bayou 300 starting problem - Kawasaki ATV Forum
post #1 of 15 Old 01-16-2012, 09:55 AM Thread Starter
Hello, I'm new to this forum and am in need of some advice. We own a 94 Bayou 300 and I'm having starting problems. If i use the starter switch when the engine is cold it will turn over nicely but will not start. I appear to be getting a spark to the plug but not sure how strong. Using the pull start results in starting reliably although even with the compression relief engaged I have a hard time getting it going (my son is much stronger than I am and can start it every time). After it has run for just a short amount of time it can be restarted reliably with the starter button for the rest of the day. It runs beautifully after being started by the way. After it sits over night, the sequence is repeated - won't start via the starter switch/starter motor but starts with pull starter and after the first start is able to be "cranked" immediately by using the electric starter. I just bought the Haynes manual and would like to get to the bottom of this because it is inconvenient to have to find a strong guy every time I need to use the Bayou on our farm . Thanks for any help you can provide.
fscogin is offline
post #2 of 15 Old 05-06-2012, 09:00 AM
Had the same problem with 1998 300 4x4 and eventually led to bigger problems with ground being off. Cleaned carb, wasn't the problem. Replaced Battery, and cleaned ground, wasn't the problem. Now starter button won't work, starter is fine checked with other power source direct. Some say wire to solenoid, but definitely a ground issue. Please send me an update on your repair.
Steele is offline
post #3 of 15 Old 05-07-2012, 01:18 PM Thread Starter
Steele,
Still haven't solved the problem. I can get it to start sometimes but it only provides a spark at the plug when I release the starter switch. The guy at the Kawasaki dealership said "battery problem" when I described it to him but I have a new battery in and I've polished the battery cables to a shine. What I haven't checked is where the battery is grounded to the frame or engine block. Let me know if you figure anything out.
Forrest
fscogin is offline
post #4 of 15 Old 05-08-2012, 06:04 AM
bayou757's Avatar
i would definatly check your ground to the engine block
bayou757 is offline
post #5 of 15 Old 05-14-2012, 09:37 AM Thread Starter
Bayou757,
I disconnected the ground cable from the battery to the engine block and cleaned it up good. Was a little hard to get to. Reconnected, did not solve the problem. So, I'm still looking for a solution.
fscogin is offline
post #6 of 15 Old 05-27-2012, 03:19 AM
TFR
Sorry for digging up an old thread but I've been searching the web for an answer to this, as I have exactly the same problem on the same bike.
Weird isn't it?
Hope you find the answer, please post if you do!
TFR is offline
post #7 of 15 Old 05-27-2012, 12:29 PM
blm510's Avatar
If you have a book look up the tasting procedures for the ignation box and rectofier when you replace do both one will take the other out my 96 would only spark when i let off the starter button.
B
blm510 is offline
post #8 of 15 Old 05-27-2012, 03:55 PM
TFR
Yes, exactly the same symptoms here...when this "thing" occurs there's no spark until let off the button.
I have changed CDI, coil, plug.
There's not much left to change apart from the wiring loom. At the moment I'm thinking I have a dodgy wire somewhere causing the intermittent fault. Either that or the starter motor is causing issues, but as it spins the engine up I'm not so sure.
TFR is offline
post #9 of 15 Old 05-27-2012, 11:38 PM
blm510's Avatar
It may be the rectofier they work together to creat spark and from MY experience on a 1990 & a 1996 change both if you find one is bad.
B
blm510 is offline
post #10 of 15 Old 11-25-2012, 11:44 AM
Don't know if this will help, but check your valve clearances. I've had many bikes through the years and the intake valve being to tight will keep it from starting off the electric starter, but I could pull start it with the throttle wide open every time. Adjusted the valves and it would start right up.
DOPRESTON is offline
1994 kawasaki bayou 300 quits when warm
1995 kawasaki bayou 400 solenoid how to fix
2003 kawasaki bayou 300 wont fire
bayou for trun over but wont crank
kawasaki bayou 300 ignition problems
kawasaki bayou 300 only sparks after letting off starter button
kawasaki bayou 300 starter problems
kawasaki bayou 300 starting problems compression
kawasaki bayou 400 igniter troubleshoot
kawasaki bayou starting problems
no click or ignition light 220 kawasaki bayou
pull start not cranking bayou 300
what makes my 2001 kawaski 300 shut down after a hour of running
Bayou 220 Starting Problems 09wingates Kawasaki Brute Force/Prairie/Bayou 6 02-02-2017 11:29 AM
1993 Bayou 300 starting problem 905sra Kawasaki Brute Force/Prairie/Bayou 3 11-23-2011 06:20 PM
Bayou starting problem scruffy19 Kawasaki Brute Force/Prairie/Bayou 2 12-31-2010 05:41 PM
98 bayou 400 kfl starting problems BLACKCHEVY24 Kawasaki Brute Force/Prairie/Bayou 3 10-23-2010 06:06 PM
'j95 Bayou 220 Starting Problems thajuice Kawasaki Brute Force/Prairie/Bayou 0 09-18-2009 08:20 AM
