Prairie 700 backfiring through carbs - Kawasaki ATV Forum
post #1 of 5 Old 08-21-2012, 08:47 AM Thread Starter
SKC
I have replaced the fuel pump. It starts right up but will backfire through the carbs when given high throttle. I was
thinking i need to clean the carbs or jets? Any ideas?
SKC is offline
post #2 of 5 Old 08-21-2012, 09:22 AM
Feedback Score: 4 reviews
Mikeyboy_esq's Avatar
Popping thru the carbs could possibly be caused by dirty carbs or else it is running lean and needs to be rejetted. Did you do any motor upgrades recently that may cause it to need to be rejetted (e.g., installed aftermarket exhaust, drilled holes in the airbox, install a high flow air filter, etc.)?
2007 KFX 730 (sold)
2004 Twin Peaks 800 (sold)
2003 Prairie 650 (parted out)
2002 Prairie 650 (parted out)
Happy trails...
Mikeyboy_esq is offline
post #3 of 5 Old 08-21-2012, 09:39 AM Thread Starter
SKC
I haven't done anything else besides change the fuel pump.
SKC is offline
post #4 of 5 Old 08-21-2012, 10:03 AM
Then my guess is that you probably got some trash in the carbs. It doesn't take much to clog up the carbs and make them run poorly. My advice is to remove the carb bowls (be careful if they still have the stock carb bowl screws...they are soft and tend to strip out on the head) and the diaphram/slides (they are under the large black plastic caps) and spray out the carbs real good with carb spray and reassemble. If you haven't already done so, now would be a good time to replace the stock carb bowl screws with allen head bolts. Good luck.
2007 KFX 730 (sold)
Happy trails...
post #5 of 5 Old 08-21-2012, 02:04 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Quote:
X2.
If it ran good before the fuel pump went bad, then you dislodged some dirt and it's now in the carb/carbs.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
04 prairie 700 backfiring through carb
2003 kawasaki prairie engine backfires
2004 kawasaki prairie 700 back fire
2004 kawasaki prairie 700 backfire
2004 kawasaki v twin 700 back fires no power
2004 kvf 700 carb adjustment
kawasaki prairie 700 4x4 atv back fireing
kawasaki prairie 700 4x4 atv back fireing and no power
kawasaki prairie 700 backfiring
kawasaki prairie 700 carburetor
removing the carburetors from my kawasaki prairie 700 4x4
youtube 700 kawaski atv backfiren
backfiring though the carbs Dr. Love Kawasaki KFX700 V-Force 7 07-01-2011 08:56 PM
06 650 Brute backfiring thru the carbs tbone550 Kawasaki Brute Force/Prairie/Bayou 2 11-28-2010 09:53 AM
03 Prairie 360 4x4 Backfiring BIGTIME57 Kawasaki Brute Force/Prairie/Bayou 0 10-11-2010 05:48 AM
BACKFIRING THEW CARBS DIESEL-TECH Kawasaki Brute Force/Prairie/Bayou 3 11-22-2007 10:02 AM
Prairie backfiring Adirondack Man Kawasaki Brute Force/Prairie/Bayou 3 06-04-2003 06:39 PM
