Front differential problem? - Kawasaki ATV Forum
post #1 of 9 Old 05-24-2012, 01:11 PM Thread Starter
Exclamation Front differential problem?
Hello, i am new to these forums.
I have a month and half old, 2011 brute force 650 sra.
Love it to death, does everything i ask it to do. But when im in 4 wheel drive and try to reverse in mud/sand/or water the front drive shaft pops in and out and makes a very obnoxious noise that makes me cringe ha.
If i can get anyone's opinion, its greatly appreciated. Thanks.
GeneralLee is offline
post #2 of 9 Old 05-24-2012, 01:16 PM
Feedback Score: 5 reviews
Check and make sure there is a spring in the shaft. Has it done this always?
nate_1503 is offline
post #3 of 9 Old 05-24-2012, 02:06 PM Thread Starter
Well its still under warranty so i havent been wanting to break it all apart. And ya kinda. Ive only noticed it cause ive gotten stuck in mud a few times and tried to revers but it makes a grind kinda. It seems like its trying to find a gear in there. Where is this spring at in the shaft?
post #4 of 9 Old 05-24-2012, 02:07 PM Thread Starter
AAAnd it would be hard to show the dealer cause it only happens in mud/sand/water not on anything else
post #5 of 9 Old 05-24-2012, 02:12 PM
Feedback Score: 2 reviews
canada's t4's Avatar
are you trying to put in 4x4 after you get stuck if so that noise is normal and not good as these diffs take a few turns to lock in u should keep it in 4x4 before entering a whole
`2005 bruteforce 750i
26 inch mudlites
moose power module
passenger seat
warn winch
fairing
muzzy pro
`1996 ski doo formula 3 600 triple(AKA the purple screamer)
`2006 brutefore 650i( getting complete rebuild from frame up)
canada's t4 is offline
post #6 of 9 Old 05-24-2012, 02:21 PM Thread Starter
Sometimes i have and i figured that they were normal but im talking about they dont go away. I can hear it lock in but then the make a louder noise. I think its just normal probably, i just dont like the noise cause it can sound bad.
i have gotten in water then switched it to 4wd and then tried going reverse it does the same.
post #7 of 9 Old 05-24-2012, 02:41 PM
Prairie Under Pressure's Avatar
You should always put it in 4x4 when ever you think you might need it. Dont wait until you are not moving and try it or you will break it and you will have to pay for it. I got stuck going up a hill that was red clay and wet one time and had a line of atv's behind me. I could not get it into 4x4 without hurting it so I just asked my friend on a polais to push me far engough for it to engage. That was not what I wanted to do but had no choice. So remeber lock it in 4x4 when you think you might go somewhere that you will need it. It is not designed to lock in with the front wheels stopped and the rear spinning.
2007 Cadilliac Escalade ESV 403 hp 6 speed trans
2003 Dodge Hemi Ram 4x4 Quad cab
1996 Dodge Cummins turbo Diesel 280HP 680TQ
2004 Prairie 700
2001 Polaris 500 HO
2009 Honda RancherES 420 4x4
2003 Honda 250EX
2001 Kawaski KX125
2001 Kawasko KX100
2002 KAwasaki KLX125
2004 Carter Talon 150cc GO Cart
2006 50cc R1 Super mini bike
Prairie Under Pressure is offline
post #8 of 9 Old 05-24-2012, 02:46 PM Thread Starter
True, usually i have been doing that but i hope its not to late :/ but when in fourwheel drive all tires do spin and have power so that's good.
But even thought it has a flip switch it wont engage until stopped or about 5 mph. And im glad i dont have to deal with red clay. Its the worst.
post #9 of 9 Old 05-25-2012, 05:50 AM
The actuator control module is programed to not engage teh 4wd actuator unless motion is detected. If you engage from a stand still, if often does not engage fully and will only partially engage the front diff. this will lead to the splines beeing stripped. The control module is also programmed to not engage or disengage the 4wd actuator over ~12mph.
KDIXER is offline
Tags
4 wheel drive
06 brute force front differential wont engage
2004 kawaski prarie 700 front differential making popping sound
2004 prairie 700 failed actuator
2005 kawasaki prairie 700 4-wheel drive pops
brute force 750 front differential clunk
brute force 750 front differential problems
brute force front differential problems
brute fprce 750 differential noise
can am commander rear differential problem after reverse in mud
checking the front diff brute force 750
front differential popping under load 2004 arctic cat 500
prairie 700 front differential inspection
prairie front differential problems
Why 10w-40 in front differential?? kurtfrombell Kawasaki Brute Force/Prairie/Bayou 6 03-08-2012 06:14 AM
HELP! Rear differential problem! Newbie... joshw1950 Kawasaki Brute Force/Prairie/Bayou 4 12-19-2011 10:00 AM
front differential oil stonewall Kawasaki Brute Force/Prairie/Bayou 4 03-10-2011 02:57 PM
WTB- Front differential carnut Wanted 3 10-02-2009 06:26 AM
WTB : Front Differential KMKjr Wanted 4 01-29-2009 02:51 PM
