Prairie 300 4x4 - Kawasaki ATV Forum
post #1 of 7 Old 03-21-2012, 07:41 PM Thread Starter
Prairie 300 4x4
hey gang just purchased this 99 model prairie 300 4x4 for $800.00 . The little prairie was purchased for my girlfriend to ride because she is tired of being on the back of mine all the time . I purchased this from the original owner who only used it on his cattle farm . The quad cranks and runs excellent - shifts from neutral to reverse fine and from high range to low range fine - brakes work good - i rode the quad for over five miles with no problems before i purchased it and went over it and could not find any leaks of any kind . Now the bad the front end feels loose so when i got it home i put it on the lift and looks like it will need some ball joint and some tie rod ends . Besides the worn out front end and tires and it being really dusty i will be doing a partial restoration on this thing so it can be trail reliable . Who makes the better ball joints and tie rods and what mods can be done to make it a little peppy ?
maddmaxx65 is offline
post #2 of 7 Old 03-22-2012, 04:54 AM
Feedback Score: 1 reviews
jakedogg's Avatar
OEM for the ball joints and rod ends. Congrats on your purchase, darn good deal.
Brute Force 650 (SRA)
26 Ripsaws on MSA Torks
Dyna CDI
Custom Skids & Bumper
Muzzy
JD Powersports
jakedogg is offline
post #3 of 7 Old 03-22-2012, 07:37 PM Thread Starter
For your info i found some factory rims and tires that were dealer take offs from an 09 brute force - i needed new tires anyways and purchased them for $200.00 and brought them home . Just for shitz and giglez i took off the tire on the right rear side just to see if the rim and tire from the brute force would even be close to fitting and BAM the thing bolted right on with no problems - will post pics in the morning for proof - have not checked the front but as of right now i know for certain that the rears from the 09 650 brute force will bolt directly on your 99 model prairie 300 4x4 . In the morning when i get off from work i will check the fronts and snap some pics for proof
post #4 of 7 Old 03-23-2012, 08:22 AM Thread Starter
Well finally got off work this morning - had to work over - but i did manage to put the tires and rims from from the 09 brute force 650 on my 99 prairie 300 4x4 - no modifications needed - they were a complete bolt on . The front tires stayed the same 25x8x12 and the rear tires changed from 25x11x10 to the 25x10x12 . Proof is in the pics
post #5 of 7 Old 07-28-2012, 12:54 AM
jcpaynblazer's Avatar
agreed. i got a 2000 300 4x4 for $900 and all it needed was a damn rough brake job lol. yours sounded way easier to fix. but a hell of a deal none the less
2000 Kawasaki Prairie 300 4x4
DynoJet Jet kit
Custom 1.5" Snorkel AirBox intake
Custom 1.5" Snorkel CVT Intake
High Lifter 2" lift
25" Mud Titan, 8in wide in front, 12in wide in the back
2500lb Badlands Winch
jcpaynblazer is offline
post #6 of 7 Old 07-28-2012, 06:06 AM
Feedback Score: 3 reviews
NovaKaw650's Avatar
I've always liked the P300; more speed than the P360 as well.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #7 of 7 Old 07-28-2012, 11:33 PM
Yeah my spedometer is broke but i got a buddy to ride next to me in his car and i got a solid 55mph out of her
DynoJet Jet kit
High Lifter 2" lift
2000 prairie 300 4x4 reviews
kawasaki 300 prairie
kawasaki atv forums 4x4
kawasaki atv prairie 300 4x4
kawasaki prairie 300
kawasaki prairie 300 4x4
kawasaki prairie 300 4x4 review
kawasaki prairie 300 4x4 top speed
kawasaki prairie 300 forum
kawasaki prairie 300 problems
kawasaki prairie 300 review
kawasaki prairie 300 reviews
kawasaki prairie 300 specs
Pulling a engine on a prairie 700 and putting it on a prairie 650. onebadprairie Kawasaki Brute Force/Prairie/Bayou 11 05-14-2013 10:04 AM
03 Prairie 650 Motor in 02 Prairie Chassis Kawidan Kawasaki Brute Force/Prairie/Bayou 2 01-14-2013 03:28 PM
Will a front differential from a 2005 Prairie 360 work with a 2003 Prairie 650? David1985 Kawasaki Brute Force/Prairie/Bayou 11 08-30-2011 06:08 AM
lte for prairie and head prairie with 1.5 mm valve over brute 665 For Sale 3 11-17-2008 01:46 PM
04 Prairie 700 motor in 02 Prairie 650 Chassis Kawidan Kawasaki Brute Force/Prairie/Bayou 4 03-09-2007 03:53 PM
