What kind of oil should i use?? - Kawasaki ATV Forum
post #1 of 15 Old 01-04-2012, 12:05 PM Thread Starter
Chad650's Avatar
Hey i just got a 2008 brute Force 650 SRA, it has 140 miles on it. i was wondering what Kawasaki puts in them from new for oil, synthetic or regular oil. I want change it and what to know whats the best oil to go with?? Also whats the best filter?
Thanks
Chad650 is offline
post #2 of 15 Old 01-04-2012, 12:36 PM
Look above your post in the sticky section for filters. Search "oil*" for everything else you wanted to know.
MinnKawi is offline
post #3 of 15 Old 01-04-2012, 12:39 PM
Rundown's Avatar
You can't go wrong with Kawasaki products. I've always run Kawie oil and filters.
It's been said by VFJ that synthetic oil is not as good. If you get water in sythetic oil, it will not mix at all and can wear the bearings out very fast. Regular oil will mix with the water and keep some of it's lubrication qualities.
If you don't want to pay for Kawie oil, Amsoil is the best choice.(0-40)
Don't put automotive oils in there. They are not made for engines with gears in them.
2004 Prairie 700, Progressive front suspension springs, Muzzy exhaust, NAPA hose mod, Twin-Air powerflow kit, Crossover intakes, Dyna CDI, Maroon primary, 25'' Dirtdevil tires, 1.5'' Wheel spacers.
Rundown is offline
post #4 of 15 Old 01-04-2012, 01:03 PM
Feedback Score: 3 reviews
w_pinkerton's Avatar
Quote:
I believe that's only for wet clutch systems.
A lot of people swear by 15w 40 rotella motor oil. I have yet to switch mine to that, but I will as soon as I use the the rest of my oil. I also use the 1" longer purolator oil filter.
As for full synthetics, I wouldn't use them either.
2002 P650
Dynatek CDI/Plug Boot Mod/Crossover Intakes/Stock Exhaust
'03 Airbox/UNI filter/Polished Slides/2 Shims per needle/142F&R/42 Pilots
Pink Primary/Dalton OD Cover/KEBC Removed
Aluminum Products Skids and Bash Plate
Elka Spring Kit, 2" Lift kit, 1" wheel spacers
ODI grips/Maier Handguards/Rox Risers/Fly CR High Bars
25" Duro Power Grips
w_pinkerton is offline
post #5 of 15 Old 01-04-2012, 01:05 PM
2011BruteForce750's Avatar
stock filter is fine. you wont benefit from any aftermarket (not even k&n) i got a twin air in mine. ams oil 0-40 full synthetic for vtwin engines is what i use. i called them and told them what i had and they recommended that oil to me.
2011BruteForce840 4x4irs EFI
Ultimate Trail Machine
Other bikes
-2004klx400sr bbk/stroker kit next winter for sure (or if it blows up this summer)
2005BruteForce750 4x4irs sold
-2003LakotaSport300 sold
-1993Bayou220 sold
-2003klx110 sold
-1984Honda trail 110 sold
[/COLOR]
2011BruteForce750 is offline
post #6 of 15 Old 01-04-2012, 02:59 PM
Rundown's Avatar
The hi-lo-rev transmission uses the oil in the engine. Automotive oils aren't made to resist gear pressure. And like you said, they are not suitable for wet clutch use. (front diff)
Rundown is offline
post #7 of 15 Old 01-04-2012, 04:09 PM
lumbeebrute's Avatar
390 hours and 4600 miles. Stock Kawi filters and 10w40 Castrol.
Black 09 650sra
Crossover intake
Vfj#1primary/#1secondary
Dynatek
Sunpro tachometer
Moose rear bumper
Superwinch lt3000
Scratches and dings.
lumbeebrute is offline
post #8 of 15 Old 01-04-2012, 05:38 PM
electricstart's Avatar
I am using rotella 15w 40 supposed to best for these motors.Talked v force john
2012 Kawasaki Brute force 750 eps Green
2012 Kawasaki Brute force 750 eps Black
Maxis Bighorn tires
Ricochet Skid Plates
Warn xt 2500 winches
electricstart is offline
post #9 of 15 Old 01-04-2012, 06:12 PM
dgthomas67's Avatar
What if the Kfx 700 has always ran mobile 1 fully synthetic. Bought a Kfx 700 and it has always ran with fully synthetic can I change? It has no problems. It is a 2005.
I am here: http://maps.google.com/maps?ll=30.229134,-93.325179
David Thomas
2005 KFX 700 Vforce
2005 KFX 400
2006 KFX 700 Vforce
dgthomas67 is offline
post #10 of 15 Old 01-05-2012, 06:16 AM
Quote:
I am here: Google Maps
I would stay with the mobile 1 IMO
Maxis Bighorn tires
2009 kawasaki 650 quad what type motor oil
kawasaki prairie 700 oil
kawasaki prairie 700 recommended oil
type of oil for kawasaki prairie 400
what kind of oil do i use in 06 brute force 750
what kind of oil does 2015 teryx 4 take
what kind of oil kawasaki 44 4 wheeler
what kinda oil do you use for a brute force 4 wheeler
what oil does a kawasaki brute force use
what oil does the kawasaki brute force 300 take
what type of motor oil used on kawasaki bayou 250
what type of oil do i use in a 2005 brute force
what type of oil shoul i put in kfx 700
my kind of dog! kujo Club Kawie 8 12-30-2008 11:11 PM
Would you be so kind? KodiakGuy Club Kawie 16 06-23-2005 03:35 PM
What kind of oil? Derek Kawasaki Brute Force/Prairie/Bayou 5 03-26-2005 06:52 AM
Would you be so kind? KodiakGuy Kawasaki Brute Force/Prairie/Bayou 0 12-31-1969 07:00 PM
