starter problem - Kawasaki ATV Forum
post #1 of 7 Old 08-30-2012, 04:37 AM Thread Starter
starter problem
Hello, i have a '08 brute force 750 4wheel drive. it was running good since i bought it second hand and only 28 hours on it. i was starting her up and heard some loud nocking noise then it started but with the idle going up and down, tried giving some throttle to it went decent but once i tried putting on reverse died out. tried starting her up and all of a sudden just spins. pulled starter out to check on shaft everthing looks perfect, tried starting to verify if starter operates correctly, all i get is a click like a dead battery. but i fully charged the battery. so i check the flywheel where the starter shaft turns over....and it spins freely. Is that supposed to be spinning free or has to have some tension? please help me out here. THANKS!
jensvw is offline
post #2 of 7 Old 08-30-2012, 05:09 AM
Feedback Score: 5 reviews
Shouldn't turn free... You probably have a busted starter gear. Pull the stator cover to verify
nate_1503 is offline
post #3 of 7 Old 08-30-2012, 06:24 AM
Feedback Score: 23 reviews
T_Dilley's Avatar
Not likely but you could have sheared your key way in the flywheel too.
2004 KFX715
'The Blue Bullet'
2004 KFX700/Stock
2004 KFX700/Bolt Ons
T_Dilley is offline
post #4 of 7 Old 08-30-2012, 01:11 PM
Was the starter earthed when you tested it? If it was off the bike it might only have the positive cable to it. Relay would click but starter wouldn't move. Sorry of its a stupid question.
And my bayou 220 turns freely too when the starter is out. Found that out yesterday.
markp is offline
post #5 of 7 Old 08-30-2012, 03:28 PM Thread Starter
Post
exactly what happened, relay clicked and starter didnt budge at all. Installed starter back in, and just spinned. took it back off and just clicked again.
jensvw is offline
post #6 of 7 Old 08-30-2012, 11:10 PM
When the starter is out the bike you do need to put a earth / neutral wire to the body of it to make the electrical circuit.
markp is offline
post #7 of 7 Old 09-05-2012, 03:25 PM Thread Starter
I'm just a newby to this sport, but i was talking to a friend that does motocross racing and he was telling me i may have a blown motor or busted piston, i figured if low on oil my oil lite will flash but nothing went on and i figured nocking noise from engine will be heard when engine is on but nothing too. KINDA CONFUSED HERE
jensvw is offline
bayou 220 keyway sheared
brute force 750 keyway
brute force 750 starter problems
brute force 750 starter problems#gsc.tab
brute force 750 starting problems
brute force sheared keyway
kawasaki bayou 220 shear of key
kawasaki brute force 750 starter relay
kawasaki lakota solenoid problem
solenoid clicks but will not spin starter on a brute force 750
solenoid problem on my 07 brute force
starter relay bayou 220
why does the starter on my bayou 220 just spin
Prairie 700 Starter Problem?? dudley237 Kawasaki Brute Force/Prairie/Bayou 4 02-25-2012 09:17 PM
Need help with a starter problem? Ametuer Everything Else 2 01-01-2012 06:37 AM
starter problem dblbassdruMer Kawasaki Mojave/Lakota 3 09-21-2011 05:48 AM
Starter Problem ACEKFX Kawasaki KFX700 V-Force 6 08-31-2008 06:20 AM
Starter problem jak Kawasaki KFX700 V-Force 5 10-22-2007 09:01 PM
