Kawasaki Prairie 700 Valve Problems - Kawasaki ATV Forum
post #1 of 5 Old 04-12-2012, 02:54 PM Thread Starter
Hi there guys new member to this site.
I picked up a 2005 Kawasaki Prairie 700 yesterday as a project bike, the engine is not running but i got the bike for a steal. Easily part it out and make money but that's a last resort.
Story is the last owner was driving across the lake in the winter time and the bike just died on him. Its got 7500 km on it.
I took it home and checked compression and both the front and rear cylinders are flat >20 psi. I then took off the valve cover so that the rockers were off the valves and then checked the compression of the cylinder itself and it was in the low 90's for psi. Has anyone had this problem before? Any knowledge would be greatly appreciated!
vezina is offline
post #2 of 5 Old 04-12-2012, 03:04 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
The intake valves go tight, that causes the loss of compression. The first symptoms are hard starting. The cams have auto compression releases, so the compression is low when testing; something like 50-70lbs is normal. 20lbs is not enough to start.
It doesn't explain why it stopped dead.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #3 of 5 Old 04-12-2012, 03:20 PM Thread Starter
Is it feasible to shim the valves or is replacing them a better option, i just shimmed my Crf250r and it worked great.
vezina is offline
post #4 of 5 Old 04-12-2012, 03:30 PM
NovaKaw650's Avatar
Garage
It's your lucky day!
No shims; there are adjusters on the rocker arms.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #5 of 5 Old 04-12-2012, 03:32 PM Thread Starter
Beautiful, ill see what that does.
vezina is offline
Tags
kawasakiprairie700, prairie, valves, valvetiming
04 kawasaki prairie 700 reviews
05 kawasaki prairie 700 cam
05 kawasaki prairie 700 low compression
2005 kawasaki prairie 700 cams
2005 kawasaki prairie 700 compression readings
how to remove master cylinder piston from kawasaki prarie 700
intake valves 04 700 parrie
kawasaki 700 prairie
kawasaki praire 700 what should compression be
kawasaki prairie 700 checked compression its 90 lbs
kawasaki prairie 700 engine
kawasaki prairie 700 master cylinder problems
Kawasaki mojave valve question mattsteibler26 Kawasaki Mojave/Lakota 7 02-25-2012 09:44 AM
will a 2004 Kawasaki Prairie 700 Rear Differential fit 2002 Kawasaki Prairie 650 purpitt Kawasaki Brute Force/Prairie/Bayou 0 10-23-2011 12:49 PM
4X4 Problems - New to Kawasaki SirMudAlot Kawasaki Brute Force/Prairie/Bayou 6 09-22-2011 09:49 AM
Adjust Valve Kawasaki Bayou 220 vladiassis Kawasaki Brute Force/Prairie/Bayou 3 06-20-2011 05:51 PM
valve problems? SxysCowboy Kawasaki Brute Force/Prairie/Bayou 4 10-11-2004 05:48 PM
