with 400 easy miles wasnt to bad... it was tight and after a good 20minutes of airgun torture to it.. it popped right off along with the secondary.
2011BruteForce840 4x4irs EFI
Ultimate Trail Machine
Other bikes
-2004klx400sr bbk/stroker kit next winter for sure (or if it blows up this summer)
2005BruteForce750 4x4irs sold
-2003LakotaSport300 sold
-1993Bayou220 sold
-2003klx110 sold
-1984Honda trail 110 sold
[/COLOR]
2011BruteForce750 is offline
post #4 of 8 Old 01-03-2012, 11:52 AM
dogwood's Avatar
Try smacking the head a few times with a heavy mallet 5 lbs or so, with the impact gun you should be able to spin it off quite easily. And if you do need to hold clutch in place I just use a socket extension with a socket so you get more of a base. I put a bolt thru the floor board and butt it up against it. Just make sure it is setup good so it won't slip and a little heat will never hurt from a propane torch if needed. Not to much just warm it up a little and go
XT3000/RT2500*Dual Batteries*60" plow*Kimpex Bumpers* Fender guards\foot pegs*Symtec grips\Thumb warmer*Full Richochet Skids*Kimpex storage seat*Moose Bags*Garmin 60CSX\Ram Mount*Fan mod/rad racked*K&N filter*Full Muzzy Snorkeled (XMC coated)*Dynatek CDI*NGK wires\iridium plugs*Coils sealed in RTV red*2" snorkels*EPI susp. springs*VForce Spider Mod stage 3*2" lift*AMStar tie rods with chromoly ends*SuperATV HD front axles*28" MST's on SS108's*1" billet front spacers*HID's
dogwood is offline
post #5 of 8 Old 01-03-2012, 11:55 AM
get the biggest impact gun you have and my compressor is a huge round red one idr compression i think 130-150psi i went up to before it finally came off. i didnt use anything to hold the primary it should just turn about 1/4inch everytime the gun pulses repeatedly...
Other bikes
-1993Bayou220 sold
-2003klx110 sold
[/COLOR]
post #6 of 8 Old 01-03-2012, 11:58 AM
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
righty loosie!!!!!!!!
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #7 of 8 Old 01-04-2012, 04:06 AM Thread Starter
Another attempt today
Yes, I've got the thread direction correct. Probably checked myself 10 times. Clockwise to LOOSEN.
Thanks for the replies and I'll give it another try today with the BFH and heat. I like the idea of the socket extension and am obviously concerned with damaging the primary splines. The primary bolt has never been removed so it's stock fit from the factory. Still scratching my head as the torque spec is (69) pounds. This darn bolt must over a 100 lbs torqued....what the heck.
BFH = big f'in hammer
2011bruteforce 750, great video and i have watched it 5 times. All this effort for doing the right thing and installing a new belt. Creeping and squealing now, have to add shims to make it right.
malibu is offline
post #8 of 8 Old 01-04-2012, 12:19 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
There aren't any splines; it's a taper fit on the crank.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
2007 kawasaki brute force 650 primary bolt direction
650 prarier primary clutch right or left hand threads
are kawasaki kx250 primary gear left hand thread
brute force primary bolt
brute force primary clutch bolt thread size
kawasaki prairie primary bolt left hand thread
kawasaki prarie 400 secondary clucth bolt torque
kawasaki primary bolt damaged
primary clutch bolt size on 2011 brute force
removed bolt from my kawasaki atv and there was red on the threads what is it
thread size for primary clutch bolt on 2002 kawasaki 650 praire
thread size for primary clutch on kawasakie 650
what threads are primary bolt on prairie
Primary Bolt/ Washers BigSexy03 Wanted 1 11-23-2009 07:36 AM
Primary Clutch bolt PIPO Wanted 7 10-21-2008 02:26 PM
Primary Clutch Bolt Broke hensons700v Kawasaki KFX700 V-Force 38 02-18-2007 11:47 AM
How tight on crankshaft bolt? AZVFORCE Kawasaki KFX700 V-Force 1 08-14-2004 06:03 PM
KFX400 carb bowl screws tight!....REALLY TIGHT!.... BogSpores Kawasaki KFX700 V-Force 5 10-02-2003 06:47 AM
