Old 03-14-2012, 08:07 PM   #11
Quad82's Avatar
View Quad82's Photo Gallery(0)
Default
A common symtem (sp) of a bad pick-up. Turns over and over with no spark. Then, when you let off the starter button you get 1 good spark. Not to throw money at it. But if all other avenues fail, that is where I would start. Deff get yourself a manual and see if it has a troubleshooting stats for testing the pick-up.
95 KLF400
01 KLX440
03 KFX440
04 KFX440
01 TRX500
85 lt185
89 230 Quadsport
03 S-10 Quad-cab
Quad82 is offline   Reply With Quote
Old 03-16-2012, 10:27 AM   #12
View Mustangnemisis's Photo Gallery(0)
Default
So went to an Atv salvage today to get a cdi and coil and rectifier and brought the bike with me and the guy at the salvage came out ran a couple test and turns out the pulser was my problem it wasnt giving off any signal to the cdi so the cdi knew when to fire the coil so problem fixed it was: The pulser under the engine cover
Kawasaki bayou klf300c
Wiseco piston
Custom exhaust
4 inch lift kit
27 inch mud lite tires
Kawasaki prairie 400 4x4
2 inch lift, push bar 26 inch mudlites, snorkeled
Ready to break it and build it better
Mustangnemisis is offline   Reply With Quote
Old 03-18-2012, 06:46 PM   #13
Quad82's Avatar
Default
Sounded like a pick-up (pulser) coil issue. Thanks for letting us know what the fix was.
95 KLF400
01 KLX440
03 KFX440
04 KFX440
01 TRX500
85 lt185
89 230 Quadsport
03 S-10 Quad-cab
1999 kawasaki bayou lift
99 kawasaki bayou 300 cdi problems
custim atv lift kit for 300 bayou
custom kawasaki bayou 300
kawasaki bayou 300 6 lift kit
kawasaki bayou 300 intermittent spark
kawasaki bayou intermiting spark
kawasaki klf300c
kawasaki klf300c atv
kawasaki klf300c atv not firing
kawasaki klf300c bayou
klf300b cdi cranks good
klf300c
You may not post new threads
You may not post replies
Ignition Problem: 1999 Kawasaki Prairie 300 4x4 decon Kawasaki Brute Force/Prairie/Bayou 0 11-08-2011 03:19 PM
Ignition Problem 650 Prairie Kawasaki Brute Force/Prairie/Bayou 0 03-26-2011 07:36 PM
Kawasaki kfx 700 stage 3 rev box ignition cdi????? bigevil Kawasaki KFX700 V-Force 1 04-12-2010 06:31 AM
Ignition Switch Problem G Bob Kawasaki Brute Force/Prairie/Bayou 1 03-03-2010 07:08 PM
ignition problem??? Bodawg Kawasaki KFX700 V-Force 6 01-17-2010 03:03 PM
