my exuast is glowing cherry red on my 05 brute 750 - Page 2 - Kawasaki ATV Forum
post #11 of 13 Old 02-02-2012, 02:17 PM
Feedback Score: 9 reviews
VFORCEJOHN's Avatar
Some mis info here.
sooty black exhaust= LEAN
wet/greasy exhaust = rich
popping on decel and backfire= LEAN on MAINS (or loose exhaust)
If you see flames coming out on decel it's LEAN not rich
these things will run ok 10.0:1 a/f pig rich, they won't not run too well but you won't experience major issues. they will not run well at all LEAN.
Howabout you figure out your jetting and let us know what it is.
most likely it hasn't even been jetted at all.
WEB: WWW.VFORCEJOHN.COM
PHONE: 570-773-1240
EMAIL: Vforcejohn@yahoo.com
DISCOUNT MUZZY EXHAUSTS click here http://www.kawieriders.com/forum/int...ml#post1328320
VFORCEJOHN is offline
post #12 of 13 Old 03-21-2013, 07:44 PM
hi to all the brute lovers currently having a rear header glowing red issue my self any advise deeply appreciated all mods include very simple uni filter,dynatek cdi,iridium plugs,hmf slip on,with dyno jet kit running #40 pilots 150f/155r, a/f out 2 turns ,needles set on 4 notch with 2 washers only seems to be running lean at mid and wot but even at mid just puttin around for about 15 min we are glowing red about 4-6 inchs on rear head pipe only i am only about 50 foot above sea level here just fyi if anybody out there has had similar issues with similar mods pls HELP !!! on the fix thanks again
Chunky0307 is offline
post #13 of 13 Old 03-22-2013, 12:53 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Raise those needles.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
full system exuast BIG BRUTE FORCE 650 4X4 Kawasaki Brute Force/Prairie/Bayou 10 06-08-2011 11:43 AM
does anyone know where to buy cheap factory full exuast kit for o5 750 brute BIG BRUTE FORCE 650 4X4 Kawasaki Brute Force/Prairie/Bayou 3 04-11-2011 07:44 PM
Don Cherry Camo Club Kawie 9 03-07-2010 09:48 PM
Project Cherry Pie RAWDAWG700 Kawasaki KFX700 V-Force 41 09-21-2009 01:59 PM
Cherry red header? nate Kawasaki KFX700 V-Force 11 11-10-2008 07:43 AM
