750 brute with 650 crank? - Kawasaki ATV Forum
post #1 of 9 Old 09-08-2012, 06:50 PM Thread Starter
I have a 750 brute and my rods seized on my crank. I have a good 650 crank sitting in the shop. I was thinking of using the crank out the 650 in my 750. It should drop me to a 715. I need a quick cheap fix. Hunting season just started and i need my brute. What do you think? should i try this or not?
joshall03 is offline
post #2 of 9 Old 09-09-2012, 06:17 AM
Feedback Score: 3 reviews
rdm531's Avatar
the 650 has a 3mm shorter stroke, would probly work ,but you will lose preformance
06 650i,sleeved to 85mm, fst 11.5-1 pistons, fst stage 2 cams,hd value springs,dyna fs ing,full hmf exhaust, ,29.5skinny laws, 1.5in spacers front/2.5 spacers rear, 4000rt warn winch, 3in center snorkels,rad relocated,aux driving lights,back up light,custom 4 gauge cluster, oil temp, oil press, water temp, an return oil temp,rmax manual 4wd,oil cooler,. ez steer
custom cut clutches
rdm531 is offline
post #3 of 9 Old 09-09-2012, 07:04 AM
Feedback Score: 1 reviews
It will work as long as you have the 650 rods, its should ge a really quick reving 715
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #4 of 9 Old 09-09-2012, 02:17 PM
dennisgb's Avatar
Okay school me here.
If there is 3mm shorter stroke, you lose significant compression on power stroke if you only change the crankshaft. Even with the 650 rods you end up with a larger combustion chamber space which in turn will result in a huge power loss. I honestly don't think it would work. It might run but really bad.
Am I missing something?
dennisgb is offline
post #5 of 9 Old 09-09-2012, 03:43 PM
reds650's Avatar
The 650 stroke is 3mm more 1.5 mm offset. The 650 rods are 1.5 mm longer so you get the same deck hight. The combustion chamber stays the same but compression ratio will drop a small amount from the shorter stroke
09 brute force 750
A few mods lol
reds650 is offline
post #6 of 9 Old 09-09-2012, 05:26 PM
dennisgb's Avatar
Quote:
Wow! It took me a while to figure out what you meant. I thought the earlier post said the 650 stroke was shorter. I get it now. Actually this combination if the deck height is the same should result in a higher reving engine. Is there any issue with a difference in piston skirt length? With the shorter stroke could be an interference there if they changed the skirt on the pistons.
Otherwise from what you said here, it could be an interesting combination. I don't think it will result in a compression drop if the deck height is the same. Really only loose the total CC's of the shorter stroke.
dennisgb is offline
post #7 of 9 Old 09-09-2012, 05:48 PM
No issue with skirt legnth at all, the longer rods make up the difference, any combination of piston and crank will work if it has the proper connecting rods. I built s 650, stock pistons with a 700 crank, worked out to a 662 i think. The prairie that im running now has a 650 crank with 83mm, Pistons making it a 682 and it works great...just need some better cams
Green 2004 Vforce
2002 650 Prairie
riverkid is offline
post #8 of 9 Old 09-09-2012, 06:29 PM
reds650's Avatar
I meant to say the 750 is 3mm longer not the 650
09 brute force 750
A few mods lol
reds650 is offline
post #9 of 9 Old 09-10-2012, 07:19 PM Thread Starter
Im going to go ahead and build this motor with the 650 crank and rods but i am going to run a higher compression piston.
2004 650 kawasaki brute force crankshaft
650 bruteforce crank in 750 brute
arctic cat 750 crankshaft
brute force 650 crank #
brute force 750 crank forsale
brute force 750 pistons 650 crank
is a 650 and 750 brutforce crank the same
is a brute force 750 crank the same as a 650
is an artic cat 650. crank same as brute 750
kawasaki pririe 650 crankshaft swap 750
what is the difference between a 650,and 750 kawasaki brute force crank
what the difference between a kawasaki brute 650and 750 crank
will a 750 crank work in a 650 brute force
New 4.4 mm stroker crank for brute 750 powerpresser Kawasaki Brute Force/Prairie/Bayou 6 01-27-2012 01:29 PM
Brute 750 Crank 750brett For Sale 3 03-12-2011 03:30 PM
08 Brute 750 won't crank. J Luke Kawasaki Brute Force/Prairie/Bayou 7 10-25-2010 02:57 PM
brute crank? 02screw Kawasaki Brute Force/Prairie/Bayou 0 08-18-2010 04:41 PM
brute 750 crank aaron_j Wanted 0 11-23-2009 07:41 AM
