Removing a primary clutch - Kawasaki ATV Forum
post #1 of 23 Old 01-20-2013, 10:17 AM Thread Starter
1.Random.guy's Avatar
I tried to take off my primary clutch with the puller... Didnt work. I used the puller and a socket wrench. I pretty much torqued it as much as I could. No pop. The dang thing did nothing. Do I need a impact wrench?
1.Random.guy is offline
post #2 of 23 Old 01-20-2013, 10:23 AM
Feedback Score: 2 reviews
kawiprairie700's Avatar
was it a puller made by kawasaki, epi, or dalton? or was it a puller off ebay or on a website that said its made for Kawasaki but doesnt give a brand? if it is a "no name" puller then it will NOT work., by the way i almost destroyed my clutch with a "no name" aka... Chinese puller that says its made to work on a Kawasaki but wont. get a puller made by epi, dalton, or Kawasaki and it should work fine. My personal puller is epi and it works great
2005 YFZ450SE
Brute Force 730SRA
kawiprairie700 is offline
post #3 of 23 Old 01-20-2013, 10:23 AM
Feedback Score: 6 reviews
spdrcr's Avatar
Kawie puller with impact and if not step it up to a 3/4 impact
2014 Can Am Outlander Max 1000 Limited
06 kfx700 meteor blue, t-4 duals, amr stage 3 cdi,amr coils, VFJ stage 3 w/ spider mod & Gen2 weights #6 spring, k&N, VEN tie rods, 400ex thumb throttle, PRM edge bumper, back rack and Nerfs, kawie swingarm skid plate, ELKA Stage 3 fronts and rear
95 Banshee all virgin original
11 grizzly 550 EFI, EPS (wifes)
14 RZR 800S LE Stealth Black (wifes)
06 polaris predator 90, custom PINK (daughter)
09 arctic cat 90 (daughter)
spdrcr is offline
post #4 of 23 Old 01-20-2013, 11:04 AM Thread Starter
Was this one from amazon...
http://www.amazon.com/CLUTCH-PULLER-KAWASAKI-SUZUKI-ARCTIC/dp/B004QJISMI/ref=sr_1_1?ie=UTF8&qid=1358708634&sr=8-1&keywords=kfx700+clutch+puller
They dont work? WTF?
post #5 of 23 Old 01-20-2013, 11:28 AM
spdrcr's Avatar
Junk, they are not hardened like the Kawasaki or epi and the tip will mushroom or bend and trash the threads on the crank and remember it reverse threads so tighten to remove
spdrcr is offline
post #6 of 23 Old 01-20-2013, 11:49 AM
TStubb's Avatar
^ OEM or EPI are the way to go. Use an impact if you have one.
Amature/Pro Dirt Machine Rider!
2006 Brute Force 650i
3,000lb KFI, HMF Slip-on, Dirt Commanders & STI Wheels, ITP Hole Shots & Vision Wheels, Ricochet Skids, Moose Power Module, No-Toil Airfilter, Power Madd Hand Guards, A3 Grips, Kawasaki Shock Covers, 2" Reciever, Temp Gauge, Ogio Bag, 2 Kolpin Jrs.
TStubb is offline
post #7 of 23 Old 01-20-2013, 11:49 AM
thats the piece of crap i almost killed my clutch on... dont use it!! get one of the 3 i said to get. I can recommend the epi because thats the one i have and i believe it works the best but your good with either kawasaki, dalton or epi.
2005 YFZ450SE
Brute Force 730SRA
post #8 of 23 Old 01-20-2013, 12:10 PM
Feedback Score: 3 reviews
NovaKaw650's Avatar
Garage
Quote:
How big/long was the socket wrench, and how were you holding the clutch from turning?
2002 698 Prairie
VFJ 11.5:1 coated pistons
FST Stage II Cams
Kibblewhite valves
Crossover intakes
Modded airbox
Full Muzzy
Custom machined stock weights
VFJ Springs
DynaTek CDI
Other weird stuff
2011 Stratos 186XT Bass Boat
Mercury Optimax 115hp
Lowrance HDS 10 Electronics
NovaKaw650 is offline
post #9 of 23 Old 01-20-2013, 01:11 PM Thread Starter
I was using a half inch large socket wrench. Had some decent torque on it. wasnt doing a damn thing. I had a large screw driver pushed through the clutch binding up on the step or something. The clutch remover threaded in like a normal bolt. It was not opposite like the clutch bolt. Weird enough...
post #10 of 23 Old 01-20-2013, 01:23 PM
the clutch bolt comes off reverse thread but the puller bolt goes in normally, you still need to get one of the three pullers... kawasaki, epi, or dalton, you can get them online or ebay or even the dealer but my dealer had the epi in the catalog, ordered it and it worked good, about $40 and i recommend it. If you dont get one of them and keep torquing your Chinese puller, your going to destroy the crank and clutch. vforcejohn says the same thing and he is the first one who pointed out to me that ill destroy my own clutch with the chinese puller so i bought an epi, it came right off but i literally had to jump on the wrench with all my weight until "POP" it came right off. Also put a screwdriver between the clutch to hold it in place while taking it off.
2005 YFZ450SE
Brute Force 730SRA
Effect of removing shim from primary clutch? meangreen06kfx700 Kawasaki KFX700 V-Force 10 10-11-2012 05:46 AM
removing clutch kit? cody_20 Kawasaki Brute Force/Prairie/Bayou 1 05-09-2012 09:25 AM
Removing Primary Clutch WV-VRider Kawasaki KFX700 V-Force 33 03-01-2008 12:29 AM
HELP! Removing primary MuskwaMudder Kawasaki Brute Force/Prairie/Bayou 5 02-13-2005 07:11 PM
Advtages or removing shims under primary spring? wvprairie Kawasaki Brute Force/Prairie/Bayou 3 01-04-2005 02:42 PM
