carb questions or advice - Kawasaki ATV Forum
post #1 of 14 Old 12-15-2012, 12:01 PM Thread Starter
ok 2006 BF 650 SRA
i am going to rebuild my carbs. lot of good deals on ebay for rebuild kits. any one have problems with non OEM rebuild kits?
while i am in there should i rejet or do anything else while i got them off?
i dont drive fast, mainly trail riding and sometimes alot of deep mud...
the bike is factory with the exception that i plan on putting 28 inch tires on it.
any helpfull comments, or advice would be greatly appreciated
themacdadt is offline
post #2 of 14 Old 12-15-2012, 01:27 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
I personally won't use aftermarket carb kits.
Why do you feel the carbs need rebuilding? They almost never wear out; they just get dirty or gummed up.
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is online now
post #3 of 14 Old 12-15-2012, 02:00 PM Thread Starter
carb
well i just bought it and the guy said it sat a while. it would only idle and run with the choke all the way out. and it would run great.. as soon as you push the choke in it would die. if i gave it gas while pushing in the choke it would run fineover half throttle. less than half it would spit and sputter and backfire occasionaly.
so took carbs out cleaned out the best i could( the 2 jets inside than you can unscrew) reinstalled and now it does run with the choke off but still does not idle correct. and spits and sputters at low rpm.
so i fixed 50 percent of the problem being that now it will idle with no choke as long as i give it a tinny bit on the throttle.(where as before it wouldnt)
also the idle screw is turned all the way in.
so i think i need to take back off and soak the carbs. hopefullt there is just some varnish in the carbs that i could not see or clean with just the 2 jets being removed. and i was thinking that while i had them all apart and soaking that i would need a rebuild kit to put them back togather.
any more advise would be great... thanks
post #4 of 14 Old 12-15-2012, 02:11 PM
NovaKaw650's Avatar
Garage
There is a screw in each carb that goes into the body; it's the pilot screw. If those are the ones you have turned all the way in, then open them 2 turns. If it is the idle speed that's turned up as fast as it will go, then the carbs are still dirty; most likely the pilot jets and idle circuits.
2002 698 Prairie
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
VFJ Springs
DynaTek CDI
Other weird stuff
post #5 of 14 Old 12-17-2012, 07:11 AM
VTwinKawi's Avatar
general carb advise: take a little piece of wire or small pick and poke through every single little hole.
2016 570 outty max 27 mudlite xtr
2006 660 Rhino 27 mega mayhems
2003 650 Prairie mud lites(sold)
2008 700r Raptor se (sold)
2006 360 full skids winch (sold)
VTwinKawi is offline
post #6 of 14 Old 12-17-2012, 07:59 AM
I'd bet you anything that it isn't a need for the rebuild kits. Best thing you can do is spend that money on a gallon of Gunk parts wash. (I actually think its carburator soak but can't remember) I got mine from Advanced Auto or O'rileys. Either way it comes in a gallon can with a little basket in it. Pull the carbs, disassemble making sure to remove ALL plastic parts, drop it in overnight and then the next day use compressed air to blow out ALL small orfices and reassemble.
My 650 set for like two years with very little running and ethanol gas in it. I had treated the gas but didn't realize it would still do this until now. Mine had green moss looking stuff growing inside the carbs and I even had problems with the fuel pump doing the same thing. I promise you don't want to have to buy one of those things either. Kawie wants like 500 bucks for it.
One other thing I'd recommend you check is the front and rear diff oil. If it has been setting for a while it would be a good idea to get that changed or you might end up like me and be doing a rebuild before long. These things are known for leaking and if it got water inside it before it was parked.... Trust me its a pain in the butt to have to do especially if you could change the oil and not have that problem.
Just a word from one that has been there. Hope you enjoy the ride.
PRAIRIEOUTLAW is offline
post #7 of 14 Old 12-17-2012, 03:15 PM Thread Starter
carbs
thanks for all the advice, i think i am going to break down and soak them and see what happens. am going to buy bowl gaskets and o-rings also.
ill let you know what happens.
thanks again. todd
post #8 of 14 Old 12-17-2012, 05:52 PM
dennisgb's Avatar
Quote:
This advice is absolutely critical especially the pilot jets. Sounds like you only took out the main jets. You need to take the pilot jets out also. They are smaller and next to the mains. You should also take the float needle seat out and clean it and inspect (although this doesn't effect idle). Adjust the pilot screws with engine hot and running. Start at 2 1/4 turns out.
2003 Kawasaki Pairie 650 - Dynatec CDI - Big Gun EVO Exhaust - Shimmed Needles - KEBC Removed and Bypassed
dennisgb is offline
post #9 of 14 Old 01-19-2014, 03:51 PM
This may sound dumb but I'm an old guy with limited flexibility. I can access the carb allen head float drain screws & the idle speed adjustment but can't seem to get at the idle circuit mixture screws. Do I have to remove all the higher stuff to get at them? It';s a 650 brute force, 2008.
al35ford is offline
post #10 of 14 Old 01-19-2014, 05:53 PM
chopermech's Avatar
No, get a small pocket screw driver, if there are no plugs over the screws, it should be real easy.
Bicycle
chopermech is offline
03 kawasak 360 carb wires
08 kawasaki prairie 360 carb jet placement and float height
2003 kawasaki prairie 360 spit and sputter issue
2004 kawasaki prairie 360 carburetor idle
2012 kawasaki prairie 360 spit back in carb
can i buy a carburetor jets for kawasaki at orileys?
kawasaki brute carburetor jets you don't poke with wire
kawasaki prarie 360 sputters at high rpm
lt80 spit and backfire
orings 2003 kawasaki 650 prairie air tested blew out orings
prairie 360 can't get needle valve out of carburator
should there be some vaccum at idle with fuel pump on john deere f725 kawasaki 20 hp
where are the vaccum ports on a brute force
Valve lash is good , still popping out the front carb. Advice please. applehead Kawasaki Brute Force/Prairie/Bayou 12 07-28-2014 02:01 PM
carb needles. need advice ffmict Kawasaki KFX700 V-Force 2 11-02-2012 06:49 PM
Prairie 360 tunning carb advice needed bhi3202 Kawasaki Brute Force/Prairie/Bayou 20 08-27-2012 10:22 AM
I need some advice on carb probs jjs3788 Kawasaki Brute Force/Prairie/Bayou 14 09-18-2011 05:06 AM
ned some advice on carb hellhound Kawasaki Tecate 3 10-07-2010 11:27 PM
